mau11(at)free.fr Guest
Posted: Tue Jun 09, 2009 7:18 am Post subject: Reduce speed in approach |
Hello all,
Is there a flap manual command on the three gear?
I search a solution to reduce speed approach by increasing flap position
on the monowheel.
Do you have an idea?
Builder N° 145
Michel AUVRAY
mau11(at)free.fr
rlborger(at)mac.com Guest
Posted: Tue Jun 09, 2009 2:56 pm Post subject: Reduce speed in approach |
Michel,
Do I understand correctly that you wish to reduce the approach speed
by extending the flaps further than is normally permitted on the
monowheel?
If so, from my experience, I do not see any simple means by which this
can be accomplished.
There is an adjustment available in the position of the FL21 "Horn"
which can be used to allow a bit more flap movement. See page
28M-11. There is also some adjustment available in the "Fork
Assembly" (175-601-208) which is installed at both ends of the "Flap
Push Rod (FL20). See page 28M-17. These adjustments could be used to
proved some limited additional flap extension, but probably at the
cost of a less than fully retracted flap and some loss of cruise speed
due to the added drag. I'm not sure how much approach speed reduction
could be gained, but I expect it would be minimal.
I guess you could also machine a new, longer, FL19 "Horn Plate" which
would provide greater movement of the "Flap Push Rod" with further
extension of the flap.
Personally, I'd not recommend any of these modifications as you are
treading in new, untested areas of Europa aerodynamics. Perhaps one
of the more aerodynamically inclined folks can make a better judgement.
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Jun 9, 2009, at 10:16, Michel AUVRAY wrote:
Hello all,
position on the monowheel.
Builder N° 145
--------(*)-------- Michel AUVRAY
mau11(at)free.fr
pjeffers(at)talktalk.net Guest
Posted: Tue Jun 09, 2009 11:25 pm Post subject: Reduce speed in approach |
Hi
Be very careful in this area One of the reasons for the current max flap setting is that any speed below your current approach speed would significantly reduce aileron effectiveness Need I say more
Pete Jeffers
Posted: Wed Jun 10, 2009 12:48 am Post subject: Reduce speed in approach |
Robert Borger wrote:
Michel,
monowheel?
I
Check six,
Bob Borger
Bob, Michel
Ivan did test 30deg flap deflection but he found that at any lower speed
control was difficult because the ailerons were not effective.
Don't do it
Graham
david.stanbridge(at)swift Guest
Posted: Wed Jun 10, 2009 1:30 am Post subject: Reduce speed in approach |
Michel,
| Quote: | From an aerodynamic perspective then increasing the flap angle will
substantially increase the pitching moment and you will undoubtedly find
that you run out of tail authority.
Essentially with an increased pitching moment the horizontal tail needs to
do more work to balance it. At lower speeds it will actually provide less
work and therefore you could find yourself in a very steep descent that
close to the ground will not be recoverable.
My advice would be to stay clear of this.
To slow the aircraft further you could experiment with vortex generators on
the upper surface of the wing which is something that Bud Yerly has been
looking at with some folks in California. With VG's the pitching moment is
not so much impacted but the underpowered horizontal tail is still there.
Then VG's would be needed on the horizontal tail to counter this to prevent
it from stalling. In other words it is not an easy thing to do.
Dave Stanbridge
Europa Aircraft
Hello all,
I search a solution to reduce speed approach by increasing flap > position
on the monowheel. ; > 0
Posted: Wed Jun 10, 2009 9:02 am Post subject: Reduce speed in approach |
Graham Singleton a écrit :
<grahamsingleton(at)btinternet.com>
> Michel,
> monowheel?
> I
> Check six,
> Bob Borger
Bob, Michel
speed control was difficult because the ailerons were not effective.
Don't do it
Graham
Hello graham;
How are you?
My problem is the next.I live near Grenoble now, and the airfield in
mountains are sometimes short and it is important to have a sufficient
low speed for landing.
To day the monowheel offert a compromise flaps position. In the three
wheels the position flap is 29 to 30°? I am interested to obtain the
same no more.
To day my flaps are in 25° position.
My idea is to install a handle on the flap tube command into the tunnel
and the handle pass through one slot on the top of the tunnel, with
three positions in order:
- Flight
- Take off
- Landing
Please look my drawing joint, I study this project.
Naturally I modified the OR5 and increase the slots on each side of the
fuselage (About 20- 25 mm) I add a latch with spring to lock the handle
in each position, this is not close.
I have only one problem I don't know what is the effort previously on
the flap handle?
On many aircraft there is a three or more flaps positions, manual or
electric. In the case of monowheel I prefer manual.
What is your opinion of this idea?
Michel AUVRAY
mau11(at)free.fr
 Download |
| Filename: |
Commande_manuelle_des_volets_2.pdf |
75.09 KB |
| Downloaded: |
498 Time(s) |
rparigor(at)suffolk.lib.n Guest
Posted: Wed Jun 10, 2009 10:13 am Post subject: Reduce speed in approach |
Hi Michel
Where did you get information that the Tri gear can have more than 27 degrees? I just looked on Factory build manual and tri is same as mono, 25 to 27 degrees:
http://www.europa-aircraft.biz/pdfs/buildersmanuals/CBM%20-%20ANNEX%20E%28T%29%20Mar%202008.pdf
Like others have mentioned, I too heard that more tha 27 degrees will allow plane to take off before you have proper aileron authority on a Monowheel.
How would you deal with the fact that the down stop on the undercarriage mounting frame needs to be firmly planted?
Justin Kennedy has independent flaps on a Mono I think? Takeoffs in crosswinds with less than full flaps can be desirable on a mono.
If I were you, adjust to 27 degrees flaps, adjust your idle if you have a Rotax so it is smooth on ground at 1450RPM, but only use that setting for landing short. A fine pitch prop, or variable pitch should also help slowing plane down with a low idle. Remember low idle in air will not be as low as static. Best idle on ground 1800RPM plus. The lighter the aeroplane the better for slowing things down.
Even if you change flap setting just 2 degrees, go up and practice a full stall series cooridinated and not, try also in some turns to make sure you didn't introduce any nastyness. If you do tend to dropping a wing, you could try and reflex the ailerons just a little from neutral which would act as an extras bit of washout, also when you load wings ailerons tend to go down (perhaps try 3/32" reflex).
Drouge chutes work a treat as does beta thrust!
Ron Parigoris
Visit - www.EuropaOwners.org
Posted: Wed Jun 10, 2009 4:09 pm Post subject: Reduce speed in approach |
| Quote: | Hello graham;
How are you?
same no more.
tunnel and the handle pass through one slot on the top of the tunnel,
with three positions in order:
Hallo Michel!
I am good thank you, I trust you are well. I wish that I lived near
Grenoble!
I think your idea would be OK. Remember that at these deflections the
flap is producing a lot of drag.
I recommend when you land at these lower speeds you leave some power on,
increased power will reduce stall speed but you will need to be very
careful especially in gusty weather. A strong gust can instantly stall
the airplane.
Graham
paul.the.aviator(at)gmail Guest
Posted: Wed Jun 10, 2009 6:34 pm Post subject: Reduce speed in approach |
Hi Graham,
I seem to recall in conversations with Ivan or Andy or someone that the original design criteria was for 30 degrees of flap deflection, but ultimately all that could be achieved mechanically was 27 degrees.
Do you have any recollections of this, or is it just "hanger talk" that I have remembered and got tangled up in my aging neurons ? Can you confirm or dispel this?
I do know from my experiments of trying to get negative flap defection, I could never extend the range of travel past 27 degrees, despite making several FL21 horns. Just as an aside Bud has told me with the elliptical lift distribution on the wing that negative flaps probably wouldn't buy me much anyway.
Micheal once upon a time, way back when I owned a Cessna 150 that had 40 degrees of flap. I remember that I could really land it in a short distance, but it used to drop out of the sky like a man hole cover, and if I tried to do a go around I had t retract some flaps otherwise it wouldn't climb. I can say that can replicate the same short landings in my Europa but I have to really focus on the approach speed.
I do have a question though, I was wondering way you are unable to achieve 27 degrees of flap deflection.
BTW, I can confirm that keeping a little power on helps with the airflow over the stabilizer and you can slow the aircraft down a little more, however you don't want to get too far behind the power curve that your engine / propeller combination won't pull you back if you need to power up and go around. I have a 914 / Airmaster and I find that anything below 55 knots gets little tricky. I'd suggest you try experimenting at altitude to get a feel of what its like.
As they say, "your mileage may vary", take it easy and fly safe.
Cheers, Paul
On Wed, Jun 10, 2009 at 6:07 PM, Graham Singleton <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote] I am good thank you, I trust you are well. I wish that I lived near Grenoble!
I think your idea would be OK. Remember that at these deflections the flap is producing a lot of drag.
I recommend when you land at these lower speeds you leave some power on, increased power will reduce stall speed but you will need to be very careful especially in gusty weather. A strong gust can instantly stall the airplane.
Graham[b]
ploucandco
Posted: Thu Jun 11, 2009 12:24 am Post subject: Re: Reduce speed in approach |
Hi Michel,
Can you tell me what is the length of the runway at your airfield?
I have a monowheel and found landing it on the 400m strip asphalt at my base aerodrome very challenging, especially when I am alone in the plane. Grass is a bit more easy as less tendency to bounce.
In extreme conditions, I stop the engine just after touchdown. That stops the runway needs.
I use 55knots as approach speed when no wind, 58 in windy conditions.
Kind regards, Jacques
rampil
Posted: Fri Jun 12, 2009 6:55 am Post subject: Re: Reduce speed in approach |
Hi Michel,
To answer your other questions, the trigear flaps are independent
of the the landing gear (since the gear are fixed!) and the flaps are
continuously variable 0-25 degrees.
If I were in your position, I would pay very careful attention to what
David Stanbridge has to say, unless you have a wish to splint your
airframe into one of those mountains.
Instead, consider using a slip which the Europa does quite well to lose
altitude without increasing speed.
Please be careful!
Ira
