Instrument panel
Goto page 1, 2  Next
annken100
PostPosted: Wed Jun 17, 2009 11:48 am    Post subject: Instrument panel Reply with quote
Ok Guys, while the Zenith list is rank with arguments about flutter and 601's raining from the sky, I decided to post some photos of my panel progress.
The vast majority of components are installed and about 25% of the wiring is done. As the last picture shows, I have a bit more wiring to do!
Ken Pavlou
 Filesize:  823.2 KB
 Viewed:  27335 Time(s)
 Filesize:  945.95 KB
Instrument Panel
 Filesize:  832.62 KB
601 XL / Corvair
lwinger
PostPosted: Wed Jun 17, 2009 12:10 pm    Post subject: Instrument panel Reply with quote
Nicely done.  How did you label your panel?
Larry Winger
On Wed, Jun 17, 2009 at 12:48 PM, annken100 <annken100(at)aol.com (annken100(at)aol.com)> wrote:
[quote]--> Zenith-List message posted by: "annken100" <annken100(at)aol.com (annken100(at)aol.com)>
Ken Pavlou
601 XL / Corvair
http://forums.matronics.com/viewtopic.php?p=248756#248756
http://forums.matronics.com//files/img_00591_216.jpg
http://forums.matronics.com//files/img_00561_134.jpg
http://forums.matronics.com//files/img_00581_137.jpg
http:=====
http://forums.mle, List Admin.
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
jaybannist(at)cs.com
Ken,
Wow, looks like a real Pro job !! Love it !!
Jay
Ken Pavlou
601 XL / Corvair
Email message sent from CompuServe - visit us today at http://www.cs.com
pramodkotwal(at)yahoo.com
Ken,
Either you are a masochist or just love to see cockfights.
You might just have started a flaming war on the reliability of the glass panel and how your panel betrays the spirit of the whole amateur built plane culture, an insult to the (cheapskate) Corvair movement.
Let us stand behind the mud barrier and raise our glasses of a martini to the fighting fools,
Pramod
--- On Wed, 6/17/09, annken100 <annken100(at)aol.com> wrote:
Subject: Instrument panel
Date: Wednesday, June 17, 2009, 3:48 PM
"annken100" <annken100(at)aol.com>
Ken Pavlou
601 XL / Corvair
http://forums.matronics.com/viewtopic.php?p 48756#248756
Email Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
craig(at)craigandjean.com
PostPosted: Wed Jun 17, 2009 12:12 pm    Post subject: Instrument panel Reply with quote
Very comprehensive. I assume the "serial output" selector switch is for
monitoring the serial output from five instruments. Is that a 9 pin DSUB
connector next to the switch? The first (CCW) position looks like it is
labeled "Off". Just a precaution so the connector can't kill one of the data
streams?
Don't you need a USB connector to update the firmware on the Dynons? Since
the clips indicate you are making your forward skin removable I suppose you
will go in that way.
-- Craig
PostPosted: Wed Jun 17, 2009 12:24 pm    Post subject: Instrument panel Reply with quote
He spent the money he saved on the engine on some nice glass. Smile
And depending on the Dynon models he installed he probably has glass backing
up glass.
Pramod: given his location and yours I bet you nitrided his crank.
-- Craig
cookwithgas
PostPosted: Wed Jun 17, 2009 12:35 pm    Post subject: Re: Instrument panel Reply with quote
Beautiful Ken. Keep building a little each day. I hope to meet you at a fly-in some day.
Scott in Texas
601XL/Corvair
136 hours
Iberplanes
PostPosted: Wed Jun 17, 2009 12:39 pm    Post subject: Instrument panel Reply with quote
Hello Ken,
nice panel with AP74 and HS34, I guess the AP installation was an snap, right? BTW, how did you do the label? It looks great.
Bye,
Alberto Martin
www.iberplanes.es
Igualada - Barcelona - Spain
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: (at) home
Engine: Jabiru 3300
Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
carlossa52(at)gmail.com
PostPosted: Wed Jun 17, 2009 12:42 pm    Post subject: Instrument panel Reply with quote
Very, very nice !
I too am interested on how you labeled the panel, looks like you had it professionally done?
Carlos
CH601-HD (a bunch of parts conspiring to become an airplane)
2009/6/17 annken100 <annken100(at)aol.com (annken100(at)aol.com)>
[quote] --> Zenith-List message posted by: "annken100" <annken100(at)aol.com (annken100(at)aol.com)>
Ken Pavlou
601 XL / Corvair
annken100
PostPosted: Wed Jun 17, 2009 12:50 pm    Post subject: Re: Instrument panel Reply with quote
Larry, I did the labels using a system called decalpro FX. Here is the link: http://www.pulsarprofx.com/ I highly recommend it. The system does have a steep learning curve, but the results are worth it. Also, the guy who created the system is very helpful over the phone.
Craig, you are correct, that is a 9 pin connector next to the serial switch. I made a serial cable that goes from the panel to my laptop which has a usb-serial converter. I simply connect the laptop and select which unit I want to update. I can also use it to download the ems and efis data. The main instrument is a Dynon D180 and the backup is a D100. The D100 normally boots up in to the EMS screen. The D180 boots up to a full EFIS screen. The rest of the equipment are a Dynon HS34 and AP74 and a Garmin SL30 Nav/Com and GTX327 transponder. The GPS is an Avmap EKP IV and the intercom is a flightcom 401.
Thank you all for the kind words.
Ken Pavlou
601 XL / Corvair
Gig Giacona
PostPosted: Wed Jun 17, 2009 12:53 pm    Post subject: Re: Instrument panel Reply with quote
How dare you interrupt the fighting with this crap.....
Just kidding of course. Fine looking panel. I especially like the labels.
A couple of questions.
1. Where did you get the little switch guards?
2. Why the HS 34 if you have an SL30? I thought the Dynon could deal with the SL30 data without the HS34 and the AP 74 gives you the knobs and voice alerts?
W.R. "Gig" Giacona
601XL Under Construction
PostPosted: Wed Jun 17, 2009 1:06 pm    Post subject: Instrument panel Reply with quote
One source of switch guards (two styles). Look on the right side:
http://periheliondesign.com/
-- Craig
annken100
PostPosted: Wed Jun 17, 2009 1:49 pm    Post subject: Re: Instrument panel Reply with quote
Alberto, I haven't installed the autopilot servos yet. I'll let you know how that goes.
Gig, the switch guards are from http://www.periheliondesign.com They also sell a neat domino-sized overvoltage device which works good.
You are correct that the D180 will handle the Sl-30 without the HS34. There are two reasons why I purchased the HS34:
1.) More buttons and knobs! Laughing
2.) I hate assymetry, I thought the D180 looked better with the HS34 on one side and a AP74 on the other.
Just kidding, I chose to install the HS34 because I'm connecting both the SL30 and the GPS to the Dynons. The HS34 allows me to keep the D180 serial line free for updates and data streaming. Also, I needed more GP inputs for things like my trim and flap indicators. Lastly, I can change bearing sources and the obs with my left hand without letting go of the center Y-stick.
See my previous response for the panel labels.
Ken Pavlou
601 XL / Corvair
Juan Vega Jr
PostPosted: Wed Jun 17, 2009 6:24 pm    Post subject: Instrument panel Reply with quote
OOOOOooooh, I Like!!
JUan
rogers_pritchard(at)yahoo
PostPosted: Thu Jun 18, 2009 10:12 am    Post subject: Instrument panel Reply with quote
Ken,
It's beautiful. Ben and I are jealous.
We have the OVP and the fuel pressure gage in,thank you for the help.
Roger
Ken Pavlou
601 XL / Corvair
y Browse, Chat, FAQ,
="http://www.matronics.com/Navigator?Zenith-List" target="_blank">http:=====
arget=_blank rel=nofollow>http://www.matronics.com/Navigator?Zenith-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
Thruster87
PostPosted: Thu Jun 18, 2009 8:53 pm    Post subject: Re: Instrument panel Reply with quote
How do you find getting in and out with the throttle quadrant where it is??? Nice panel. Cheers
annken100
PostPosted: Thu Jun 18, 2009 9:48 pm    Post subject: Re: Instrument panel Reply with quote
The quadrant is off to the side enough that it doesn't get in the way of me getting in and out.
Ken
601 XL / Corvair
PostPosted: Mon Jun 22, 2009 8:17 am    Post subject: Instrument panel Reply with quote
Ken, was the $90 "starter" kit from pulsarprofx.com sufficient to do your
whole panel or did you have to order more supplies?
-- Craig
annken100
PostPosted: Mon Jun 22, 2009 9:00 am    Post subject: Re: Instrument panel Reply with quote
Craig,
I used all the white film during the learning process. I ended up ordering some more white. Now that I'm more proficient with the process I could do the whole panel with just the starter pack.
Ken
601 XL / Corvair
PostPosted: Mon Jun 22, 2009 9:22 am    Post subject: Instrument panel Reply with quote
Thanks! I'll be using the black on my white panel. So I think I could use
one of the other colors for practice and have all the black left for the
real panel.
Any other tips that you learned or is it just a matter of getting a feel for
it?
-- Craig
Goto page 1, 2  Next
Page 1 of 2
