chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri Jun 19, 2009 1:56 pm Post subject: Stainless steel rivets |
Hi everyone
just checking off the last few remaining parts of my XL build and have a few Stainless steel rivets still left over.
Tried the search function but no success,I have them in the brake pedal hinges and the 2 in the elevator, but where else???
I would hate to leave them out..
Also checking the latest drawing updates on 6-B-7, the L angle between 6-B-7-1 top stiffener and the firewall said A5 I have A4.. Was this a structural change due cracking or loose rivets, I have A4 and will drill them out and change if that's what is supposed to be there
Chris..
Thruster87
Posted: Fri Jun 19, 2009 2:45 pm Post subject: Re: Stainless steel rivets |
I can only remember the use off SS rivets on the elevator horn strap[ I think ] but I used extras in places like the first or second from the ends on flap/elevaor/aileron hinges.wing skin ends,ailerons where you put the new mod angle and any other place I wanted extra strength .Make sure you use duralac to STOP CORROSION between SS and Al. Cheers
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Fri Jun 19, 2009 7:17 pm Post subject: Re: Stainless steel rivets |
If you saved your packing lists you should be able to add up the number of rivets used and the component they are used in. Usually there are a few extra rivets included with the kit so they may be surplus to your needs.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
