Posted: Sun Jun 28, 2009 5:45 am Post subject: Splicing at D-subs. |
Sam Hoskins wrote:
| Quote: | I didn't hear back on this one, so here it is again:
Bob - do you have a comic book about splicing a second 20 AWG wire
into the
wire(s) heading into a D-sub connector? I looked through the articles at
http://www.aeroelectric.com/articles.html, but didn't find exactly what I
was trying to accomplish.
I have a 37 pin connector which is plugged into a device. I want to tap
into 5 of those wires to connect to another gizmo, and figured you already
have a razzle-dazzle way to accomplish it.
Thanks.
Sam Hoskins
Murphysboro, IL
www.samhoskins.blogspot.com <http://www.samhoskins.blogspot.com>
Hi Sam,
There's a comic book somewhere on the aeroelectric site showing how to
feed power *in* to multiple pins on a subD connector. You can just
reverse the technique to feed multiple outs. Bring one lead out of the
subD for a few inches. At that point, use an in-line (butt) splice with
your subD lead in one end and your 2 destination leads in the other.
Of course, this assumes that you have researched the signal quality
implications of splitting the signals.
bbradburry(at)bellsouth.n Guest
Posted: Sun Jun 28, 2009 5:46 am Post subject: Splicing at D-subs. |
Sam,
Is this what you were looking for?
http://www.aeroelectric.com/articles/pigtail/pigtail.html
Bill B
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins
Sent: Sunday, June 28, 2009 8:11 AM
To: AeroElectric-List(at)matronics.com
Subject: AeroElectric-List: Splicing at D-subs.
Bob - do you have a comic book about splicing a second 20 AWG wire into the
Thanks.
Sam Hoskins
Murphysboro, IL
www.samhoskins.blogspot.com | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
Sam
Posted: Sun Jun 28, 2009 6:15 am Post subject: Splicing at D-subs. |
No - I saw that one and it's for shields. I was looking for something similar for single conductor wire.
It's no big deal. I was just looking for one of Bob's elegant soultions.
Thanks.
Sam
On Sun, Jun 28, 2009 at 8:43 AM, Bill Bradburry <bbradburry(at)bellsouth.net (bbradburry(at)bellsouth.net)> wrote:
Sam,
Bill B
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Sam Hoskins
To: AeroElectric-List(at)matronics.com (AeroElectric-List(at)matronics.com)
Thanks.
Sam Hoskins
Murphysboro, IL
0 1 2
_________________ Sam Hoskins
Bob McC
Posted: Sun Jun 28, 2009 7:19 am Post subject: Splicing at D-subs. |
Sam;
Same process works. Just bring an inch or so of the wire from the pin out of the connector, splice on your two leads, heat shrink the assembly, just as shown in this “comic book” for shields and carry on. The second wire instead of looping back into the connector as shown here, simply goes to your second device. Either the solder technique or the solder sleeve method are neat and compact.
Bob McC
Sent: Sunday, June 28, 2009 10:03 AM
Subject: Re: AeroElectric-List: Splicing at D-subs.
Thanks.
Sam
Sam,
Bill B
Thanks.
Sam Hoskins
Murphysboro, IL
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-Listhttp://forums.matronics.com | | Quote: | | http://www.matronics.com/contribution |
| Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-Lista>http://forums.matronics.com | 01
23456789 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 1 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 2 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 3 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 4 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 5 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 6 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 7 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 8 | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 9 | Quote: | | http://forums.matronics.com | 0 | Quote: | | http://forums.matronics.com | 1
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sun Jun 28, 2009 7:28 am Post subject: Splicing at D-subs. |
Sam,
While I was looking I also found the one that Charlie is talking about here.
You just use 6" pigtails and crimp them together as Charlie describes.
Bill B
At 09:03 AM 6/28/2009, you wrote:
| Quote: | No - I saw that one and it's for shields. I was looking for something similar for single conductor wire.
Sorry for the long delay in responding . . . I
wish there were an "elegant" solution. Obviously
the D-Sub pin is limited to the insertion of but
a single 20AWG wire. The task is to tap
into a few conductors in a manner that does not
result in the wire bundle taking on that
"rabbit satisfied snake" appearance.
The lowest volume approach I can deduce is
to bare a short segment (1/4 to 3/8 inch)
of strands on wire to be tapped a couple
of inches from the end . . .
[img]cid:.0[/img]
Wrap the branch strands around the open gap, solder
and heat shrink. Then install the d-sub pin.
[img]cid:.1[/img]
You probably want to have the spice occur outside
the back-shell of the connector. Stagger their
positions so that they don't "bulk up" a lump
in one place on the harness.
Are you committed to 20AWG wire throughout?
22AWG does this hat-dance a little better.
( -Thomas Paine 1776- )
39.05 KB |
3508 Time(s) |
28.44 KB |
3508 Time(s) |
Posted: Sun Jun 28, 2009 7:33 am Post subject: Splicing at D-subs. |
to feed power *in* to multiple pins on a subD connector. You can just
the subD for a few inches. At that point, use an in-line (butt)
splice with your subD lead in one end and your 2 destination leads in
the other.
I think you're referring to the suggestion for
paralleling pins in a d-sub to achieve higher current
ratings for conductors in the connector. This technique
was used on a super-sonic target project I worked on
some years ago and is illustrated here:
http://www.aeroelectric.com/Pictures/Wiring_Technique/Paralleled_DSub_Pins.pdf
Sam is looking for a way to add a "wye-intersection"
into one of the connectors for carrying the same
current of to another location in the system. I've
illustrated a suggestion to this task in another
posting.
rjquillin
Posted: Sun Jun 28, 2009 8:00 am Post subject: Splicing at D-subs. |
As an additional data point, Garmin has a D-sub crimp and poke contact P/N 336-00023-00 for standard density connectors that accommodated an 18AWG wire.
Ron Q.
At 08:25 6/28/2009, you wrote:
[quote] Sorry for the long delay in responding . . . I
"rabbit satisfied snake" appearance.[b]
Posted: Sun Jun 28, 2009 8:10 am Post subject: Splicing at D-subs. |
At 10:56 AM 6/28/2009, you wrote:
| Quote: | As an additional data point, Garmin has a D-sub crimp and poke
I've heard of those but never had an opportunity
to use them. I'm sure there are other "nifty"
solutions out there. I'll try to get my hands on
some and look 'em over. I think I've heard of similar
products from yesteryear.
A larger diameter crimp/solder cup adapter would
be quite elegant. Unfortunately, these devices
seldom find their way into the Digikey or Radio Shack
catalogs at attractive prices. Shade tree technicians
are oft obliged to resort to processes adapted from
the materials at hand. An as one can see from a study
of the NASA handbook cited earlier, even the
Big Guys have adopted some techniques we Poor
Guys can duplicate.
Sam
Posted: Sun Jun 28, 2009 8:52 am Post subject: Splicing at D-subs. |
Thanks all - got it!. Now, off to the airport...
Sam
On Sun, Jun 28, 2009 at 10:25 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[img]cid:.0[/img]
[img]cid:.1[/img]
39.05 KB |
3505 Time(s) |
28.44 KB |
3505 Time(s) |
