Wiring for the jab 3300
mosquito56
PostPosted: Wed Jun 10, 2009 11:05 am    Post subject: Wiring for the jab 3300 Reply with quote
I am trying to find explanations on the sensors for the 3300. Specifically the electrical characteristics?
I am trying to wire them up to a microcontroller and some adcs.
Rpm--- will the hall effect work on 5v dc?
Oil pressure and temp--- are they just like the gas level resistor?
Don
Don Merritt- Laredo, Tx
matronics(at)rtist.nl
PostPosted: Wed Jun 10, 2009 11:50 am    Post subject: Wiring for the jab 3300 Reply with quote
Many hall sensors can be operated on 5V. Here's an example of a gear-tooth
hall sensor datasheet: http://www.hallsensors.de/CYGTS101DC.pdf
As you can see, the sensor requires a pull-up resistor (probably open
collector). Many microcontrollers (eg. Atmel AVR) can be configured to
activate a suitable internal pull-up.
The pressure and temp sensors are variable resistors. If you add a known
pull-up to +5V then you should be able to get a level that an embedded ADC
can process.
Engine environments are truely harsh from an electrical design point of
view. Make sure you design plenty input protection (big spikes, load dumps,
overvoltage, reverse connections, short circuits) on your microcontroller,
or be prepared to see flakey results and blown parts. If at all possible,
avoid direct connections from the microcontroller to the outside world. Use
buffers on input and output. And when you start programming, be defensive.
Check all code paths and all variables for out-of-range values, and provide
some sort of visual "Lost my mind" indication. A watchdog timer can be
helpful too..
Rob
craig(at)craigandjean.com
PostPosted: Wed Jun 10, 2009 12:37 pm    Post subject: Wiring for the jab 3300 Reply with quote
The RPM Hall effect sensor is not supplied with the engine. Most people with
electronic gauges or EFIS tie into the AC alternator field windings and look
for 6 pulses per revolution (3300).
Oil temp is a NTC resistive device - negative temperature coefficient. As
the temperature goes up the resistance goes down. The pressure sender is a
VDO part where a mechanical slider moves over a resistive element (that is
why they wear out). Look on the VDO site.
-- Craig
PostPosted: Wed Jun 10, 2009 1:13 pm    Post subject: Wiring for the jab 3300 Reply with quote
And to add the caveat here, tying your microcontroller to the AC alternator
is lethal to the chip without proper precaution. If you really want to do
that, take a look at the signal with a scope to see what hostile signal
comes from the alternator.. Set scope for 20V per division...
Rob
mosquito56
PostPosted: Wed Jun 10, 2009 7:50 pm    Post subject: Re: Wiring for the jab 3300 Reply with quote
Hmm, hall efffect not supplied? What is that a $2 transistor. I saw a pic with the sensor installed on a Jab site. I ass-u-me-d that it was supplied.
I assume there is a mount for it on the engine?????
Thanx for all the pullup and protection advice. I will definetely be taking it all to heart.
Glad to hear everything is just pots, the oil temp and pressure.
What is a vdo?
I hope to open my engine box next week and am beginning to plan for the microcontroller.
Don
PostPosted: Wed Jun 10, 2009 8:10 pm    Post subject: Wiring for the jab 3300 Reply with quote
VDO is the German maker of senders and gauges.
-- Craig
Clive J
PostPosted: Thu Jun 11, 2009 12:23 am    Post subject: Wiring for the jab 3300 Reply with quote
It's an eddy current probe, there is a mount sticking out from the engine back plate, it counts two small tabs that are on the back of the fly wheel.
I got it from RS Components
Products In Stock
RS Stock No. Qty Unit Price Goods Value Description
304-166 1 £8.30 £8.30
Magnetic,pick up,min,Analogue,O/P 10V
Regards, Clive
What is a vdo?
Don
Apologies if I seem antagonistic.
I believe in the freeflowing ideas and discussions between individuals for assistance in this thing we call life.
http://forums.matronics.com/viewtopic.php?p 47649#247649
mosquito56
PostPosted: Thu Jun 11, 2009 4:12 pm    Post subject: Re: Wiring for the jab 3300 Reply with quote
Thanx, that will save me a bunch of grief.
Don McIntosh
PostPosted: Fri Jun 12, 2009 7:34 am    Post subject: Re: Wiring for the jab 3300 Reply with quote
Are you talking about the sensor for RPM here because I was wondering also what to get to feed RPM info to my Dynon? Will this sensor you called out here do this? I am just getting ready to start all the wiring and sensor hookup.
 Filesize:  214.45 KB
 Viewed:  14915 Time(s)
Don McIntosh
Kitfox Series 7
Jabiru 3300
DaveG601XL
PostPosted: Fri Jun 12, 2009 8:21 am    Post subject: Re: Wiring for the jab 3300 Reply with quote
Don,
With the Dynon, you can just tap into one of the alternator output wires. Set the Dynon configuration to read 6 pulses per rev. That is what I did and it read within 1 RPM of a PropTach optical unit.
Good luck,
David Gallagher
Cincinnati, OH area
Don McIntosh
PostPosted: Fri Jun 12, 2009 8:24 am    Post subject: Re: Wiring for the jab 3300 Reply with quote
Great!
Don McIntosh
Kitfox Series 7
Jabiru 3300
