POH -pilot operating handbook
Davcoberly(at)wmconnect.c
PostPosted: Sun Jun 21, 2009 9:06 am    Post subject: POH -pilot operating handbook Reply with quote
After searching Archives and Internet I still don't know how to make my POH (for 601XL with a Corvair Engine) what has to be included what format I'm am totally at a loss on this any help or suggestions on this appreciated. David Coberly [quote][b]
bryanmmartin
PostPosted: Sun Jun 21, 2009 10:37 am    Post subject: POH -pilot operating handbook Reply with quote
There is no clear cut format required for a POH for an amateur built
airplane in the U.S. I found a POH somewhere on the web for a 601HD.
It was basically formatted the same as the POH for a Cessna 172. I
modified it for my 601XL with a Subaru engine. I have posted a copy of
the Word file Here:
http://home.comcast.net/~bryanmmartin/Documents/601XLPOH.doc
You can download this file and modify it for your airplane if you want.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
Bryan Martin
do not archive.
jaybannist(at)cs.com
David,
I made a POH for my airplane (601XL with a Corvair engine). It is a compilation of a lot of different POHs, but a WHOLE lot simpler than your typical certified airplane POH. Not a lot of CYA stuff. I have it on WordPerfect formatted to print landscape on 8 1/2 x 11 paper and cut down to around 5" x 7" to better fit in the airplane. There are 23 pages in all. It is not totally complete. Since I have not flown off the 40-hour test period, it doesn't have all the numbers filled in. I could make a pdf if you would like to review it.
The three view drawings and weight & balance pages are separate documents that I could also reproduce as pdfs.
Jay
pdn8r(at)yahoo.com
PostPosted: Sun Jun 21, 2009 11:11 am    Post subject: POH -pilot operating handbook Reply with quote
Also a couple samples at www.ch601.org
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
--- On Sun, 6/21/09, Davcoberly(at)wmconnect.com <Davcoberly(at)wmconnect.com> wrote:
From: Davcoberly(at)wmconnect.com <Davcoberly(at)wmconnect.com>
Subject: POH -pilot operating handbook
Date: Sunday, June 21, 2009, 1:05 PM
arget=_blank rel=nofollow>http://www.matronics.com/Navigator?Zenith-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
eldenej(at)yahoo.com
PostPosted: Sun Jun 21, 2009 2:07 pm    Post subject: POH -pilot operating handbook Reply with quote
Jay,
This is something that several of us would be delightedcto see
PostPosted: Sun Jun 21, 2009 2:22 pm    Post subject: POH -pilot operating handbook Reply with quote
Elden,
Here it is.? I've noticed that I have changed some of the checklists and not updated the POH.? That is something you will want to customize for your airplane anyway.? Use at your own discretion and all that stuff.? Let me know if you have any suggestions that could improve it or if you have any questions.
Jay
PostPosted: Sun Jun 21, 2009 3:38 pm    Post subject: POH -pilot operating handbook Reply with quote
Thank you, Jay; this is certainly suggestive.
Elden J.
--- On Mon, 6/22/09, jaybannist(at)cs.com <jaybannist(at)cs.com> wrote:
Subject: Re: POH -pilot operating handbook
Date: Monday, June 22, 2009, 6:19 AM
Elden,
Here it is.  I've noticed that I have changed some of the checklists and not updated the POH.  That is something you will want to customize for your airplane anyway.  Use at your own discretion and all that stuff.  Let me know if you have any suggestions that could improve it or if you have any questions.
Jay
Gig Giacona
PostPosted: Mon Jun 22, 2009 10:14 am    Post subject: Re: POH -pilot operating handbook Reply with quote
jaybannist(at)cs.com wrote:
Elden,
Jay
It isn't attached Jay.
W.R. "Gig" Giacona
601XL Under Construction
craig(at)craigandjean.com
PostPosted: Mon Jun 22, 2009 10:32 am    Post subject: POH -pilot operating handbook Reply with quote
It came through to me (as an actual attachment, not a link at the bottom of
the page). I'll send it to you direct.
-- Craig
PostPosted: Mon Jun 22, 2009 11:08 am    Post subject: POH -pilot operating handbook Reply with quote
Gig,
Give it another try.
Jay
POH5-2.pdf
 Filename:  POH5-2.pdf
 Filesize:  26.91 KB
 Downloaded:  832 Time(s)
