Advice about gas tanks in 601.
ggower_99(at)yahoo.com
PostPosted: Tue Jun 16, 2009 4:18 pm    Post subject: Advice about gas tanks in 601. Reply with quote
Hello 601 builders,
I am ready to install the fuel senders in the 601 tanks... Just I am holding a little, doing some thinking, about the chance of installing the senders on the top of the tank...
Two questions?
Someone had installed the senders on top of the tank in the 601 XL? Have photos?.
From some of you that have flying airplanes and that have the senders on the side. The sealing is satisfactory?
I will hate to need to open the leading edge skin(s) to replace the sender or the gaskets... I think there is no way to reach it throught the 3 front ribs holes, to replace it...
Thank you all in advance for the comments.
Saludos
Gary Gower.
701 912S
Building 601 XL Jab 3300
Fuselage almost ready, tail surfaces ready, working on wings.
johnd
PostPosted: Tue Jun 16, 2009 4:37 pm    Post subject: Advice about gas tanks in 601. Reply with quote
Hi Gary,
I installed my senders on the side per the plans. I first installed them with just the gasket and paper washers for the screws and they leaked around the screw holes. I removed them thu the lightening hole and the maintenance opening on the bottom of the wing and and reinstalled them with fuel lube sealant on the gasket and screws and haven't had a leak so far. I've got about 15 hours with no leaks...
Good luck,
John Davis
N601JD
Gary Gower wrote: [quote]
Hello 601 builders,
Two questions?
Saludos
Gary Gower.
701 912S
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
ashleyw(at)gvtc.com
PostPosted: Tue Jun 16, 2009 4:41 pm    Post subject: Advice about gas tanks in 601. Reply with quote
Gary,
I have the senders in the side per plans. I have had to reseal one of the screws a couple times.
The paper washers that came with the sender appear to work if installed once. I took a sender out and the washers were trashed. My first attempt to seal the screws with EZ lube lasted about 6 months. I now have some Permatex gasket maker on the screw and it appears to be holding.
It is actually very easy to get the sender in and out of the wing thru the rib holes.
Floyd Wilkes
601XL
cookwithgas
PostPosted: Tue Jun 16, 2009 4:44 pm    Post subject: Re: Advice about gas tanks in 601. Reply with quote
Gary:
Here is what I did:
http://www.cooknwithgas.com/5_30_04_Wingholes.JPG
http://www.cooknwithgas.com/3_04_03_Sender2.JPG
http://www.cooknwithgas.com/3_04_03_Sender.JPG
http://www.cooknwithgas.com/3_5_03_SenderParts.JPG
http://www.cooknwithgas.com/3_5_04_WingTank.JPG
http://www.cooknwithgas.com/3_7_04_Access.JPG
Scott Laughlin
601XL/Corvair
136 Hours
Zbagged 12 times
larry(at)macsmachine.com
PostPosted: Tue Jun 16, 2009 5:12 pm    Post subject: Advice about gas tanks in 601. Reply with quote
Hi Gary,
I have side mounted fuel senders in my tanks and the gaskets are very
sound as provided. Top mounting is over kill and problematic for the
leading edge tanks
and header. I'd recommend you go with the side mount. I can see my tank
sender, access it and remove it from the inboard rib nearest it without
too much difficulty
but don't think that will ever happen. Take time to install it
correctly and you'll not have any problems.
http://www.macsmachine.com/images/leadedgetanks/full/sender-calibration-setup.gif
http://www.macsmachine.com/images/leadedgetanks/full/tankwired.gif
http://www.macsmachine.com/images/headertank/full/vdoinstall.gif
http://www.macsmachine.com/images/wing/inspectionpanels/full/inspectpnl.jpg
http://www.macsmachine.com/images/completion/full/airmap500mt2.gif
Fuel gages are arranged left tank, center tank and right tank on the top
right side.
The three gages on my panel read fuel levels very accurately with these
side mount positions.
Gary Gower wrote:
Hello 601 builders,
Two questions?
Have photos?.
Saludos
Gary Gower.
701 912S
psm(at)att.net
PostPosted: Tue Jun 16, 2009 5:52 pm    Post subject: Advice about gas tanks in 601. Reply with quote
Hi Gary,
I have senders on tank tops and photos (someplace . . .) I can dig
them up if you want.
One of my neighbors bought a Zodiac XL and had a leak around the
senders which were on top of the tank. He strongly recommended to me
that I install inspection plates over the senders. I didn't do it
yet because my tanks were already closed into the wings, but you
might consider such a feature.
If you still want the pictures, please let me know. I am sure I have
them someplace in the pile of 1500 or so pics I have.
Best regards,
Paul
At 05:16 PM 6/16/2009, you wrote:
Hello 601 builders,
Two questions?
Have photos?.
Saludos
Gary Gower
chuck960
PostPosted: Tue Jun 16, 2009 6:21 pm    Post subject: Re: Advice about gas tanks in 601. Reply with quote
In my opinion the sender supplied with the kit needs some help. Get rid of the backing ring. It will only grab a very small amount of the tank skin.
Here are some photos. Also McMaster Carr has some very very good sealing washers for #10 screws. You will not need any liquid sealer.
 Filesize:  673.2 KB
 Viewed:  11604 Time(s)
 Filesize:  670.78 KB
 Filesize:  673.42 KB
 Filesize:  680.8 KB
 Filesize:  679.26 KB
bryanmmartin
PostPosted: Tue Jun 16, 2009 6:44 pm    Post subject: Advice about gas tanks in 601. Reply with quote
I have mine in the top of the tanks as per the early plans I have.
They have changed the senders since then. I had to modify the senders
some to get a low enough profile to fit on top. I also installed
access panels over the senders. I think I have pictures but I don'
have them handy right now.
On Jun 16, 2009, at 8:16 PM, Gary Gower wrote:
Hello 601 builders,
Two questions?
Have photos?.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
Bryan Martin
do not archive.
leo.gates
PostPosted: Tue Jun 16, 2009 6:45 pm    Post subject: Advice about gas tanks in 601. Reply with quote
Gary,
Mine is a HDS, but with leading edge tanks with sender on the side.
Sealed mine with permatex four years ago, no leak.
Leo Gates
CH601HDS TDO, Rotax 912UL
Gary Gower wrote:
Hello 601 builders,
Two questions?
Have photos?.
Saludos
Gary Gower.
701 912S
steerr(at)bellsouth.net
PostPosted: Wed Jun 17, 2009 4:57 am    Post subject: Advice about gas tanks in 601. Reply with quote
Hi, Gary. I installed mine in the side, per the plans. No leaks so
far, but I did have to replace one of the senders that turned out to be
bad. Didn't discover it until the wiring was in place. It was no
problem at all to replace it.
Gary Gower wrote:
Hello 601 builders,
Two questions?
Have photos?.
Saludos
Gary Gower.
701 912S
Checked by AVG - www.avg.com
z601(at)anemicaardvark.co
PostPosted: Wed Jun 17, 2009 5:48 am    Post subject: Advice about gas tanks in 601. Reply with quote
On Tuesday 16 June 2009 19:16, Gary Gower wrote:
Hello 601 builders,
Two questions?
photos?.
Gary, I haven't tried this, but my immediate thought is that it places the
assembly and the electrical connections in an area where there's very little
room, and where it will be harder to service, should this become necessary
later.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
PostPosted: Wed Jun 17, 2009 6:04 am    Post subject: Advice about gas tanks in 601. Reply with quote
On Tuesday 16 June 2009 19:31, John Davis wrote:
Hi Gary,
After sealing the sender with sealant as you did, I put a soapy mixture around
the sender, and pressurized the tank slightly.
On one tank, I got bubbles around one screw, and had to do some additional
sealing. On the other, no bubbles appeared.
I feel reasonably confident that when I finally get the aircraft finished I
won't have fuel leaks. Or at least, not there.
About 20 years ago, I rebuilt a Tripacer, and blindly thought with sealant and
snugging the screws to their appropriate level of tightness, thinking I
wouldn't have leaks. I was wrong.
You can check on my aircraft construction
progress at: http://www.mykitlog.com/santaigo
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Retired Aerospace Technical Manager
Do not archive.
Jim B Belcher
A&P/IA
PostPosted: Sun Jun 21, 2009 6:51 pm    Post subject: Advice about gas tanks in 601. Reply with quote
Hello all my friends...
I really appreciate all the answers in the list and also off list I recieved about the senders instalation.
I didnt answer earlyer because I was thinking a lot about all your answers...
This is something great about this list... Like the good old times.
Given my experience building the 701 as close as possible to the plans, and the great results 240 flying hours later...  and counting.
I am going with the side senders, as the plans, but will take the advice from you all in account looking for a good sealed instalation. Not forgiving that might need to change a sender (electric parts are never built fail proof) in a future.
Thank you all once more.
Saludos
Gary Gower.
Flying from Chapala, Mexico.
Keep building and flying, Please!
