carlisle
Joined: 20 Jun 2009 Posts: 72 Location: Sioux Falls, SD
Posted: Thu Jun 25, 2009 9:00 pm Post subject: HighWing Bungees |
Anyone used these? The material is quite a bit thicker than what you get from Kitfox. Whereas you're supposed to wrap the OEM cords around the tubes 6 times, measuring out the diameter of the HighWing cords across the available tubing length, looks like 4 loops will be about max.
kitfoxnick
Joined: 13 Apr 2008 Posts: 33 Location: Northern Maryland
Posted: Fri Jun 26, 2009 4:05 am Post subject: Re: HighWing Bungees |
I have a set of the high wings bungees. I was able to get the six wraps on, don't know if they're any different then mine. I bought mine back in the fall.
_________________ Nick Weiskopf
Norrisville, MD
kitfox !V-1200
Rotax 912ul |
dave
Posted: Fri Jun 26, 2009 4:58 am Post subject: Re: HighWing Bungees |
| carlisle wrote: | | Anyone used these? The material is quite a bit thicker than what you get from Kitfox. Whereas you're supposed to wrap the OEM cords around the tubes 6 times, measuring out the diameter of the HighWing cords across the available tubing length, looks like 4 loops will be about max. |
I make my own, cost about 1$ a foot for mil spec bungee.
Each bungee 5 feet long - 6 wraps no trouble and work great. I don't use those big nico crimps either. Mine have proven to be tough and never let go.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
wingman
Posted: Fri Jun 26, 2009 5:17 am Post subject: Re: HighWing Bungees |
Dave
What are you using instead of nicopress then?
Do you just tie a knot or do you have some other clamping device?
W
_________________ Kitfox IV 1200
Rotax 912 ULS
on full lotus floats |
dave
Posted: Fri Jun 26, 2009 5:32 am Post subject: Re: HighWing Bungees |
I use wire - I think it about 1/8 or 5/32 . You crimp them on the bungees .
Bull rings - what ever -- they grip and I tested them to 1500 lbs on ends
Look at any other bungee you buy -- they all the same
Tom Jones
Posted: Fri Jun 26, 2009 6:25 am Post subject: Re: HighWing Bungees |
Ever wonder what the color codes on the bungees means?
http://rgl.faa.gov/Regulatory_and_Guidance_Library%5CrgAdvisoryCircular.nsf/list/AC%2043.13-1B/$FILE/Chapter%2009-10.pdf
The color code is on page 9-2. I tried to copy and paste but the table came out scrambled.
Here's what it says.
From 43.13-b
"The cord is color coded to to indicate when it was manufactured and to determine the life of the cord. According to MIL-C-5651A, the color code for the year of manufacturer is repeated in cycles of 5 years. Table 9-1 shows the color of the code thread for each year and quarter year.
Years ending with:
0 or 5 Black,
1 or 6 green,
2 or 7 Red,
3 or 8 Blue,
4 or 9 Yellow,
Quarter:
1st - Red,
2nd - Blue,
3rd - green,
4th - yellow
The color coding is composed of threads interwoven in the cotton sheath that holds the strands of rubber cord together. Two spiral threads are used for the year coding and one thread is used for the quarter of the year sheath, e.g. yellow and blue would indicate that the cord was manufactured in 1994 during April, May, or June."
I guess that might be 1999 or 2004 now too.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
wingman
Posted: Fri Jun 26, 2009 7:11 am Post subject: Re: HighWing Bungees |
Dave
Can you explain a bit more or post a picture of how you do it.
W
Rotax 912 ULS
carlisle
Posted: Fri Jun 26, 2009 7:49 am Post subject: Re: HighWing Bungees |
So the colot tells us how old it is but does anyone know the service life of mil spec bungee cord?
Tom Jones
Posted: Fri Jun 26, 2009 10:54 am Post subject: Re: HighWing Bungees |
| Quote: | | So the colot tells us how old it is but does anyone know the service life of mil spec bungee cord? |
The kitfox gear should be tight up against the fuselage when two people are on board.
I have heard of Cubs going for 20 years or more.
From 43.13b:
"a. Old aircraft landing gear that employs
a rubber shock (bungee) cord for shock
absorption must be inspected for age, fraying
of the braided sheath, narrowing (necking) of
the cord, and wear at points of contact with the
structure and stretch. If the age of the shock
cord is near 5 years or more, it is advisable to
replace it with a new cord. A cord that shows
other defects should be replaced, regardless of
age."
Classic IV
Ellensburg, WA |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jun 26, 2009 6:00 pm Post subject: HighWing Bungees |
Sorry about the late response. The bungee cord is mil-spec Type I cord of 3/8" diameter. They are the dimension of the original Kitfdox bungees. As I recall, there was a time when Skyster sent out a thinner bungee but required more wraps.
When you wrap these, you will find that there will be overlap on at least one wrap.
The bungees are returnable if for any reason you are uncomfortable with them.
Lowell
--- On Thu, 6/25/09, carlisle <carlisle_99(at)yahoo.com> wrote:
Subject: HighWing Bungees
Date: Thursday, June 25, 2009, 10:01 PM
--> Kitfox-List message posted by: "carlisle" <carlisle_99(at)yahoo.com (carlisle_99(at)yahoo.com)>
http://forums.matronics.com/viewtopic.php?p=250104#250104
http://www.matronics.com/Naviga - MATRONICS WEB A href="http://www.matronics.com/contribution" target=_blank>http://www=======================
| [quote][b]
Float Flyr
Posted: Fri Jun 26, 2009 7:21 pm Post subject: HighWing Bungees |
Dave what do you use to fabricate the loops?
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Sat Jun 27, 2009 2:00 am Post subject: Re: HighWing Bungees |
I looked but have no pics of crimping the bungees.
Here is a finished one with tape on it . I was out of heat shrink at that time.
Dave
65.11 KB |
15018 Time(s) |
