Install CH750 Struts on CH701
arno7452(at)bellsouth.net
PostPosted: Sat May 23, 2009 10:42 am    Post subject: Install CH750 Struts on CH701 Reply with quote
Anyone installed the streamlined struts on a CH701? Parts cost was estimated at $1,000. Lot of money for no more than 5mph increase in cruise.
Think I will wait for 2 axis autopilot instead.
Ken
CH701 912ULS N701LK
craig(at)craigandjean.com
PostPosted: Sat May 23, 2009 12:08 pm    Post subject: Install CH750 Struts on CH701 Reply with quote
Another way to look at it is a 3-5 percent reduction in fuel burn at the same cruise speed. Others have streamlined by wrapping the struts in 0.016. There is a thread over on the Zenith builders site about this.
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Ken Arnold
Sent: Saturday, May 23, 2009 12:39 PM
Subject: Install CH750 Struts on CH701
Ken
CH701 912ULS N701LK
dwilde(at)clearwire.net
PostPosted: Sat May 23, 2009 12:24 pm    Post subject: Install CH750 Struts on CH701 Reply with quote
cruise.
Ken
CH701 912ULS N701LK
Ken: Contact Raven Aviation. They offer a kit for only $275. Their
email is: info(at)ravenaviation.us or snail mail at Raven Aviation, PO Box
378, Kernville, CA 93238.
I plan on buying a set later this year.
Dan Wilde
NYTerminat(at)aol.com
PostPosted: Sat May 23, 2009 2:40 pm    Post subject: Install CH750 Struts on CH701 Reply with quote
Or slip on the plastic streamline struts for about $200 or less.They work well.
Bob Spudis
In a message dated 5/23/2009 4:09:32 P.M. Eastern Daylight Time, craig(at)craigandjean.com writes:
-- Craig
Ken
CH701 912ULS N701LK
Recession-proof vacation ideas. Find free things to do in the U.S.
ricklach
PostPosted: Sat May 23, 2009 9:19 pm    Post subject: Re: Install CH750 Struts on CH701 Reply with quote
I made some wing strut fairings for my 701 and they work fantastic. I gained a minimum of 5MPH cruse and upwards of 10MPH cruse improvement is not unusual. I now cruse between 90MPH to 105MPH. It’s a very different airplane now; it gains speed much faster and doesn’t lose speed nearly as fast now when you pull the throttle. I was so impressed with the performance improvement I decided to market a Wing Strut fairing kit to help pay for my airplane habit. It includes all four fairings and all the hardware needed for the installation for $275. I’ve spent a lot of money on airplanes over the years and this is the best performance improvement for the least amount of money I have ever enjoyed.
Whether you by my kit or some other aero wing strut solution, just do it, you will not be disappointment.
Rick
Raven Aviation
rick(at)ravenaviation.us
701Driver
N35 26.700, W118 16.743
PostPosted: Sat May 23, 2009 9:57 pm    Post subject: Install CH750 Struts on CH701 Reply with quote
Do you have more of a description and/or some photos?
Metal or plastic?
How does it fasten to the steel struts?
How does it install around the aux struts?
Is it easy to retrofit or is it best to install it as you build the plane?
-- Craig
ricklach
PostPosted: Sun May 24, 2009 9:24 am    Post subject: Re: Install CH750 Struts on CH701 Reply with quote
Hi Craig,
Thank you for your inquire about my Wing Strut Fairing Kit. I’ve attached a few pictures of them for your review. To describe the fairings, they are 6061-T6, .016 aluminum cut to size and bent to wrap around the standard, round, 701 strut. They come pre-drilled and ready to install. They are attached to the round factory strut using 3/32 rivets at each end and by the 3/16 bolt attaching the Jury Struts to the Wing Strut. I also provide photo installation instructions and all the rivet hardware to make the installation. After reviewing the attached material please feel free to e-mail me at your convenience with any additional questions you may have about the performance increases or installation.
Thank You
Rick
View of the Wing Strut Fairings at the fuselage attachment point.
 Filesize:  56.71 KB
 Viewed:  14638 Time(s)
Close-up view of the Wing Strut Fairing around the Factory Round Strut.
 Filesize:  31.45 KB
View of the Wing Strut Fairings at the Wing Attachment point.
 Filesize:  45.18 KB
701Driver
PostPosted: Sun May 24, 2009 10:07 am    Post subject: Install CH750 Struts on CH701 Reply with quote
BTW: if you have the money (US$900 as I recall) and want something that
should just drop in then Mark Townsend had this to say last August:
"I have a replacement Streamline strut kit for the 701. I use my custom
extruded strut that I have for my floats and have had CNC fittings on all
ends. This replaces the 4130 tube that you now have. This is not a cheap
alternative, the .016 wrap will provide the cruise increase. I have wrapped
many 701's struts and will continue to do so in the future, but this
streamline strut kit offers a significant quality change to the wrapping of
your struts.
For more information and pictures please visit
http://www.can-zacaviation.com/struts/strut.htm
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com
www.can-zacaviation.com"
-- Craig
lgold(at)quantum-associat
PostPosted: Sun May 24, 2009 5:13 pm    Post subject: Install CH750 Struts on CH701 Reply with quote
If this streamlined strut kit is the one made in Canada and announced about
a year ago, they were very heavy. The .025 teardrop 6061-t6 sheet covers
that you can make yourself added 8-lbs to the plane. I think these struts
were 4 0r 5 times this weight. Am I correct?
Les
PostPosted: Sun May 24, 2009 7:35 pm    Post subject: Install CH750 Struts on CH701 Reply with quote
I don't know the weight. What I quoted from Mark is all I have. But at that
price your wallet will be lighten enough to compensate for the extra weight
of the extrusions. Smile
-- Craig
kmccune
PostPosted: Mon May 25, 2009 6:29 am    Post subject: Re: Install CH750 Struts on CH701 Reply with quote
Don't forget figure in the steel strut weight, when figuring the weight difference, between the faired steel struts and the all aluminum extruded ones.
Kevin
Les
R.W. Emerson (1803-1882)
Dorothy McCune
ricklach
PostPosted: Mon May 25, 2009 8:43 am    Post subject: Re: Install CH750 Struts on CH701 Reply with quote
I think Marks extruded Aero Strut solution is a first class solution. I have no idea how much they weigh but I have a feeling they are heavier than the round steel strut with the .016 aluminum fairing solution. I have not weighed the complete package yet, but I know that all four strut fairings including hardware weigh less than 4.6lbs.
As soon as I can pull a strut with fairing off my airplane I will do that and weigh it. I’ll post the information as soon as I can get it done. My plane is not here right now so it will take until next week.
701Driver
n752ms(at)softcom.net
PostPosted: Mon May 25, 2009 2:34 pm    Post subject: Install CH750 Struts on CH701 Reply with quote
All.
I have Mark's struts and they are about 20 lbs heaver than the round tubes
with fairings on them. They are much more ridged than the round tube, not
that I think the 701 needs it. They certainly look nice and finished and no
question as to the angle of incidence when you mount them, it is built in to
the machined end pieces.
Although there may be some misalignment with the ends ( just like the
factory single piece struts), they fit good, On mine I machined out the
slots a little bigger to make up for the misalignment.
I have never flown with the round tube struts so I can't say how much of a
difference there is between the two. At gross weight I cruse at 5300 rpm at
about 85 mph. I have the Rotax 912 uls and the prop is a Woodcomp with 14
degrees of pitch, wot at level flight is 5800 rpm and 100 mph. I could
increase the pitch a couple of degrees and get some more speed, but that
isn't why I built this plane. Climb out is at 5500 rpm, I could decrease
the pitch and make climb out at 5800 and get better climb but the current
pitch seems fine to fly off my 40, then we will see.
Mark S.
