Crowbar
woxofswa
PostPosted: Fri May 15, 2009 9:21 am    Post subject: Crowbar Reply with quote
I received my Crowbar OV-14 module along with other parts for my external power project.
Perhaps because of the importance of the task, or maybe because of the macho name "Crowbar", I kind of expected a big meaty device with attitude and tatoos ... Something that would belong on a De Havilland that McGyver could use to save the world and then cook his dinner.
Needless to say I was surprised at the scrawny little twirp that looked like it belonged in a Chinese toy robot.
(just funnin' with ya Bob).
Nevertheless, my whole life has been doing more with less, so I have 100% confidence in this dohicky, I just have a couple of questions.
Is this thingy a one time protector? Does it give its life to an overvoltage and you snip it off like a foreskin and replace it? Or does it reset itself and endure forever?
What is the best way to install it? Just wire it in and tie wrap it somewhere?
Does anyone have a picture of a proper installation?
Thanks in advance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
trigo(at)mail.telepac.pt
PostPosted: Fri May 15, 2009 10:12 am    Post subject: Crowbar Reply with quote
Myron
Very well described, I mean the sensation you had. It was exactly the same I had when I received that CROWBAR OV-14 little black critter…
Well, perhaps I couldn’t have remembered what McGiver could do with it … J
Carlos
[quote] --
mprather(at)spro.net
PostPosted: Fri May 15, 2009 10:13 am    Post subject: Crowbar Reply with quote
The little pipsqueak should last a long time.. All it has to do is fault
the 5A breaker and drag the field pin down (if it has an external
regulator). I believe the SCR selected is up to repeated trips without
any trauma. If I'm reading the specs correctly, it will handle 16A
without problem (with proper cooling).
Matt-
power project.
macho name "Crowbar" I kind of expected a big meaty device with attitude
and tatoos. Something that would belong on a De Havilland that McGyver
like it belonged in a Chinese model airplane.
somewhere?
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p 44172#244172
PostPosted: Fri May 15, 2009 11:42 am    Post subject: Crowbar Reply with quote
At 12:21 PM 5/15/2009, you wrote:
--> AeroElectric-List message posted by: "woxofswa" <woxof(at)aol.com>
Perhaps because of the importance of the task, or maybe because of the macho name "Crowbar" I kind of expected a big meaty device with attitude and tatoos. Something that would belong on a De Havilland that McGyver could use to save the world and then cook his dinner.
Needless to say I was surprised at the scrawny little twirp that looked like it belonged in a Chinese model airplane.
It's job is over less than 100 milliseconds after
onset of an OV condition. It forces the 5A field
supply breaker open. It will do this many times
without breaking a sweat.
Tie-wrap it to a wire bundle. It's okay
to let the body hang on the leads.
Thanks in advance.
I fussed over packaging for some time. I was
looking for a process and materials that provided
adequate protection while keeping costs low.
When you have an assembled ECB this small
[img]cid:.0[/img]
How's the best way to package it? Potting (full
encapsulation) is messy, slow and makes the thing
difficult to diagnose for field failures . . . impossible
to repair.
The double melting wall heat-shrink provides an
envelope that can be put on in seconds, offers
good shielding from contaminants. It can be
cut away for repairs, field failure diagnosis
or re-adjustment.
Our next line of products will be offered in
an enclosure like this:
[img]cid:.1[/img]
I have hundreds of plastic boxes with pre-cut d-sub
connector holes in the top. Cost of box and lid is
under $2. While the box is glued shut, it's fast to
assemble, easy to cut off, easy to replace after
repairs are made, etc.
I really considered reviving the CbOVM-14 in
this housing but that would ADD the costs of enclosure
and connector. Not consistent with my design and
marketing goals.
( -Thomas Paine 1776- )
 Filesize:  45.24 KB
 Viewed:  13007 Time(s)
 Filesize:  143.54 KB
johngoodman
PostPosted: Tue May 26, 2009 11:25 am    Post subject: Re: Crowbar Reply with quote
I'm following the Z-31A schematic for a military style ground power jack, and I'm ordering parts. I've found everything except for the OVM-14 Crowbar O.V. Module. I called B&C sales and they referred me to a part number 504-1 , which is something for an alternator with a lot of pieces. How do I get just the OVM-14?
PostPosted: Tue May 26, 2009 12:31 pm    Post subject: Crowbar Reply with quote
At 02:25 PM 5/26/2009, you wrote:
<johngoodman(at)earthlink.net>
They're in production in our shop now. I don't have
them on the catalog yet. Fill out an order at:
https://matronics.com/aeroelectric/Catalog/AECcatalog.html
and put "1ea CbOVM-14 (at) $25.00" in the comments box.
woxofswa
PostPosted: Mon Jun 15, 2009 11:24 am    Post subject: Re: Crowbar Reply with quote
I am finishing up the installation of my external power receptacle.
Just to be totally sure, please verify that the orange lead from the OVM14 is the positive lead and goes on the left terminal of the smaller posts on the contactor?
Thanks in advance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
PostPosted: Tue Jun 16, 2009 5:23 am    Post subject: Crowbar Reply with quote
Yes, the non-black lead is (+). The exact color
was changed to identify mod levels in the construction.
Don't know about the "left" terminal. The (+) lead
of the crowbar module goes to the (+) supply termnial
of the contactor . . . the black lead goes to the
terminal that is connected to the ground power control
breaker.
plevyakh
PostPosted: Tue Sep 18, 2012 1:08 pm    Post subject: Re: Crowbar (engine side) or cool panel side to install? Reply with quote
Guys,
I'm installing the CbOVM-14 OV Protection module and wanted to confirm if it's ok to install this on the engine side of the firewall (HOT), or should I put it on the Instrument Panel side (COOL).
It would be a little easier with wiring to zip tie it onto my Ground Power contactor terminal wires on the engine side, but I didn't want to do this if over the airplane life I'd eventually fry the thing.
Sounds like either side I choose, the installation mount method is to just tie wrap it to some wires. If others have a better idea, I'd appreciate the tips.
TIA for your comments and help!
Howard
Howard Plevyak
GlaStar / Cincinnati, Ohio
PostPosted: Tue Sep 18, 2012 7:11 pm    Post subject: Crowbar Reply with quote
At 04:08 PM 9/18/2012, you wrote:
Guys,
it won't be damaged . . . but htey do have
a temperature coefficient of voltage greater
than I would like.
That will work . . . and it would be best to
install it in the cockpit.
