aerosiam
Posted: Sat Feb 28, 2009 6:49 pm Post subject: Stiff rudders |
When our Allegro 2000 was delivered the rudders were stiff.
We found the problem to be the sleeve (the piece with the lubricating nipple in enclosed photo) jamming against the collar above. We machined it down a few thou and the rudders are smooth and light.
Paul
| | - The Matronics Allegro-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
42.41 KB |
8518 Time(s) |
ledson
Posted: Thu Jun 25, 2009 1:50 pm Post subject: Re: Stiff rudders |
I as well have stiff rudders. Can you tell me what you machined down? Was it the sleeve or the collar? And did you take the material off the top or the bottom?
Larry
aerosiam
Posted: Thu Jun 25, 2009 7:10 pm Post subject: Re: Stiff rudders |
Larry
With the tail tied down and the steering link rod removed, the nosewheel should rotate with just a slight drag from the bearings. On my aircraft (Dec 2006) the rudders were STIFF.
From memory, I machined down the top of the sleeve and slipped long bolts thru the rivet holes to check the clearance before rivetting the sleeve in place.
I am sure you know already but the nosewheel has 3 grease nipples.
Paul
