rudder trim tab
Goto page 1, 2  Next
lurcottstudios(at)yahoo.c
PostPosted: Sun May 17, 2009 11:02 am    Post subject: rudder trim tab Reply with quote
Greetings,
I have been reading the list here for a while, and want to take the opportunity to say thanks to all of you. I have a Series V with a Lycoming O-235 which is a great source of fun and unending lessons for me. There is one issue that I have, and that is that I must always input right rudder. I expect that at higher power settings, but at cruise? Anyway, I was wondering since the aircraft is already covered and flying is there some add-on type tab that I could affix to the rudder so that I don't have to constantly push on that right side. Cruise requires about 3-4 pounds or so of pressure. If someone has a photo or drawing, I would appreciate that too, as I am very visual. Thanks for any input.
Will Lurcott
Series V
Lyc O-235
Flagler Beach, FL
lcfitt(at)sbcglobal.net
PostPosted: Sun May 17, 2009 6:43 pm    Post subject: rudder trim tab Reply with quote
Will,
I have been told by what I consider to be reliable sources that the engine
mounts designed for the Kitfox engines has no thrust offset - zero offset,
horizontal or vertical so right rudder is essentially built into the design.
I went through this for the first five years of flight on my Model IV and
had difficulty even considering a trim tab simply because it would look like
a bandage. I finally did the deed and it made a world of difference, not
only in cruise, but in the pattern as well. I hated right traffic patterns
because I had real problems coordinating the right rudder pedal with a right
turn. Everything just improved in bunches.
My airplane is gone, but the trim tab was about six inches top to bottom and
extended aft about an inch and a half or so. Overall it was triangular in
shape with a trimmed base so it riveted to the trailing edge and the rib
forward to prevent the trailing edge rivets from working as I adjusted it.
My ribs were of the Speedster style with an airfoil on the horizontal so
what I did there is drill through the rib and using a 4-40 blind nut from a
hobby store on one side and a screw of trimmed length inserted through the
tab. If you don't have the ribs in the rudder, I suppose you could go
through the fabric a bit oversizes and then use a tubular spacer of the
right length to accommodate the space between the 3/8" rib and the fabric,
though that might not be necessary that far back. I couldn't find any clear
photos, so made a drawing. As I recall, I bent the edges of the triangular
portion inward a little bit to create a firm contact with the fabric to
prevent air getting under and possibly lifting the tab.
Lowell
 Filesize:  34.71 KB
 Viewed:  17059 Time(s)
Lynn Matteson
PostPosted: Mon May 18, 2009 2:22 am    Post subject: rudder trim tab Reply with quote
Here is a shot of my present trim tab, soon to be modified with a
servo from the model airplane world, and a controller. The tab looks
larger than it actually is, and I may be shrinking it further. I
staggered the rivets so that it would be more stable, and I attached
it with aluminum rivets so I could "drill it off" when the time came
to hinge it for the servo application. Also, I have since painted it,
so it is a little less obtrusive than it appears.
Lynn Matteson
Jabiru 2200, #2062, 654 hrs
Sensenich 62x46 Wood prop
Status: flying
On May 17, 2009, at 2:56 PM, william lurcott wrote:
Greetings,
Will Lurcott
Series V
Lyc O-235
Flagler Beach, FL
www.matronics.com/contribution _-
 Filesize:  403.12 KB
 Viewed:  17054 Time(s)
Lynn
Kitfox IV-Jabiru 2200
N369LM
kerrjohna(at)comcast.net
PostPosted: Mon May 18, 2009 9:00 am    Post subject: rudder trim tab Reply with quote
Will, I did similar to Lowell with similar results. I place it lower on the rudder at the point of maximum bend so that I could use the geometry of the rudder to provide rigidity.  One thing I have learned on the Hatz is that the rudder is neutral when aligned with the stabilizer offset, not with the centerline of the aircraft
John Kerr
KITFOXZ(at)aol.com
PostPosted: Mon May 18, 2009 2:53 pm    Post subject: rudder trim tab Reply with quote
Hello Will,
My Ship is not yet flying but I wanted to chime in on this thread. I have always believed that an airplane should be built to fly straight and level first. My model building days (and my aeronautical engineer father) taught me to pay particular attention to true alignment and close to perfect airfoils in all aspects of building. A banana shaped fuselage is a curse one never will overcome. A warped wing will be more and more of a liability as the ship picks up speed in it's death spiral to mother earth.
With a straight and true airframe accomplished first, the builder next tackles an engine mount. The engine's propeller will cause a torque turn in the opposite direction of the prop rotation. A shim in the engine mount is the best way to fix the problem in my book. I don't like the idea of having to change more than a little pitch trim when the engine quits. An airplane should glide straight in my opinion. If the engine quits, your hands are already full and I don't want to have to be standing on some rudder too, trying to overcome my trim tab.
Actually, isn't a washer or two under the left engine mount to firewall points a heck of a lot easier than fabricating a trim tab? It's a lot less ugly!
OK, I apologize, John, Lowell, Lynn, your trim tabs are beautiful but, isn't a simple washer for a little right thrust a solution to the point?
If the airplane fly's straight and true naturally and as you add power the right thrust becomes more and more effective to counteract the very torque turn you are trying to kill in the first place. Isn't this a solution near to God and the birds?
Dang propellers anyway!
John P. Marzluf
Columbus, Ohio
Outback (out back in the garage)
In a message dated 5/17/2009 3:03:29 P.M. Eastern Daylight Time, lurcottstudios(at)yahoo.com writes:
Greetings,
Will Lurcott
Series V
Lyc O-235
Flagler Beach, FL
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matron====================================
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
A Good Credit Score is 700 or Above. See Yours in Just 2 Easy Steps!
Lynn Matteson
PostPosted: Mon May 18, 2009 4:58 pm    Post subject: rudder trim tab Reply with quote
Correct me if I'm wrong, but isn't one reason to use the rudder trim
to counteract, for instance, a crosswind while flying, thus removing
the necessity to hold a little rudder to keep the ball centered? At
least that's what I thought I was doing in building a cockpit-
controlled trim tab.
Lynn Matteson
Jabiru 2200, #2062, 655.4 hrs
Status: flying
On May 18, 2009, at 6:51 PM, KITFOXZ(at)aol.com wrote:
Hello Will,
the point?
John P. Marzluf
Columbus, Ohio
Greetings,
Will Lurcott
Series V
Lyc O-235
Flagler Beach, FL
==================================== href="http://www.matronics.com/
==================================== tp://www.matronics.com/
Lynn
N369LM
John,
I agree with you entirely. That is why I resisted the trim tab for so long.
The washer idea didn't occur to me as I was a rank novice in the building
and early flying stages. The trim tab just finally made sense and I did it
and never regretted it. Since then, however, I have been thinking quite a
bit about the whole issue. I am thinking of building my own engine mount
with the offsets built into it, and I have been tinkering with a cockpit
adustable rudder trim as I doubt a washer or two or an offset will
completely negate any yaw tendency at all power settings.
I guess this is as good a time as any to present my rudder trim system. I
have a servo in the rudder that will warp the two bottom ribs giving a
different cambered surface on one side or the other. The ribs are tied
together so I will get an overcamber and undercamber on a desired side, or a
symmetric surface on both sides controllable with a switch in the cockpit.
Of course it has yet to fly, but it is something I have been thinking about
long before the opportunity to build again came up.
Lowell
 Filesize:  170.31 KB
 Viewed:  17039 Time(s)
JetPilot
PostPosted: Mon May 18, 2009 5:41 pm    Post subject: Re: rudder trim tab Reply with quote
There is nothing wrong with trim tabs. All sorts of much more advanced and high performance aircraft use trim tabs. Johns washer idea is a good one, but I doubt it will be enough, and even when you get close to correct, you will still probably get yaw changes with power, which is exactly why many manufactured aircraft have rudder trim. Even modern jet airliners have rudder trim... The theory of building a perfectly straight airplane is good and something to strive for, but the reality is that you will still probably need a trim tab in the end. An electric adjustable rudder tab is even better...
Kolb MK-III Xtra, 912-S
KITFOXZ(at)aol.com
PostPosted: Mon May 18, 2009 6:38 pm    Post subject: rudder trim tab Reply with quote
Lynn, Lowell and Mike, others lurking,
I didn't mean to condemn trim tabs and especially cockpit controlled trim tabs. The point I was hoping to make is that I feel the emphasis should be on building a good airframe that is straight and true. I don't want to have a bird that is all bent up and those imperfections compensated for with hairy items hanging off of every control surface.
These are harsh sounding words I know. I am just trying to make the point with exaggerations. Engine torque is proportional to power setting and so is the resultant yaw. I want to cancel it immediately at it's source with engine thrust line offset. Washers, shims, another engine mount perhaps, are the cleaner ways to make an airplane fly straight. What I want to accomplish is a glide that is straight and true first and then do what has to be done to make the engine pull it in as straight of a path as can be done even with the imperfections of that rotating, torque inducing, P factor producing, wind mill out in front.
Of course a cockpit controlled trim tab is used for cross wind trim and elevator trim is used for load CG variations. But, to permanently bend a control surface to make up for a faulty thrust line is wrong I feel. If your car has a front end alignment problem, do you alter the rear axle alignment to make it go down the road straight? --Albeit in a crab angle?
I love this forum because there are so many points of view that can get aired. Dead horses are beaten. Feelings are even stepped on but, when it all is tallied up some do and don't are discovered. Some best practices are established and airplanes end up flying.
Got to turn in for the night.
John P. Marzluf
Columbus, Ohio
In a message dated 5/18/2009 9:44:39 P.M. Eastern Daylight Time, orcabonita(at)hotmail.com writes:
--> Kitfox-List message posted by: "JetPilot" <orcabonita(at)hotmail.com>
&quot;NO FEAR&quot; -  If you have no fear you did not go as fast as you could have !!!
http://forums.matronics.com/viewtopic.php?p=244575#244575===============================================
_-= the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
propellerdesign(at)tele2.
PostPosted: Mon May 18, 2009 10:29 pm    Post subject: rudder trim tab Reply with quote
Lynn,
you do not compensate for crosswind with the trim tab, you move along with
the mass of air (steady air) at the same speed as it blows, if you don't go
directly in to the wind or with the wind, you have to compensate for the
drift over ground by alter your course.
The rudder compensate for propeller effect and different aileron drag from
left side to right side when airplane is unbalanced in weight distribution
(fuel or people)
The trim tab just take the load off the controls.
Jan
Lynn Matteson
PostPosted: Tue May 19, 2009 2:27 am    Post subject: rudder trim tab Reply with quote
Hi Jan-
I understand the compensation for wind effect by altering the course,
but what got me to thinking about the cockpit-adjustable rudder trim
tab, is that lately I've been playing around with changing speed of
flight by reducing my rpm so that I see less fuel consumption (as
revealed by my fuel flow gauge), and as a result I have noticed that
the ball is slightly off-center at times. I thought that because I
have a ground-adjustable rudder tab right now, which I understand is
only good for a certain speed for any particular setting, that it
would be good to have the cockpit-adjustable rudder tab. Is this not so?
I almost always fly alone, and my fuel usage is pretty even from tank
to tank...that is, side to side, with the 13 gallon tanks in each wing.
Lynn Matteson
Status: flying
On May 19, 2009, at 2:02 AM, JC Propeller Design wrote:
<propellerdesign(at)tele2.se>
Lynn,
along with the mass of air (steady air) at the same speed as it
blows, if you don't go directly in to the wind or with the wind,
you have to compensate for the drift over ground by alter your course.
drag from left side to right side when airplane is unbalanced in
weight distribution (fuel or people)
Jan
Lynn
N369LM
KITFOXZ(at)aol.com
PostPosted: Tue May 19, 2009 2:55 am    Post subject: rudder trim tab Reply with quote
Lowell,
Now THIS IS JUST TOO COOL!!! I will be anxious to find out how effective it will be. Did you reject the idea of putting it in the vertical stabilizer? --Would be more effective and to the point I think. In the photo, it looks like it may be a bit shy on camber changing moment. Do you think it will be enough? --Or are you trying to approach it from a conservative position just to prove the concept? Perhaps I just don't see the potential deflection amount from this angle.  --Although it shouldn't take much. We can't wait! Put that rudder on someone else's bird that is already flying to get the thing producing some numbers! Why aren't you working with the Rutan's? You are a genious!
BTW, The new Boeing 787 has a feature that is interesting: "Variable Camber Wing Trailing Edges"???
Can't wait to learn more about these!
John P. Marzluf
Columbus, Ohio
In a message dated 5/18/2009 8:59:57 P.M. Eastern Daylight Time, lcfitt(at)sbcglobal.net writes:
John,
Lowell
----- Original Message -----
Sent: Monday, May 18, 2009 3:51 PM
Subject: Re: rudder trim tab
Hello Will,
have
level
perfect
one
in
is
hands
too,
less
ugly!
the
torque
John P. Marzluf
Columbus, Ohio
Greetings,
Lycoming O-235
wondering
type
push
If
Will Lurcott
Series V
Lyc  O-235
Flagler Beach, FL
(http://www.matronics.com/Navigator?Kitfox-List)
(http://www.matronics.com/contribution)
**************A Good Credit Score is 700 or Above. See Yours in Just 2
Easy
Steps!
=Mayfooter51809NO115)
An Excellent Cr23248x1201398651/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=MayExcfooter51609NO62>See Yours in Just 2 Easy Steps!
PostPosted: Tue May 19, 2009 3:59 am    Post subject: rudder trim tab Reply with quote
Yes sure,
I might have misunderstood you.
A cockpit adjustable trim tab is better then a fixed, specially when flying
(for longer times) at different speeds. and with high power airplanes with
greater speed range.
Jan
Paul A. Franz, P.E.
PostPosted: Tue May 19, 2009 5:31 am    Post subject: rudder trim tab Reply with quote
I agree but offer a slight correction so as to be consistent with textbooks and exams
and the like. That is "alter your course" should be 'altering your heading'. You could
have a heading that pointed you at the destination but your course would be a modified
catenary. You could choose a heading such that your course would be a straight line.
So you actually alter your heading to affect the course. Rather picky, I know. Just
that this is a common test question.
Clip Clip clip
That is it in a nutshell. Trim is for unloading the control forces.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
"An unlimited power to tax involves, necessarily, a power to
destroy; because there is a limit beyond which no institution and
no property can bear taxation."
-- John Marshall, McCullough v. Maryland, 1819
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Tue May 19, 2009 6:34 am    Post subject: rudder trim tab Reply with quote
Hello All,
Thanks to everyone and to Lowell and Lynn for the photos and drawings. As a side note, my plane glides fine. However, gliding is not the primary M.O. for me. I have been told that if there is a roll tendency, versus a yaw, then the twist of the wings is a factor. Not the issue for me either. Many other aircraft have rudder trim--it just makes sense. I fly for hours at a time, and with different power settings. P-factor, torque, engine offset etc.--- it all boils down to riding that right rudder. If I don't do something soon, my right leg will look like Popeye's arm, and the left will atrophy.
The nicest installation I have seen so far is posted on the teamkitfox web site by Bruce, who goes by Airlina. It utilizes a servo connected to a tab. Additionally, he has a two speed switch for the elevator trim. Really, really nice work. My favorite idea is the one posted by Lowell. Lowell, changing the camber is nothing short of a spectacular idea!!! Indeed, a very Wright idea! I would like to see a few more photos of your project as the idea of no extruding members for trim is very appealing. Great work. Thanks again to all of you for your input!
Will
Series V
Lyc.O-235
Flagler Beach, FL
Tom Jones
PostPosted: Tue May 19, 2009 6:46 am    Post subject: Re: rudder trim tab Reply with quote
[quote="lurcottstudios(at)yahoo.c"]Greetings,
Will Lurcott
Series V
Lyc O-235
Flagler Beach, FL
Will,
Have you thought about an extra adjustable spring or bungee attached to the right rudder pedal? Maybe a stronger spring on the right and weaker on the left? Just thinking out loud.
My prop rotation is left hand. I need to hold just very slight left rudder in cruise to center the ball.
I have thought about a small bungee attached to the left pedal, run it forward to a pully on the fire wall, tie a piece of parachute cord with knots every inch or so on the end and run that back to where I can pull on it and catch the right knot in a notch in a piece of aluminum attached on the front door frame somewhere. Sorry, wordy not visual.
Tom Jones
Classic IV
Ellensburg, WA
Lynn Matteson
PostPosted: Tue May 19, 2009 7:36 am    Post subject: rudder trim tab Reply with quote
I am presently working on a controllable trim tab just like Bruce
Lina's. In fact, I just received the same controller that Bruce used
in his design. Now I'm working on a way to mount the servo...a model
airplane, giant scale servo...into the rudder, and make it secure.
Then I'll worry about running the wire through the fuselage. I've
already got the controller mounting bracket ready to attach to the
panel.....damn! I couldn't find room on the panel itself that was
convenient for the mounting and reaching, so I had to attach it below
and next to the choke, throttle and carb heat bracket. It is very
reachable there, and better than on the console, I believe. This is
the first time that I've had to add something to the plane that
didn't fit into the panel. I'd better run out of ideas pretty soon,
because I've already run out of room. : )
Lynn Matteson
Status: flying
On May 19, 2009, at 10:31 AM, william lurcott wrote:
Hello All,
Will
Series V
Lyc.O-235
Flagler Beach, FL
Lynn
N369LM
PostPosted: Tue May 19, 2009 8:09 am    Post subject: rudder trim tab Reply with quote
Yes you are correct, and I'm glad you make my inglish better. not many on
this list can read Swedish (our little Norway (LN-) friends can) so I
struggle with my inglish!
We can also call the course, track!
as an old skipper I use the words I learned long ago. and in Swedish. like-
kög kk mk where k=kurs-course
I still gets where I want to go.
Jan
Ps, when doing air-towing of gliders sometimes we put both left and right
foot, (shoos) on the starboard (right) pedal, specially on long tows. an
adjustable tab would have been nice.
Michel
PostPosted: Tue May 19, 2009 9:37 am    Post subject: rudder trim tab Reply with quote
From: JC Propeller Design [propellerdesign(at)tele2.se]
.. er, what? Hum, Lima November waking up! Smile
I also reacted to tue use of the rudder trim for crosswind but ... here it is:
The course is the direction in which the aircraft is heading! This is not my definition but the one from the Royal Air Force book my father had under World War II. And, after all, the Brits invented the English language!
So, heading and course are the same thing. The difference is that the Americans call it "heading" and the Brits call it " course" ... of course! (Yes, pun intended!)
The actual path the aircraft is tracing in relation to the ground is called the track.
Another difference between American and British English is that the Americans call the magnetic declination for magnetic variation. In fact, the magnetic variation is, as it name says, the yearly variation of the magnetic declination and the magnetic deviation is what deviates it from nearby magnetic structure.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Lynn Matteson
PostPosted: Tue May 19, 2009 11:06 am    Post subject: rudder trim tab Reply with quote
Permit a rookie to take the chance on embarrassing himself, but I
think heading is the direction that the plane is headed (duh!), and
course is the intended flight path. With no wind, heading and course
are the same direction. With a wind from the left side, heading will
be to the left of the intended destination, and vice versa if the
wind is from the right of the plane. I was flying this morning
pointing at 220 degrees (heading), and my track was 179-181
degrees...pretty good breeze up there!
Lynn Matteson
Jabiru 2200, #2062, 656.1 hrs
Status: flying
... er, what? Hum, Lima November waking up! Smile
here it is:
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
Lynn
N369LM
Goto page 1, 2  Next
Page 1 of 2
