Homemade handheld antenna
aslsa.rng(at)gmail.com
PostPosted: Thu Jun 18, 2009 7:02 am    Post subject: Homemade handheld antenna Reply with quote
Bob, Just got through mounting my A-22 handheld in my trike. Now I'm wondering about a better antenna than the rubber ducky that it came with. Calculated length for a 1/4 wave centered on 127Mhz is 23.25". I'm thinking of nothing more than a piece of 1/16" SS welding wire shoved into a BNC connector. Any input by radio heads will be greatly appreciated.
Rick
Neal.George(at)hurlburt.a
PostPosted: Thu Jun 18, 2009 8:43 am    Post subject: Homemade handheld antenna Reply with quote
Rick -
That will work, but I'd suggest a piece of music wire rather than stainless.
Music wire will accept solder, so you can solder the wire to the BNC center
pin for a better electrical connection (then pot it with epoxy for
strain-relief). You'll also be happier if you put a tight 180-deg bend or
small loop in the end (also soldered) to mitigate scratches, snags and
gouged eyes.
Neal
Rick
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.04 KB
 Downloaded:  601 Time(s)
pwmac(at)sisna.com
PostPosted: Thu Jun 18, 2009 9:15 am    Post subject: Homemade handheld antenna Reply with quote
Hi Rick,
I just got finished with antenna tuning on all my vhf radios. Made
a big difference. Like you I use lengths for my common freq.
If you go to the Ham radio store they will sell you a VHF Whip
antenna for a hand held. It will make a huge difference. Mine is
~16.7" long. They have adapters for the different connectors as
required. I have not used the rubber ducky since I got the whip
antenna. Obviously the one I bought was not tuned for 127 but the swr
is just fine across a large range of freqs. Maybe they will have a 22
or 23' one?
BTW, Correct length for 127 is 22.1" for 1/4 wave per my calcs. Cut
yours 23" an then re-cut for best swr.
Paul
Rick
akfotoman
PostPosted: Thu Jun 18, 2009 9:55 am    Post subject: Homemade handheld antenna Reply with quote
I mounted an antennae on my( Antares ) trike using a 1/4 wave whip on
the wing keel tube and ran the coax down the vertical mast with a BNC
adapter on my VXA-700 and it works fine. It is a bit directional though
and the next time I will mount it in on the bottom of the pod and put at
least a six inch diameter metal disk around the antennae mount.
RS
Rob Stapleton, Photojournalist
Anchorage, AK
KL2AN
Skype:rob.stapleton.jr
Have cameras, will travel!
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
PostPosted: Thu Jun 18, 2009 7:04 pm    Post subject: Homemade handheld antenna Reply with quote
Rick
Rick, how are you sir! Long time no speak!
How well "exposed" is the rubber duck? Unless
your mounting situation masks the antenna with
nearby conductive structure, I don't think you
would benefit much from a more optimized antenna.
Your mission profile just doesn't call for getting
weather reports from an RCO that 100 miles out
on the horizon.
Have you encountered communications issues that
you thought might be improved by a better antenna?
( -Thomas Paine 1776- )
jindoguy(at)gmail.com
PostPosted: Thu Jun 18, 2009 8:07 pm    Post subject: Homemade handheld antenna Reply with quote
We've been missed by all the big storms again this spring and I count that a long way toward things being pretty good.I'm expanding my mission profile by taking the trike to its first towered airport for the chapter 980 Fly In at IDP this Saturday. Rather than having to call ahead, I added a power tap (21st century cigarette lighter receptacle) to the panel and a bracket from the forward mast to attach the A-22. The radio stands atop the panel and the rubber ducky, or any other antenna for that matter, stands vertically above the wind screen. There's no structure exactly parallel to the antenna, although the forward mast (a 1 1/4" aluminum tube) is about two inches from the antenna base and this distance gradually increases. As I was out in the hangar this evening my eyes fell on a disused telescoping antenna from an ELT. Its BNC connector mates right up to the radio and gives me a "tunable" length. What the heck, the price was certainly right.
Thanks to all who responded. Great help just a few keyboard clicks away.
Rick
On Thu, Jun 18, 2009 at 10:04 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Rick
 on the horizon.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
 Filesize:  134.18 KB
 Viewed:  8554 Time(s)
 Filesize:  124.43 KB
PostPosted: Fri Jun 19, 2009 2:07 am    Post subject: Homemade handheld antenna Reply with quote
Bob, My apologies for missing part of you question last night. My primary concern with the rubber ducky was its performance at low altitudes (200 to 500 feet) where I normally fly.
Rick
[quote] --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Rick
 on the horizon.
le, List Admin.
PostPosted: Fri Jun 19, 2009 5:57 am    Post subject: Homemade handheld antenna Reply with quote
Understand. Given that your radio horizon is so
close compared to most airplanes, I'm doubtful
that improving antenna efficiency over that
of the rubber-duck will yield any improved
"range". In fact, depending on how well the
radio noise is controlled from your ignition
system, you might want to keep the antenna as
far from the engine as practical.
It's an easy test. Rig a temporary antenna
in your remote location of choice. We could
do some extreme range testing with the two
antennas to see if the extra effort has a
return on investment.
