Engine mount as starter ground path
Goto page 1, 2  Next
jpx(at)Qenesis.com
PostPosted: Tue May 26, 2009 7:26 am    Post subject: Engine mount as starter ground path Reply with quote
Does anyone have some scientific information (beyond the practical
description in the Connection) that I can use to convince someone that
running the engine ground strap to the engine mount is a poor choice ?
Thanks !
Jeff Page
Dream Aircraft Tundra #10
AV8ORJWC
PostPosted: Tue May 26, 2009 9:15 am    Post subject: Engine mount as starter ground path Reply with quote
Totally separate but possibly dead on. My 1978 Ford pickup suffered
catastrophic electrolysis of the cab floorboards and the entire bed
(years 28-31). The Tailgate was replaced with an Electro-Hydraulic
1,000 pound Tommy Lift. The lift motor used high current capacity
welding cable with neoprene shielding for the Positive. NO GROUND.
Just the mounting to the bed of the truck and the frame rails. All of a
sudden over the last several years, the truck began rapid corrosion
(Really Rapid - Decomposition).
My conclusion. Stray electrons looking for the primary path to ground -
found their path without the aid of the missing ground. My action -
Never again! use a structural mount in hopes of taking a path of less
effort during installation. Provide an adequate ground from the battery
or generator source. Listen to Bob. Semi-monocoque construction makes
it even more valid.
YMMV.
John Cox
Now for the experts.
longg(at)pjm.com
PostPosted: Tue May 26, 2009 9:52 am    Post subject: Engine mount as starter ground path Reply with quote
How about the scientific principle of rubber engine mounts being a poor
conductor of electricity? That would go for the cadmium plating on the
bolts themselves. Not a perfect conductor. Scientifically engine
mounting bolts will corrode over time, get oily and generally loose what
connectivity they have.
Under Ohm's law the addition of the engine mount changes sub R in the
equation reducing the conductance value of the material. If he works out
the equation using the combined values conductivity will be less. After
he is done scratching his head, he'll recognize why it's done this way.
See: http://en.wikipedia.org/wiki/Electrical_conductance
If he is trying to save $3.00 on the cost of the additional 5" of cable
required to anchor it to the engine, there is little argument on his
side.
PostPosted: Tue May 26, 2009 12:56 pm    Post subject: Engine mount as starter ground path Reply with quote
Thanks !
The shortest, lowest resistance and minimum parts count path
in any high current conduction path is the road to Ground
System Nirvana. See:
http://www.aeroelectric.com/articles/grnding.pdf
Engine mounts are steel assembled with steel
hardware. The joints between mounts and other
components of the airframe are not treated for
the purpose of electrical "bonding". The engine
mount is intended to hold the engine on the
airplane and was not designed or installed to
be a part of the electrical system.
Note that Figure Z-15 and Chapter 5 of the
'Connection speak to and illustrate a notion
that engines are best tied to the single point
fire-wall ground block with a single-flexible-
fatwire. To avoid having the firewall sheet
participate in a PARALLEL ground path (read
ground loop) any bonding jumpers across the
engine mounts are best removed.
( -Thomas Paine 1776- )
Kellym
PostPosted: Tue May 26, 2009 1:22 pm    Post subject: Engine mount as starter ground path Reply with quote
Given such a ground path, how does one get lineboys trained that the engine exhaust pipe is a terrible place for ground wire, that the fuel tanks are in the wings, and something like a bare spot on wing tiedown has a much shorter ground path? I always wonder how static charge is supposed to make it from the fuel tank through the airframe to the engine and down the rusty, carboned up exhaust pipe, usually with a swivel or slip joint or two to that ground wire, without significant resistance.
Robert L. Nuckolls, III wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> (nuckolls.bob(at)aeroelectric.com)
--> AeroElectric-List message posted by: "Jeff Page" <jpx(at)Qenesis.com> (jpx(at)Qenesis.com)
Thanks !
[img]cid:part1.04030200.02060605(at)aviating.com[/img]
 Filesize:  1.97 KB
 Viewed:  22383 Time(s)
Kelly McMullen
KCHD
europaul260i(at)bvunet.ne
How about some anecdotal evidence. I had a Cadillac 4.9 liter V8 installed
in my Pontiac Fiero. Since it weighted 15 pounds more than the V6 that was
in there, I had the battery moved from the rear engine compartment to just
on top of the front axle. My voltmeter would not show over 13.5 volts even
when the battery was weak and would drop below 12 volts if I ran the AC and
lights at the same time. I would also have intermittent problems starting
the car when it was hot. The battery was grounded to the frame and the
engine was also grounded to the frame. A 9 foot #2 wire went from the
positive terminal to the starter. After putting on a new starter the engine
would not start hot the very first time I drove it somewhere. I put a 9 foot
#2 wire from the negative side of the battery to the one of the mounting
studs of the starter and now no more starting problems. The voltmeter shows
14.5 volts on start-up and after a brief drop when turning on the lights and
AC, it shows 13.5 volts. The ground is important. I only wish it hadn't
taken me 2 years to figure it out.
Vaughn Teegarden
frank.hinde(at)hp.com
PostPosted: Tue May 26, 2009 1:37 pm    Post subject: Engine mount as starter ground path Reply with quote
Just be thankful your ground path didn't go thru your crank bearings..You would have figured itout a lot sooner though..Smile
Frank
RV 7a and a tractor where the battery negative goes directly to the starter as well!
PostPosted: Tue May 26, 2009 2:51 pm    Post subject: Engine mount as starter ground path Reply with quote
The line boy's ground lead is not intended to carry
more than micro-amps of current . . . and then for
only enough time to equalize the STATIC charge on
the airplane with the STATIC charge on the fuel truck.
Given the proliferation of composite aircraft it's
not a bad bet for fuel truck operators to use the exhaust
pipe . . . it's metallic and definitely connected to
the crankcase through other metallic parts. Now, it's
entirely possible that a metallic tank resides in a
composite wing and is plumbed up with some modern
synthetic tubing . . . it's a tiny bit of a crap-shoot.
Bottom line is that the rusty, gunked up piece of pipe
is not a bad choice.
MauleDriver(at)nc.rr.com
PostPosted: Tue May 26, 2009 5:49 pm    Post subject: Engine mount as starter ground path Reply with quote
The Z-14 I've put into my RV10 follows the best practices as described
in the Connection with one oversight.... I have the 2 sided forest of
tabs on the firewall but I only have an AWG 8 cable running to it from
the rear batteries instead of an AWG2 fat wire. And it's too late to
swap it out without significant re-work.
The isssue is how to get the engine adequately grounded for the
start. I remember this same situation being discussed recently on
either the RV10 or AeroConnection list but I'd like to get some more
input regarding my choices as I see it.
Choice1: Run a flat fat wire (AWG 2 equivalent) from the forest of tabs
lug to the engine and keep the engine mount out of the circuit. Here
I'm depending on the AWG 8 cable and the firewall to provide and
adequate ground for starting. I feel that I do have a solidly grounded
airframe and it is a metal fuselage.
Choice2: Ground the engine to the mount per Van's wiring diagram - 2
straps from the mount to the engine and relying on the 6 mount bolts to
provide what they're not designed to provide. Here I'm trusting that
the steel engine mount will work as a working part of my electrical
system - clearly this is what the Connection is steering me away from.
Choice3: Do both 1 and 2 which gives me a better chance of an adequate
ground than either choice alone gives me, but I run the risk of ground
loops. (what is the potential impact of ground loops in the starter
circuit? Does this introduce potential ground loop problems to systems
connected to the forest of tabs?)
Bob, thanks for covering the same ground over and over!
Bill "enjoying panel wiring and fiberglassing at the same time" Watson
RV10 40605
> Thanks !
PostPosted: Tue May 26, 2009 8:38 pm    Post subject: Engine mount as starter ground path Reply with quote
t 08:47 PM 5/26/2009, you wrote:
<MauleDriver(at)nc.rr.com>
described in the Connection with one oversight.... I have the 2 sided
forest of tabs on the firewall but I only have an AWG 8
cable running to it from the rear batteries instead of an AWG2 fat
wire. And it's too late to swap it out without significant re-work.
Is this the ONLY ground for the rear-mounted batteries?
8AWG is waaayyyy too small. Pull it out and ground the
battery(ies) locally to the airframe.
http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_1.jpg
http://aeroelectric.com/Pictures/Batteries/Battery_Install_OBrien_2.jpg
http://aeroelectric.com/Pictures/Grounding/Local_Battery_Grounds_1.jpg
tabs lug to the engine and keep the engine mount out of the circuit.
This is a given . . . no matter what the
rest of the ground system looks like.
Here I'm depending on the AWG 8 cable and the firewall to provide
and adequate ground for starting. I feel that I do have a solidly
grounded airframe and it is a metal fuselage.
I'm not sure from your description where the ends
of the 8AWG wire are tied. This size of
wire is too small for any significant starter
performance.
to provide what they're not designed to provide. Here I'm trusting
that the steel engine mount will work as a working part of
my electrical system - clearly this is what the Connection is
It's been done before. Leave it alone.
adequate ground than either choice alone gives me, but I run the risk
of ground loops. (what is the potential impact of ground loops in
the starter circuit? Does this introduce potential ground loop
problems to systems connected to the forest of tabs?)
Do them both and ground the batteries
to the airframe. The 8AWG wire can be
cut loose and pulled out.
PostPosted: Wed May 27, 2009 5:37 am    Post subject: Engine mount as starter ground path Reply with quote
sided forest of tabs on the firewall but I only have an AWG 8
Bill, re-reading my posting from last night I'm not
sure I conveyed a clear image of my recommendations.
In a nutshell:
Add local grounds to airframe for the batteries if
you don't already have them.
Add crankcase to firewall ground stud for engine.
Leave jumpers across the engine mount biscuits.
You can cut the 8AWG wire out if you wish and
if it is practical. It adds only weight and
offers no significant electrical function.
airlincoln(at)sbcglobal.n
PostPosted: Wed May 27, 2009 10:03 am    Post subject: Engine mount as starter ground path Reply with quote
The discussion about engine mounts as ground points has generated a question.  The "When is a Good Ground Not?" article shows 2AWG wire for the high current paths as do the Z-15 diagrams demonstrating various grounding architectures.
The Z-13/8 diagram I was planning my electrical system around shows 4AWG wires for these same high current paths.  All my "fat wires" will be under 3 feet since my RG battery, starter and battery contactors, 40A alternator, and firewall ground block will all be on or close to the firewall.  I thought I had read somewhere in the "AeroElectric Connection" that 4AWG was fine as long as all the fat wires were 3 feet or less, but now I can't find it.
Could someone confirm that 4AWG welding cable is acceptable for the high current wires when these wires are all located on the hot side of the firewall, wired per Z-13/8 and each under three feet in length?
Lincoln Keill
RV-7A
PostPosted: Wed May 27, 2009 10:13 am    Post subject: Engine mount as starter ground path Reply with quote
It's crystal clear now! Thanks
> forest of tabs on the firewall but I only have an AWG 8 cable
> running to it from the rear batteries instead of an AWG2 fat wire.
In a nutshell:
skywagon
PostPosted: Wed May 27, 2009 11:25 am    Post subject: Engine mount as starter ground path Reply with quote
Static is usually described as high voltage and little to no current.
That means those nasty electrons are really juiced up...like a 2 year old loaded with chocolate cake, etc. They can jump tall buildings, and wide gaps, etc.
A hopped up electron does not need a good conductor to move and be a nuisance. Rusty or otherwise not well connected pipes, etc. work just fine. So connecting a static grounding line to an exhaust pipe should work just fine to dump most, if not all, of the electrons to ground.
Most of my Cessna wing is bare aluminum. As an extra precaution, I lightly touch the fuel nozzle to the wing surface before I even take the fuel caps off. That also relieves any final electrons off the table before fueling. Also, as the fuel flows, I make sure the nozzle is touching the metal filler neck. In dry climates especially, flowing fuel will also generate some static. With the nozzle grounded against the filler metal that takes care of those speedy critters also.
David
 Filesize:  1.97 KB
 Viewed:  22366 Time(s)
PostPosted: Wed May 27, 2009 1:37 pm    Post subject: Engine mount as starter ground path Reply with quote
The drawings published on our website and publications
are intended to illustrate architectures. Exact sizing
of circuit protection, wires, batteries, alternators, etc.
are up to the builder based on a host of considerations.
Your recollection is accurate in that if the battery,
starter and alternator are all within short distances
of each other (3' or so) then 4AWG is adequate to the
task of managing fat-wire duties.
When engine and batteries are remotely located from each
other (rear mounted batteries in RV-8, canard pushers) will
benefit from something bigger like 2AWG battery cables.
Really extreme cases like some some winged watercraft,
parallel 2AWG or 0AWG is often used.
tomhanaway
PostPosted: Thu May 28, 2009 5:08 am    Post subject: Engine mount as starter ground path Reply with quote
Bob,My first post to this site. I’m working on an rv-10. I thought I understood the grounding once you gave the below explanation to Bill W.One and two are clear. I read #3 as putting a jumper across an individual mount t0 both sides of a single biscuit. In a later post, you advise “any bonding jumpers across the engine mounts are best removed” to avoid parallel grounds. Equally, the Connection speaks of a single point ground at firewall. Is this a contradiction or does it refer to not having jumpers between two completely separate mounts?Thanks, Tom HanawayBoynton Beach, FLRobert L. Nuckolls, III wrote:> <nuckolls.bob(at)aeroelectric.com>> > At 11:35 PM 5/26/2009, you wrote:My first post to this site. I’m working on an rv-10. I thought I understood the grounding once you gave the below explanation to Bill W.
5
6
7
8
9
5
6
7
8
9
Tom Hanaway
Tom Hanaway
Tom Hanaway
Tom Hanaway
Tom Hanaway
RV-10. Built and sold
RV-8a. Building
PostPosted: Thu May 28, 2009 1:11 pm    Post subject: Engine mount as starter ground path Reply with quote
At 07:58 AM 5/28/2009, you wrote:
Bob,[/b]
explanation to Bill W.[/b]One and two are clear. I read #3 as putting a
[/b]
No, I was referencing a project-in-process where an
already too-small 8AWG battery(-) wire was installed.
Upsizing that wire was not an attractive option.
The work-around involved the used of jumper straps
around the shock mount biscuits and local battery grounds.
Now, if you're starting from scratch and your
battery is located near the firewall, that
posting was not applicable to you. Use NO
JUMPERS on the engine mount biscuits. Wire
as suggested in chapter 5 and Figure Z-15.
Welcome to the List!
tomhanaway
PostPosted: Thu May 28, 2009 4:42 pm    Post subject: Engine mount as starter ground path Reply with quote
Thanks Bob.
Sorry to beat a dead horse but I need one more clarification. Your response mentions “if battery near firewall”. The batteries are actually both in the aft area. Can the battery be locally grounded to airframe at site of battery (metal frame craft) with B&C tab forest on firewall for grounds and engine ground?
Or is best solution still to run a 2awg ground wire up to firewall and proceed with grounding to tab forest as above?
Tom
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Thursday, May 28, 2009 5:10 PM
Subject: Re: AeroElectric-List: Re: Engine mount as starter ground path
My first post to this site. Im working on anrv-10. I thought I understood the grounding once you gave the belowexplanation to Bill W.
One and two are clear. I read #3 as putting ajumper across an individual mount t0 both sides of a singlebiscuit. In a later post, you advise any bonding jumpers acrossthe engine mounts are best removed to avoid parallel grounds. Equally,the Connection speaks of a single point ground at firewall. Is this acontradiction or does it refer to not having jumpers between twoMy first post to this site. Im working on an
5
6
7
8
9
5
6
7
8
9
RV-8a. Building
PostPosted: Thu May 28, 2009 5:03 pm    Post subject: Engine mount as starter ground path Reply with quote
At 07:34 PM 5/28/2009, you wrote:
Thanks Bob.
Tom
You say "both batteries". Which Z-figure are
you crafting?
Kellym
PostPosted: Thu May 28, 2009 5:12 pm    Post subject: Engine mount as starter ground path Reply with quote
The RV-10 by necessity and design has the battery(s) located in the
tailcone to partly offset the weight of the IO-540 up front.
Given that the structure from the battery location to the firewall is
all riveted aluminum in the lower half of the fuselage there likely is a
solid ground path. Running a fat wire to parallel that ground path, or
to replace it doesn't appear to be all that good an option.
Kelly
Kelly McMullen
KCHD
Goto page 1, 2  Next
Page 1 of 2
