dvanlanen
Posted: Thu Jun 11, 2009 2:38 pm Post subject: 601XL - Lower Elevator Cable Rear Fairlead Question |
I need some advice on installation of the lower elevator cable rear fairlead (6B24-1) to the front H.T. frame (6B1-1). Construction Guide 6-B-1 p. 5 instructs to install the fairing, then trace the outline of the lightening hole in the front H.T. frame onto the fairing and cut it out on this line. If I do this, it looks like the fairing will not provide a “stand-off” from the top of the lightening hole, which would result in the cable potentially rubbing against the top of the lightening hole. There are no other details provided in the plans regarding positioning of the fairlead. Do I need to provide some stand-off on this fairing, and if so, how much?
Dave Van Lanen
Madison, WI
601XL – tail done, starting on fuselage [quote][b]
Larry Webber
Joined: 05 Jun 2008 Posts: 63 Location: West Kingston Rhode Island
Posted: Thu Jun 11, 2009 3:38 pm Post subject: 601XL - Lower Elevator Cable Rear Fairlead Question |
I ad the same problem but with a little JOGGLEING it doesnt rub
the nylon is very tenacious and will not wear rapidly i just dropped
down and added 1/4" below the lioghtening hole
keep on building
Larry Webber601xl/corvair chugger
To: zenith-list(at)matronics.com; zenith601-list(at)matronics.com
Subject: 601XL - Lower Elevator Cable Rear Fairlead Question
Date: Thu C 11 Jun 2009 17:32:20 -0500
I need some advice on installation of the lower elevator cable rear fairlead (6B24-1) to the front H.T. frame (6B1-1). Construction Guide 6-B-1 p. 5 instructs to install the fairing C then trace the outline of the lightening hole in the front H.T. frame onto the fairing and cut it out on this line. If I do this C it looks like the fairing will not provide a “stand-off” from the top of the lightening hole C which would result in the cable potentially rubbing against the top of the lightening hole. There are no other details provided in the plans regarding positioning of the fairlead. Do I need to provide some stand-off on this fairing C and if so C how much?
Thanks C
Dave Van Lanen
Madison C WI
601XL – tail done C starting on fuselage | Quote: |
| Quote: | http://www.matronics.com/Navigator?Zenith-List
ronics.com
ww.matronics.com/contribution
| Windows Live™ SkyDrive™: Get 25 GB of free online storage. Get it on your BlackBerry or iPhone. [quote][b]
_________________ how do you eat an elephant ? one bite at a time |
jaybannist(at)cs.com Guest
Posted: Thu Jun 11, 2009 3:43 pm Post subject: 601XL - Lower Elevator Cable Rear Fairlead Question |
Dave,
You only need to mount that faring so that the curved edge is about 1/8" inside the edge of the lightening hold. The purpose is simply to have the cable rub against the fairing and not the metal of the lightening hole flange.
Jay Bannister
