Portable Scale
robin1(at)mrmoisture.com
PostPosted: Mon Jun 01, 2009 7:10 pm    Post subject: Portable Scale Reply with quote
-10 List,
  I just purchased a hand scale to keep in my plane for weighing luggage etc… while on the road. It’s a nifty little device that seems to work pretty well based on a few trials. The item is called Balanzza http://www.balanzza.com/ I purchased the Balanzza Ergo. It lists for $24.95 but I think I picked it up (new) for $18.00 delivered on eBay. I even got one in a steel blue to match my plane. They have a new unit coming out called the Balanzza Too BZ300 that has a flashlight on the butt end but it’s closer to $40.00 delivered as it has not hit eBay/discounters.
Robin
 Filesize:  13.91 KB
 Viewed:  4925 Time(s)
Tim Olson
PostPosted: Mon Jun 01, 2009 7:35 pm    Post subject: Portable Scale Reply with quote
That is WAY cool for the price and could probably also measure nosewheel breakout force!
On Jun 1, 2009, at 10:08 PM, "Robin Marks" <robin1(at)mrmoisture.com (robin1(at)mrmoisture.com)> wrote:
-10 List,
Robin
<image003.jpg>
toaster73(at)embarqmail.c
PostPosted: Tue Jun 02, 2009 4:17 am    Post subject: Portable Scale Reply with quote
Tim,
You mention nose wheel breakout force, can you recall where this number is published in the plans?
Chris
#40072
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson
Sent: Monday, June 01, 2009 11:34 PM
Subject: Re: Portable Scale
-10 List,
Robin
<image003.jpg>
ninepapa(at)bendbroadband
PostPosted: Tue Jun 02, 2009 5:44 am    Post subject: Portable Scale Reply with quote
Chris
Page 46-06 step 2.
Tim Olson
PostPosted: Tue Jun 02, 2009 5:47 am    Post subject: Portable Scale Reply with quote
From plans, it's 26lbs. After going through the setup a
few times with it loosening over time, I'd say go on the high
side, not the low, as the flats will probably force you to go in
one way or the other. I've set mine anywhere between 25 and 35
in the past, and it will loosen quite a bit.
The torque spec is on page 46-06.
Tim Olson - RV-10 N104CD
Chris wrote:
Tim,
Chris
#40072
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim Olson
*Sent:* Monday, June 01, 2009 11:34 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Portable Scale
breakout force!
<mailto:robin1(at)mrmoisture.com>> wrote:
-10 List,
Robin
<image003.jpg>
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
bcondrey
Page 46-06, step 2: should be 26 pounds. This WILL loosen up during the first several hours and need to be readjusted.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris
Sent: Tuesday, June 02, 2009 7:15 AM
Subject: RE: Portable Scale
Tim,
Chris
#40072
-10 List,
Robin
<image003.jpg>
jesse(at)saintaviation.co
PostPosted: Tue Jun 02, 2009 6:17 am    Post subject: Portable Scale Reply with quote
I don't remember where it is in the plans, but I assume in the landing gear and wheel section. The force IIRC is 26lbs at the axle.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Jun 2, 2009, at 8:14 AM, Chris wrote:
Tim,
Chris
#40072
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Tim Olson
-10 List,
Robin
<image003.jpg>
gengrumpy(at)aol.com
PostPosted: Tue Jun 02, 2009 6:20 am    Post subject: Portable Scale Reply with quote
It's in the section where the nose gear is put together. Think it is 26 lbs.
grumpy
On Jun 2, 2009, at 7:14 AM, Chris wrote:
Tim,
Chris
#40072
-10 List,
Robin
<image003.jpg>
= [quote][b]
PostPosted: Tue Jun 02, 2009 4:59 pm    Post subject: Portable Scale Reply with quote
Roger Wilco, thanks to all replies I thought I had been through that area. I ‘ll look harder!
-CHris
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA)
Sent: Tuesday, June 02, 2009 9:08 AM
Tim,
Chris
#40072
-10 List,
Robin
<image003.jpg>
 http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution
5
6
7
