vk3eka(at)bigpond.net.au Guest
Posted: Wed Jun 10, 2009 5:09 am Post subject: Fuel pipe size |
Hi Guys,
I'm running an O-200 on my 601 and will be using aluminium tubing instead of
the supplied 1/4 inch hose. What size ID are others using for an O-200?
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
bryanmmartin
Posted: Wed Jun 10, 2009 6:51 am Post subject: Fuel pipe size |
Tubing is generally listed by OD, 3/8" OD tubing should work fine.
That will give you a bit more than 1/4" ID.
Hi Guys,
instead of
O-200?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
r-garrett(at)att.net Guest
Posted: Wed Jun 10, 2009 2:42 pm Post subject: Fuel pipe size |
PETER- I would use 3/8 O.D. aluminum tubing as a replacement for the rubber
hose . It has a 1/4 inc I. D.
Posted: Wed Jun 10, 2009 3:39 pm Post subject: Fuel pipe size |
Hi Guys,
Thanks for the response. The reason for the question was that all parts
supplied by Zenith (gascolator, fuel tank) use 1/4" npt, the fuel pump uses
1/8" npt. The O-200 uses an MS3SPA with 1/4" fittings. I'll go with the 3/8"
tube and adaptor fittings for the fuel pump.
Cheers
Peter
Wonthaggi Australia
