Help needed re:- flap position indicator wires and an "inter
ptag.dev(at)tiscali.co.uk
PostPosted: Sat May 23, 2009 9:45 pm    Post subject: Help needed re:- flap position indicator wires and an "inter Reply with quote
Hi! all
I have previously had a position indictor failure on my LED bars.
I think I recall that it was the orange wire which does the
potentiometer information transfer? Mine is frozen in the fully up
indication irrespective of where the flaps are.
Can any one confirm?
I have flight tested my new Mode S Garmin 328 Transponder and it works
..except neither Waddington nor Humberside ATC have the aircraft
registration recognition to confirm that function is working OK !
It does have a radio interference problem in that there is an
interrogation blip to be heard in the radio head sets which wasn't there
on the Garmin 320 original set.
Has anyone any suggestions? (Except that I just wasted £1750 !)
Bob H G-PTAG
PS A "bright spark" at Wickenby suggested I infringe at Conningsby where
the Typhoons are based to see if they pick up the registration
information !
craigb(at)onthenet.com.au
PostPosted: Sat May 23, 2009 10:08 pm    Post subject: Help needed re:- flap position indicator wires and an "inter Reply with quote
May be a stupid question re your garmin mode s
but you did put your unique mode S id code into the transponder when you
installed it???
mikenjulie.parkin(at)btin
PostPosted: Sat May 23, 2009 10:42 pm    Post subject: Help needed re:- flap position indicator wires and an "inter Reply with quote
Hello Bob,
See attached diagram. I am not sure that there is much ATC capability for
Mode S interrogation outside the major centres - London, Manchester.
Do not archive.
trim.pdf
 Filename:  trim.pdf
 Filesize:  23.47 KB
 Downloaded:  137 Time(s)
PostPosted: Sun May 24, 2009 3:17 am    Post subject: Help needed re:- flap position indicator wires and an "inter Reply with quote
Hi! Craig
Yes I think so but it uses numerical conversions for the alphabet as per
the old telephone system.
I was not able to check it out due to the inadequate ATC receiver
facilities in this patch !
Bob H G-PTAG
PostPosted: Sun May 24, 2009 10:49 am    Post subject: Help needed re:- flap position indicator wires and an "inter Reply with quote
I am not sure whether you have configured your 328.
Details for set-up are on page 5-16/17 of the installation manual.
Numbers for G-PTAG are:
Binary: 0100_00_000_100_00_0011010100
Hex: 4040D4
Octal: 20040324
Do not archive.
