naumuk(at)windstream.net Guest
Posted: Mon Jul 06, 2009 7:52 am Post subject: Left wing low |
All-
Gig's question about the relative weights is the next logical step in trying to figure out the cause of the left wing low syndrome. P factor can be eliminated because LWLS is present in projects equipped with both right and left prop rotation engines. Whether it works or not, disrupting the airflow with either movable aileron trim or fixed tabs cuts down on the overall efficiency. Is weight distribution really the culprit or is it something else?
Bill Naumuk
Townville, Pa.
HDS N601MG/Corvair 95%
leo.gates
Posted: Mon Jul 06, 2009 9:38 am Post subject: Left wing low |
All-
Mine is a HDS, however, I had a "heavy left wing." During Phase 1
testing I loaded 175 pounds of weight (sand) in the right seat to
balance my 175 pounds. With both wing tanks 1/4 full of fuel, there was
NO heavy left wing. Landing/taxi lights are in the left wing.
I have a matronics electric trim tab on the right aileron. I find I
adjust trim about every 10 minutes as well as switching fuel tanks
periodically.
I have a Y stick and fly with my arm resting on the arm rest and two
fingers on the stick.
Leo Gates
N601Z
Bill Naumuk wrote:
| Quote: | All-
Bill Naumuk
Townville, Pa.
Juan Vega Jr
Posted: Mon Jul 06, 2009 10:19 am Post subject: Left wing low |
All of you are missing the facts. Dont shoot the messenger, Ask any aeronautical Engineer, this plane is light wing load, thus, with weight shifted about it will tend to fly in that direction.
Juan
Gig Giacona
Posted: Mon Jul 06, 2009 11:14 am Post subject: Re: Left wing low |
| Juan Vega Jr wrote: | All of you are missing the facts. Dont shoot the messenger, Ask any aeronautical Engineer, this plane is light wing load, thus, with weight shifted about it will tend to fly in that direction.
Juan
Hence my question to see if most folks left wing is heavy when empty. My thought is, are the people with real heavy left wings heavy on the left side before they even get in.
601XL Under Construction
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Mon Jul 06, 2009 11:22 am Post subject: Left wing low |
On Mon, Jul 06, 2009 at 12:14:18PM -0700, Gig Giacona wrote:
| Quote: | Hence my question to see if most folks left wing is heavy when empty. My
My weights are 292 nose, 269 right main, 289 left main. My left wing is
definitely heavy when I'm solo in the left seat, but not whe I'm solo in the
right seat.
Jay Maynard, K5ZC, PP-ASEL, CFI-SP http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
z601(at)anemicaardvark.co Guest
Posted: Mon Jul 06, 2009 11:39 am Post subject: Left wing low |
On Monday 06 July 2009 14:14, Gig Giacona wrote:
<snip>
W.R. "Gig" Giacona
Perhaps another fractor may be the weight of the pilot. Although the question
probably wouldn't be well received, it might be interesting to know pilot
weight for those aircraft that fly with the port wing low.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Posted: Mon Jul 06, 2009 12:19 pm Post subject: Left wing low |
Leo-
So in other words, lack of a copilot makes a difference. What tank
config? Also, Scott L.- you fly solo/copilot frequently. What handling
differences have you noticed?
Angle of arm is a consideration, but who knows, you might be able to
compensate with multiple battery locations depending on cockpit load. THIS
IS PURE SPECULATION!!!
Bill
Mitch Hodges
Joined: 10 Jan 2006 Posts: 45 Location: Powder Springs, GA
Posted: Mon Jul 06, 2009 12:34 pm Post subject: Re: Left wing low |
| naumuk(at)windstream.net wrote: | ...you might be able to
compensate with multiple battery locations depending on cockpit load. --- |
Reminds me of the design of the original Rotorway Exec (not sure about the current, much evolved version). They had a weight that slipped either over the right skid when flying solo, or on an attachment hanging off the back of the cockpit centerline when flying with a passenger to compensate.
Very simple and took just a few seconds to move as part of the checklist.
_________________ Mitch Hodges
N601MH (Zenith 601HDS)
Builder Log at http://www.hodges.aero
Wings Under Perpetual Construction |
leo.gates
Posted: Mon Jul 06, 2009 1:36 pm Post subject: Left wing low |
Bill-
Ten Gal. leading edge fuel tanks only. Landing/taxi lights and pitot
static tubes on the left wing. Also, all my gyro instruments (3) are on
the left side of the instrument panel. Empty: 316 lb left, 302 lb
right, 56 lb tail. Hingless ailerons so I suppose a bit more trim tab
deflection than hinged version. I see 25 degrees up and down max. on
the trim tab. Does not seem to effect the TAS. That is not noticeably,
I'm sure it does to some small extent.
Leo Gates
N601Z CH601HDS TDO
Bill Naumuk wrote:
Leo-
to compensate with multiple battery locations depending on cockpit
load. THIS IS PURE SPECULATION!!!
Bill
wjones(at)brazoriainet.co Guest
Posted: Mon Jul 06, 2009 1:39 pm Post subject: Left wing low |
With Jay's weight at 850# ,does my target weight of 750# with a big engine
seem unattainable .I believe in keeping an aircraft as light as possible
.Build the plane close to the plans and if you plan to add any extras parts
,toss the extra parts into the air and if they return to earth they are too
heavy for your plane . IMHO
Wade Jones South East Texas
jmaynard
Posted: Mon Jul 06, 2009 1:54 pm Post subject: Left wing low |
On Mon, Jul 06, 2009 at 04:35:09PM -0500, wade jones wrote:
| Quote: | With Jay's weight at 850# ,does my target weight of 750# with a big engine
seem unattainable .
I suspct it would be hard. Remember, though, that my airplane is fully
loaded with lots of options, all of which add weight. I don't know how
feasible 750 is, but it's a good goal to aim for, and I'd take anything
under 800 (remember, even with long range tanks, that would give you two FAA
standard people and full tanks).
Posted: Mon Jul 06, 2009 2:09 pm Post subject: Left wing low |
On Monday 06 July 2009 16:54, Jay Maynard wrote:
> engine seem unattainable .
FAA standard people and full tanks).
Do you know any FAA standard people?
Do not archive.
Jim B Belcher
A&P/IA
Juan Vega Jr
Posted: Mon Jul 06, 2009 5:43 pm Post subject: Left wing low |
simple siolutions. when flying sol, fly with right wing full or burn fuerl in left tank first,
option two i have a tool bag, 20 lbs , in the front right foot well, when flying solo.
Juan
daveaustin2(at)primus.ca Guest
Posted: Mon Jul 06, 2009 6:46 pm Post subject: Left wing low |
If I balance the a/c with the aileron trim, I can do left and right turns by
shifting my body around. Do I have a heavy left wing?
Dave Austin 601HDS - 912
psm(at)att.net Guest
Posted: Mon Jul 06, 2009 7:47 pm Post subject: Left wing low |
Hi Wade,
I think 750 is a very reachable target empty weight for a CH601XL
depending on which engine you use. My plane weighs about 715 without
paint on the outside and lacking upholstery. It has a complete
Jabiru 3300 installed and a relatively complete electronic instrument
panel. If you use a heavier engine (Lyc/Cont.) Then perhaps 800
pounds might be a minimum target.
Paul
XL grounded
engine seem unattainable .I believe in keeping an aircraft as light
as possible .Build the plane close to the plans and if you plan to
add any extras parts ,toss the extra parts into the air and if they
return to earth they are too heavy for your plane . IMHO
Wade Jones South
Posted: Mon Jul 06, 2009 8:49 pm Post subject: Left wing low |
Dave and all-
From the list responses, it sounds like about 20 pounds in the right or
wrong place makes all the difference. Food for thought.
Bill
Posted: Tue Jul 07, 2009 3:41 am Post subject: Left wing low |
Thanks to all that responded to my post ,and Paul I like your weight .
Posted: Tue Jul 07, 2009 3:42 am Post subject: Left wing low |
paulrod36(at)msn.com Guest
Posted: Tue Jul 07, 2009 2:06 pm Post subject: Left wing low |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Yup, it's weight. Take any Cessna, fill both tanks to the rim, and go fly. Slightly left wing heavy, just a tad. Switch to the right tank for about an hour, and see what happens. Then, run on the left tank until it's almost dry. Interesting.
Paul R.
