lgold(at)quantum-associat Guest
Posted: Wed May 20, 2009 10:17 am Post subject: Rotax 912ULS Voltage |
I am a sport pilot and don't fly at night, but took my Zenith 701 /Rotax
912ULS up a few evenings ago just to see how hard it would be to land in the
dark. No problem landing, but with all the extra night time stuff on
(strobes, 55watt landing light, & cabin lights) plus my normal stuff
(intercom, 2GPS's, Dynon 180, ICOM radio, transponder, and intercom) the
voltage went down to 11.9 at 3500-rpm and 12.3V at my 4900-rpm cruse. The
blinding low voltage light (from aeroelectric's Z16 diagram, which I used
for my aircraft) came on for the first time and gave me a scare.
My question; is this low voltage situation normal or do I have voltage
regulation issues?
Without the extra load during daylight flight my voltage runs about
12.9-13.0 V and my battery holds a 12.8V charge. I don't have an extra
alternator and just use the internal Rotax coils for power. One guy already
told me that what I am getting is the norm with the extra stuff on, and that
the Rotax voltage regulator heats up a lot and should not be expected to
last very long. Are these things true?
Thanks for your advice.
Les
Posted: Wed May 20, 2009 10:56 am Post subject: Rotax 912ULS Voltage |
At 01:08 PM 5/20/2009, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Les Goldner" <lgold(at)quantum-associates.com>
regulation issues? |
If the low votlage light is on (bus less than 13.0 volts)
then the alternator is not producing sufficient energy to
carry all of the ship's loads AND maintain a battery.
| Quote: | Without the extra load during daylight flight my voltage runs about
12.9-13.0 V and my battery holds a 12.8V charge. |
This is TOO LOW. No load and engine running should produce
a bus voltage of 14.0 MINIMUM, 14.2 to 14.4 is better. With
a 13.0V set-point, your alternator is not replenishing the
energy used to get the engine started. It's also maintaining
your battery in a very low state of charge, probably less
than 50% of capacity.
| Quote: | I don't have an extra
last very long. Are these things true? |
Not quite. That voltage level is too low. You need to
add up the real current draw for all accessories that
might be on at the same time. These cannot exceed
the rating of the alternator (assuming the battery
is charged) for the operating RPM . . .
[img]cid:.0[/img]
. . . and should not be more than 75% of that rating if
you want the alternator to replenish energy removed
before cruising flight RPMs are achieved.
The stock rectifier/regulator is marginal for the
way we use them. I wish they were a bit more robust.
It would add very little to the cost of the product.
John Deere has some single phase rectifier/regulators
rated in the 30A class. It would be interesting to
see how well these might substitute for the
stock regulator.
( -Thomas Paine 1776- )
97.89 KB |
2971 Time(s) |
franz(at)lastfrontierheli Guest
Posted: Wed May 20, 2009 2:20 pm Post subject: Rotax 912ULS Voltage |
Hi Bob,
Could you please help me with a low voltage problem that I am having in my RV7. Voltage indicators on the Dynon and engine monitor both show fluctuations between 12.5V and 11.5V while in flight. This is something that just started during the last few flights, I have 300h on the airplane with this being the first problem. I have had the ND 60A internally regulated alternator form Vans in the shop and it checked out fine, I also have put in a new battery with no improvements. Airplane wired as per Z11 with an added electronic ignition on the top side
Thanks for any suggestions you may have
Franz
[img]cid:3325677364_135572[/img]
18.73 KB |
2969 Time(s) |
Posted: Mon May 25, 2009 9:40 pm Post subject: Rotax 912ULS Voltage |
Thank you for the information Bob.
I am trying to trouble shoot my low voltage problem to determine its cause (i.e.; the regulator, wiring, or the internal engine alternator) so I can take corrective action.
There is nothing in the Rotax 912 manuals to assist in doing this. I checked the internal engine coil resistance reading and found it to be .7-ohms. The DC voltage at the regulator is the same previously reported (still under 13-volts). Finally I measured AC voltage coming from the coils. The voltage varied as follows:
Idle (1900-RPM) was 12.8 volts
2500-RPM was 16.0 v
3000-RPM was 19.0 v
4000-RPM was 24.5 v
cruse(5000-RPM)was not measured.
Bob, Am I correct to think that the AC voltage looks adequate and the problem is likely a faulty Rotax voltage regulator?
Thanks again for your help.
Les
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Wednesday, May 20, 2009 11:54 AM
Subject: Re: Rotax 912ULS Voltage
regulation issues?
stock regulator.
97.89 KB |
2950 Time(s) |
