mlord001(at)new.rr.com Guest
Posted: Wed May 27, 2009 4:41 am Post subject: Bolt torque |
Thanks Guys for the heads up on the AN bolt torque.
I will pull all of my wing bolts and replace them with new.
To explain where I got the bogus information. I googled
AN Bolt torque and a ultralightflyers.org/documents came up
I clicked on it and AN Bolt torque spec.xls document came up
with the faulty information.
Mike Lord
purplemoon99(at)bellsouth Guest
Posted: Wed May 27, 2009 1:43 pm Post subject: Bolt torque |
Juan Vega Jr
Posted: Fri May 29, 2009 5:22 am Post subject: Bolt torque |
I just checked it out. Its a good table to use. the info is correct, you just need to read the top of the column where it says foot lbs or inch lbs. I am saving it to use later. it is attached below for all.
Juan
 Download |
| Filename: |
an_torque_specs.pdf |
9.62 KB |
| Downloaded: |
10364 Time(s) |
Juan Vega Jr
Michael,
now I see, i think the numbers have an extra zero. trash that file!
JUan
JohnDRead(at)aol.com Guest
Posted: Fri May 29, 2009 5:38 am Post subject: Bolt torque |
Juan;
Your numbers are off the wall wrong! Please look in the Zenith Construction Standards for the correct numbers.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
Discover the vari1222831871x1201491818/aol?redir=http:%2F%2Fad.doubleclick.net%2Fclk%3B215225813%3B37274670%3Be%3Fhttp:%2F%2Frecipes.bisquick.bettycrocker.com%3FESRC%3D971>Get Recipes & Savings Now.
pdn8r(at)yahoo.com Guest
Posted: Fri May 29, 2009 5:50 am Post subject: Bolt torque |
Torgue values from 43.13 attached.
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
--- On Fri, 5/29/09, Juan Vega <amyvega2005(at)earthlink.net> wrote:
Subject: Re: Bolt torque
To: zenith-list(at)matronics.com, zenith-list(at)matronics.com
Date: Friday, May 29, 2009, 9:22 AM
--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net (amyvega2005(at)earthlink.net)>
Michael,
JUan
 Download |
| Filename: |
Torque_Values.pdf |
1.04 MB |
| Downloaded: |
344 Time(s) |
pete(at)usjabiru.com Guest
Posted: Fri May 29, 2009 6:14 am Post subject: Bolt torque |
Here is the FAA torque chart from AC43-13. Note that values are in inch lbs
Pete
 Download |
| Filename: |
Torque_Chart_AC43-13.pdf |
36.23 KB |
| Downloaded: |
331 Time(s) |
Posted: Fri May 29, 2009 6:25 am Post subject: Bolt torque |
Here's a question for all. Is this lack of understanding of torque values behind the alleged wing failure problems?
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 5/29/2009 8:15:30 A.M. Mountain Daylight Time, pete(at)usjabiru.com writes:
[quote]Here is the FAA torque chart from AC43-13. Note that values are in inch lbs
Pete
bryanmmartin
Posted: Fri May 29, 2009 6:56 am Post subject: Bolt torque |
I don't recall seeing bolt failure mentioned in any of the accident
reports.
On May 29, 2009, at 10:24 AM, JohnDRead(at)aol.com wrote:
| Quote: | Here's a question for all. Is this lack of understanding of torque
John Read
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
