pj.ladd(at)btinternet.com Guest
Posted: Mon Jun 15, 2009 12:55 am Post subject: ASI |
Having wiped off the pitot tube twice from my Xtra by getting into long grass etc I replaced it on top of the nose cone. Just far enough back so that it wouldn`t get wiped off by someone walking by.
Flew last night and found the ASI reading about 10/15mph slow. 2800 rpm produced only about 50 mph instead of around 65. Did a couple of stalls at 2000ft to get some sort of idea and landed OK by guess and by God with the ASI hovering just below 30mph.
Anyone put their pitots in a different position who can guide me to a good spot for refitting?
Pat
vince(at)devonwindmills.c Guest
Posted: Mon Jun 15, 2009 1:13 am Post subject: ASI |
Try halfway along the wing strut, sticking forward as much as you dar
Vince Hallam
Devon Windmill Holidays
Woodlands, Walls Hill Road
Torquay, Devon, TQ1 3LZ
Tel: 01803 316191 Mob: 07941 313141
www.devonwindmills.co.uk
Posted: Mon Jun 15, 2009 1:25 am Post subject: ASI |
Try halfway along the wing strut>>
Thanks Vince. A quick reply like that had to be aBrit. There is no one else about at this time in the morning.
Is that just a suggestion or have you tried it? Strikes me as a bit vulnerable unless you get close to the wing and then there is the disturbed air. Also the derigging problem, not that I derig mine but someone will, one day
Pat
Posted: Mon Jun 15, 2009 1:52 am Post subject: ASI |
PJ,
Give me a ring , I`ll discuss. Im home now
Vince Hallam
Posted: Mon Jun 15, 2009 3:12 am Post subject: ASI |
Pat,
Here is my solution.
http://www.jackbhart.com/firefly/firefly36.html
Jack B. Hart FF004
Winchester, In
spot for refitting?
Posted: Mon Jun 15, 2009 4:23 am Post subject: ASI |
My pitot/static system works great mounted to the bottom of the right lift strut approximately 6 to 12 inches from the outboard end.
[quote] Is that just a suggestion or have you tried it? Strikes me as a bit vulnerable unless you get close to the wing and then there is the disturbed air. Also the derigging problem, not that I derig mine but someone will, one day
Pat
_________________ John Hauck
Titus, Alabama |
Posted: Mon Jun 15, 2009 5:20 am Post subject: ASI |
Hey PJ,
I lost your phone no,Call again when you`re free.
Vince Hallam
robcannon
Joined: 22 Jun 2008 Posts: 39 Location: British Columbia
Posted: Mon Jun 15, 2009 7:29 am Post subject: Re: ASI |
I have my pitot on top of the nose and it is accurate (gps checked). If I was doing it again I would try it an inch or so further back as it sometimes gets bent when it's in my crowded hanger.
cheers, Rob Cannon
631.82 KB |
19077 Time(s) |
robcannon
Posted: Mon Jun 15, 2009 7:31 am Post subject: Re: ASI |
Can anyone tell me how to shrink photos when I attach them to emails. I use a canon powershot A75.
Rob Cannon
George Alexander
Posted: Mon Jun 15, 2009 9:40 am Post subject: ASI |
Rob:
If you are using Windows XP, go to:
http://www.microsoft.com/windowsxp/using/digitalphotography/learnmore/tips/e
schelman2.mspx.
Easy, free, tool for doing what you want. Adjusts the size, but leaves the
original intact (in case you want decent quality prints).
Fun, Safe Flying!
George Alexander
http://gtalexander.home.att.net
DO NOT ARCHIVE
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
herbgh(at)nctc.com Guest
Posted: Mon Jun 15, 2009 12:12 pm Post subject: ASI |
Free download called...irfanview....very easy to use...lots of choices ...Herb
http://www.irfanview.com/
At 12:39 PM 6/15/2009, you wrote:
<gtalexander(at)att.net>
Rob:
schelman2.mspx.
Fun, Safe Flying!
George Alexander
DO NOT ARCHIVE
Posted: Tue Jun 16, 2009 1:55 am Post subject: ASI |
John,
thanks for the gen.
I assume that you just have a couple of straight tubes projecting from the front of the strut.
Questions. How long have you made them.?
Have you run the plastic tube internally or just run it up the strut?
How have you fixed the assembly to the strut?
My thought is to bend the metal tubes through 90 degrees with the leg attached to the plastic tube bound to the strut with a couple of cable ties.
Pat
aslsa.rng(at)gmail.com Guest
Posted: Tue Jun 16, 2009 3:08 am Post subject: ASI |
Pat, There's another option you might wish to try that I use on my Mk III and my trike. Both a short section of stiff vinyl tube to connect the short pitot sticking out of the fuselage to an extension that gets it out about 8" into the airstream. If I or someone else hits it it just bends out of the way and then comes back into line when the offending party, usually some cow at a Fly In, removes her haunch. Cheap to try and probably saves you from having to call out the engineering battalion.
Rick
On Tue, Jun 16, 2009 at 4:54 AM, pj.ladd <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)> wrote:
[quote] John,
thanks for the gen.
Pat
tp://forums.matronics.com
Posted: Tue Jun 16, 2009 5:41 am Post subject: ASI |
Actually, I found a PT-17 pitot/static system when I was building my mkIII, and installed it to the strut using 4 pop rivets.
Ran the tubing through the lift strut.
It is a single tube aproximately 5" long that incorporates both pitot and static pressure systems.
Pat
Titus, Alabama |
Posted: Wed Jun 17, 2009 2:40 am Post subject: ASI |
It is a single tube aproximately 5" long that incorporates both pitot and static pressure systems.>.
Thanks John, that sounds pretty neat with only a single tube.I have never heard of that. Does that mean it measures pitot pressure only and you use cockpit static?.
Incidentally I saw a couple of PT 17`s at a local airshow recently. Not many about over here.
Pat
Posted: Wed Jun 17, 2009 2:46 am Post subject: ASI |
Cheap to try and probably saves you from having to call out the engineering battalion.>>
Thanks Rick. A neat solution and may put the end of the pitot into clear air.
Cheers
Pat
Posted: Wed Jun 17, 2009 4:58 am Post subject: ASI |
Patrick:
I say again, the single tube incorporates both pitot and static pressure systems. Too complicated for me to try and explain how it is designed before I have my first cup of coffee.
Pat
Titus, Alabama |
Posted: Wed Jun 17, 2009 5:38 am Post subject: ASI |
Pat- Aircraft Spruce lists a couple of the single tube designs, plus a couple of the double tube designs. Listed under "Instruments". Page 394 in my catalog. I don't know which one John has. They list one for under $20 (US), and go up to almost $180.
Bill Sullivan
Windsor Locks, Ct.
Posted: Wed Jun 17, 2009 5:39 am Post subject: ASI |
Perhaps this drawing would help.
Rick
On Wed, Jun 17, 2009 at 7:57 AM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
| Quote: | Patrick:
Pat
11.83 KB |
19022 Time(s) |
Posted: Wed Jun 17, 2009 6:18 am Post subject: ASI |
Thanks, Rick.
The single tube pitot/static system at the bottom of the file is a good example.
My system was manufactured by Kollsman Instruments during WWII. It was still in its original wrapping with cosmoline. Has a Federal Stock Number on it. Think I got it from WagAero for about $12.00. Made of nickle plated brass.
[quote]Perhaps this drawing would help.
Rick
Titus, Alabama |
