rmacpunk(at)netzero.net Guest
Posted: Sun May 31, 2009 2:49 pm Post subject: Wing tip height xl |
Can someone give me the approx wing tip height from the ground. I am in the process of fitting the wings and do'nt wish to cut off too much metal on the inboard side. Thanks
psm(at)att.net Guest
Posted: Sun May 31, 2009 3:13 pm Post subject: Wing tip height xl |
Hi Bob,
If you do cut off to much metal on the inboard end of a wing, it is easy to add a strip from the last rib to the final position you want. Actually, this is a lot easier than cutting the existing skin since you can fit a template to the fuselage (I like styrene plastic sheet for this) and later position it to drill for the rivet line on the inboard rib.
If you make a nice edge to the "Fairing" it looks like you planned it all along.
Paul
XL grounded
At 03:46 PM 5/31/2009, you wrote:
[quote]Can someone give me the approx wing tip height from the ground. I am in the process of fitting the wings and do'nt wish to cut off too much metal on the inboard side. Thanks
jaybannist(at)cs.com Guest
Posted: Sun May 31, 2009 3:24 pm Post subject: Wing tip height xl |
Bob,
>From the fattest part of the bottom of the wing at the bottom of the tip plate is approximately 4' - 5". Geive me a couple of hours and I'll send you a narrative of how I did it along with a drawing and photo.
Jay Bannister
Do not archive.
