R: VGs
Goto page Previous  1, 2
PostPosted: Thu Jun 25, 2009 2:09 pm    Post subject: R: VGs Reply with quote
> Zero ground roll is a splat
Jack B. Hart FF004
Jack H:
Zero ground roll is very attainable.
Did one in my Ultrastar and the MKIII. Both under same circumstances.
Wish John W was still here to verify my landing at Canon City, Colorado, in
2004, where I met John to do an attempt on Leadville, CO, highest airport in
the North American Continent. John landed at 1300 with 21 steady and gusts.
I landed at 1700 with 38 steady and gusts. I hovered to a touch down on a
gravel pad between the taxiway and the active. John was standing there to
catch the wing when I touched down. I'm sure we shared this with you all
after it happened. We were on our way to MV.
The landing I did at the Rock House this year, was done without flaps at 50
mph IAS. If I had known the turbulence was going to slack off the moment I
touched down, I could have used full flaps and done another hovering touch
down. If you saw John B's video clip of my landing, you can see how short
my ground roll was touching down at 50 mph IAS. I can assure you we had
some "real" wind that day, that continued for another couple days without
let up.
Last year, 2008, John W and I were grounded in Ontario, OR, with 45 mph
winds and gust over 50 mph for three days and nights without let up.
Normally, we set 25 mph steady as our red line for not flying.
Five or 10 mph in the speed range we land is not going to make a lot of
difference in surviving the landing or not.
slyck(at)frontiernet.net
PostPosted: Thu Jun 25, 2009 3:55 pm    Post subject: R: VGs Reply with quote
Just about the time I'm hitting the sod I prefer a higher stall
speed. -at least 1 MPH higher than the wind on my nose.
That is the time that VGs and flaps (unless you are "Queekdraw" and
retract them at exactly squat time) are no friend.
I flew my MKIII for two years before i even tried flaps. A pleasant
novelty that I have come to appreciate.
BB
> Jack B. Hart FF004
Jack H:
Colorado, in 2004, where I met John to do an attempt on Leadville,
CO, highest airport in the North American Continent. John landed
at 1300 with 21 steady and gusts. I landed at 1700 with 38 steady
and gusts. I hovered to a touch down on a gravel pad between the
taxiway and the active. John was standing there to catch the wing
when I touched down. I'm sure we shared this with you all after it
flaps at 50 mph IAS. If I had known the turbulence was going to
slack off the moment I touched down, I could have used full flaps
and done another hovering touch down. If you saw John B's video
clip of my landing, you can see how short my ground roll was
touching down at 50 mph IAS. I can assure you we had some "real"
wind that day, that continued for another couple days without let up.
mph winds and gust over 50 mph for three days and nights without
let up. Normally, we set 25 mph steady as our red line for not flying.
lot of difference in surviving the landing or not.
Possums
PostPosted: Thu Jun 25, 2009 4:44 pm    Post subject: R: VGs Reply with quote
At 06:00 PM 6/25/2009, you wrote:
Think I'll put 3 sets on ,then I can hover.
G.Aman mk-3c
OK .....we got 3 sets on this one - I think.
http://www.youtube.com/watch?v=b_EjsgLXdb8&feature=related
Possum
Dana
PostPosted: Thu Jun 25, 2009 5:00 pm    Post subject: R: VGs Reply with quote
At 03:35 PM 6/25/2009, JetPilot wrote:
Your understanding of this is wrong. You are misapplying a generality
that applies to slow flying airplanes where the approach speed is very
close to what its stall speed is. What you do not want is a gust causing
a loss of airspeed and stall in the airplane...
That's one concern, which I guess is a non issue if you fly your approach
at the same speed. However, if you _do_ use the same approach speed,
doesn't it take longer to bleed off enough speed to set it down
stalled? It's that period of time, close to the ground on a gusty day,
that concerns me.
Don't get me wrong, I find the concept intriguing... and I'd like to fly
the same plane with and without VG's... but not enough to go through the
hassle of mounting them on my plane, and having to remove them and clean up
adhesive residue if I don't want to keep them. As John says, I don't
personally feel the need for them. But if somebody has an UltraStar with
VG's that they're willing to let me fly, I'd love to try it.
-Dana
In America, anyone can become president. That's one of the risks you take.
PostPosted: Thu Jun 25, 2009 5:10 pm    Post subject: R: VGs Reply with quote
Possum:
Think this guy has VGs on his helmet, just like Buford.
I'd try the helmet VGs but afraid I might get a little light headed.
mkIII - Don't know how I did it without "them"!
jbhart(at)onlyinternet.ne
PostPosted: Thu Jun 25, 2009 7:11 pm    Post subject: R: VGs Reply with quote
John,
Say you touch down at 50 mph verses 40 mph, there is an kinetic energy
reduction of 35 percent for the same gross weight.
If one compares landing at 50 mph at 1000 pound gross weight to 40 mph with
500 pound gross weight, the kinetic energy reduction will be 68
percent.
Now compare the 50 mph at 1000 pound gross weight to 30 mph with 500 gross
weight (FireFly), the kinetic energy reduction will be 82 percent.
Given equal piloting abilities, who do you think is most likely to come out
of a botched up landing in the best shape?
Fly safe.
Jack B. Hart FF004
Winchester, IN
PostPosted: Thu Jun 25, 2009 7:23 pm    Post subject: R: VGs Reply with quote
out
Jack B. Hart FF004
I don't know, Jack.
Probably be pretty hard to find two pilots with the same piloting abilities.
smlplanet(at)msn.com
PostPosted: Fri Jun 26, 2009 12:42 am    Post subject: R: VGs Reply with quote
Like so many others here I have been very happy with my VG's and been flying over a year with them and installed with the carpet tape and no problems
by0ung(at)brigham.net
PostPosted: Fri Jun 26, 2009 7:19 am    Post subject: R: VGs Reply with quote
  G.Aman mk-3c
If you can hover with 3 sets…. Try 4…
The negative airspeed take off and landings must have some application.
Boyd Young
Do not archive.
PostPosted: Fri Jun 26, 2009 7:38 am    Post subject: R: VGs Reply with quote
Boyd:
That could be the reason some folks haul "ballast" in their Kolbs.
Boyd Young
PostPosted: Fri Jun 26, 2009 9:18 am    Post subject: R: VGs Reply with quote
John,
Few things make me chuckle for the entire time I am reading mail..
Still have a smile on my face.
Boyd Young
Boyd:
Boyd Young
zeprep251(at)aol.com
PostPosted: Fri Jun 26, 2009 11:44 am    Post subject: R: VGs Reply with quote
Yea,I can back it into the hanger before shutting it down.It does slow real good, why not try for reverse!
G.Aman
Possums
PostPosted: Sat Jun 27, 2009 6:05 pm    Post subject: R: VGs Reply with quote
I don't know......maybe it ain't the VGs that would make you a little
light headed?
At 09:08 PM 6/25/2009, you wrote:
Possum:
 Filesize:  56.34 KB
 Viewed:  6266 Time(s)
Possum
sky-king(at)inbox.com
PostPosted: Mon Jun 29, 2009 3:24 am    Post subject: R: VGs Reply with quote
Now that IS funny. What is he smokin??
[quote] --
Page 2 of 2
