nico(at)cybersuperstore.c Guest
				 Posted: Wed Jun 17, 2009 4:36 pm    Post subject: If it an't "Boeing" I an't going,, |
				Anybody has any experience with this?
   Makes the  term "If It an't Boeing I an't going" have more meaning
 Subject: Air  France Accident: Smoking Gun Found
 A Brazilian Naval unit reportedly  found the complete vertical fin/rudder
 assembly of the doomed aircraft  floating some 30 miles from the main debris
 field. The search for the flight  recorders goes on, but given the failure
 history of the vertical fins on  A300-series aircraft, an analysis of its
 structure at the point of failure  will likely yield the primary cause factor
 in the breakup of the aircraft,  with the flight recorder data (if found)
 providing only secondary  contributing phenomena.
 The fin-failure-leading-to-breakup sequence is  strongly suggested in the
 attached (below) narrative report by George Larson,  Editor emeritus of
 Smithsonian Air & Space Magazine.
 It's  regrettable that these aircraft are permitted to continue in routine
 flight  operations with this known structural defect It appears that safety
 finishes  last within Airbus Industries, behind national pride and  economics.
 Hopefully, this accident will force the issue to be addressed,  requiring at
 a minimum restricted operations of selected platforms, and  grounding of some
 high-time aircraft until a re-engineered (strengthened)  vertical fin/rudder
 attachment structure can be  incorporated.
    This is an account of a discussion I  had recently with a maintenance
 professional who salvages airliner airframes  for a living. He has been at it
 for a while, dba BMI Salvage at Opa Locka  Airport in Florida. In the process
 of stripping parts, he sees things few  others are able to see.
 His observations confirm prior assessments of  Airbus structural deficiencies
 within our flight test and aero structures  communities by those who have
 seen the closely held reports of A3XX-series  vertical fin failures.
 His observations:
 "I  have scrapped  just about every type of transport aircraft from  A-310,
    A-320, B-747, 727, 737, 707, DC-3, 4, 6, 7, 8, 9,  10, MD-80, L-188,
 L1011  and various Martin, Convair and KC-97 aircraft.  Over a hundred of
 them.
 Airbus products are the flimsiest and most  poorly designed as far as
 airframe structure is concerned by an almost  obsession to utilize composite
 materials.
 I have one A310 vertical fin  on the premises from a demonstration I just
 performed.  It was pathetic  to see the composite structure shatter as it
 did, something a Boeing product  will not do.
 The vertical fin along with the composite hinges on rudder  and elevators is
 the worst example of structural use of composites I have  ever seen and I am
 not surprised by the current pictures of rescue crews  recovering the
 complete Vertical fin and rudder assembly at some distance  from the crash
 site.
 The Airbus line has a history of both multiple  rudder losses and a vertical
 fin and rudder separation from the airframe as  was the case in NY with AA.
 As an old non-radar equipped DC4 pilot  who flew through many a thunderstorm
 in Africa along the equator, I am quite  familiar with their ferocity.  It is
 not difficult to understand how  such a storm might have stressed an aircraft
 structure to failure at its  weakest point, and especially so in the
 presence of instrumentation  problems.
 I replied with this:
 "I'm watching very carefully the  orchestration of the inquiry by French
 officials and Airbus. I think I can  smell a concerted effort to steer
 discussion away from structural issues and  onto sensors, etc.  Now Air
 France, at the behest of their pilots'  union, is replacing all the air data
 sensors on the Airbus fleet, which  creates a distraction and shifts the
 media's focus away from the real  problem.
 It's difficult to delve into the structural issue without  wading into the
 Boeing vs. Airbus swamp, where any observation is instantly  tainted by its
 origin. Americans noting any Airbus structural issues (A380  early failure
 of wing in static test; loss of vertical surfaces in Canadian  fleet prior to
 AA A300, e.g.) will be attacked by the other side as partisan,  biased, etc.
 His follow-up:
 One gets a really unique insight  into structural issues when one has
 first-hand experience in the dismantling  process.
 I am an A&P, FEJ and an ATP with 7000 flight hours and I was  absolutely
 stunned, flabbergasted when I realized that the majority of  internal
 airframe structural supports on the A 310 which appear to be  aluminum are
 actually rolled composite material with aluminum rod ends. They  shattered.
 Three years ago we had a storm come through, with gusts up to  60-70 kts.,
 catching several A320s tied down on the line, out in the  open.
 The A320 elevators and rudder hinges whose actuators had  been
 removed shattered and the rudder and elevators came off.
 Upon  closer inspection I realized that not only were the rear spars
 composite but  so were the hinges.  While Boeing also uses composite
 material in its  airfoil structures, the actual attach fittings for the
 elevators, rudder,  vertical and horizontal stabilizers are all of machined
 aluminum."
    -----------------(end of  narrative)---------------
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
