Gig Giacona
Posted: Wed Jun 10, 2009 11:10 am Post subject: Dynon and trim. |
Anyone have a wiring diagram for where they installed with a Dynon 180...
2 RAC trim servos, 1 RAC Flap Sensor, 1 five button RAC grip?
601XL Under Construction
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Jun 10, 2009 11:31 am Post subject: Re: Dynon and trim. |
Gig,
Do you have the Dynon D-180 install guide? Trim and flap instructions are on page 3-16 of the latest version. It says to send the RAC orange wire to Dynon's 5VDC excitation, pin 18. The RAC blue wire to ground and the RAC green wire to the general purpose input of your choice. It works fine in my installation.
What you cannot do is use the RAC indicator AND send the same indication to the Dynon. The RAC indicator puts out a 6VDC signal, so it over saturates the Dynon. The general purpose inputs coughs at over 5VDC of incoming voltage. Believe me, I tried it and found out first hand!
Good Luck,
_________________ David Gallagher
Cincinnati, OH area |
Gig Giacona
Posted: Wed Jun 10, 2009 12:19 pm Post subject: Re: Dynon and trim. |
| DaveG601XL wrote: | Gig,
Do you have the Dynon D-180 install guide? Trim and flap instructions are on page 3-16 of the latest version. |
I found that and understand it but where my confusion really kicks in is the wiring that goes through the RAC grip.
Posted: Wed Jun 10, 2009 12:38 pm Post subject: Dynon and trim. |
I may be confused about what you are asking for but the wiring between the
RAC grip and RAC trim actuators is in the RAC docs and doesn't go through
the Dynon. The position indication does but the two systems are electrically
isolated even though linked mechanically.
-- Craig
Gig Giacona
Posted: Wed Jun 10, 2009 1:02 pm Post subject: Re: Dynon and trim. |
| craig(at)craigandjean.com wrote: | I may be confused about what you are asking for but the wiring between the
-- Craig
The grip is really what is bothering me. Because the way the buttons, including the PTT button share a ground and a DC power supply.
I asked for a diagram of the whole thing to deal with that issue and then to check that I was reading the Dynon manual correctly.
annken100
Posted: Wed Jun 10, 2009 5:16 pm Post subject: Re: Dynon and trim. |
Gig,
Sharing a ground with the other switches in the grip is not a problem, your PTT will work just fine. The ground you share with the PTT is always ground and never sees voltage.
Ken
_________________ 601 XL / Corvair |
