Posted: Sun May 17, 2009 6:33 pm Post subject: EXP2BUS and non-functioning alternator |
At 05:08 PM 5/16/2009, you wrote:
I discovered that the IG lead to the alternator was only producing
12V when measured disconnected. As soon as a load was applied that
went down to 1.5V. It turns out that some filings had got under
the legs of an IRF4905 Mosfet and seemed to have shorted the pins.
So, new question: Does anyone know how to test whether the cleaned
up IRF4905 still works, and what the pinouts might be. There are
three legs, but nothing I've read tells me what leg does what.
See:
http://www.irf.com/product-info/datasheets/data/irf4905s.pdf
| Quote: | Would I have to remove the IRF4905 from the board to test it's output?
I wouldn't think so . . . but I'm mystified as to how
an IRF4905 might be used to control an alternator. This
is a really husky device. Far larger than necessary
to effect control of the IG lead of an alternator. Do
you have a schematic of the EXP2BUS product? I wasn't
able to find anything useful on the website.
( -Thomas Paine 1776- )
ianxbrown
Posted: Mon May 18, 2009 7:33 am Post subject: EXP2BUS and non-functioning alternator |
I have the installation manual (attached) but it doesn't have a
conventional circuit diagram. There is a logical layout in Figure 7,
and a physical layout in Figure 3 (the IRF4905 is at J17) and a photo on
the front page, which also shows it's location.
There is evidence that the track leading from the Source pin on the
IRF4905 has overheated, but I have yet to check it for continuity (meter
is at the airport).
Ian
On Sun, 2009-05-17 at 21:31 -0500, Robert L. Nuckolls, III wrote:
See:
 Download |
| Filename: |
EXP2-C_installation_manual.pdf |
338.65 KB |
| Downloaded: |
2326 Time(s) |
