Upper intersection leg fairing
orchidman
PostPosted: Fri May 15, 2009 5:11 pm    Post subject: Upper intersection leg fairing Reply with quote
I can't find any comments on Tim's or Deems site about how you construct the upper leg intersection fairing.
Are you applying the 2 layers of glass to each one? If so, are you doing it on the plane? If so, how are you holding it to the fuselage while applying the glass?
I have trimmed the fairings and drilled the 4 holes and clecoed them to the fuselage. I am happy so far. Now how do you add the glass while the clecos are holding the fairing in place? Shocked
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Deems Davis
PostPosted: Fri May 15, 2009 6:05 pm    Post subject: Upper intersection leg fairing Reply with quote
I built them up with additional layers of glass before fitting to the
fuse. here's a link to a photo album:
http://deemsrv10.com/album/Sec%2048%20Gear%20Leg%20&%20Wheel%20Fairings/slides/DSC03905.html
follow the links on the left of the page to additional pictures.
Here's links to the build log:
http://deemsrv10.com/48-10&48-11.htm
http://deemsrv10.com/48-11&48-12.htm
I later decided to attach the lower intersection fairings directly to
the wheel pants, Additional pictures:
http://deemsrv10.com/album/Sec%2048%20Gear%20Leg%20&%20Wheel%20Fairings/slides/DSC04260.html
Note: I haven't installed these on the 'finished; aircraft yet
Deems
N519PJ 16.5 hrs
I have trimmed the fairings and drilled the 4 holes and clecoed them to the fuselage. I am happy so far. Now how do you add the glass while the clecos are holding the fairing in place? [Shocked]
Gary Blankenbiller
RV10 - # 40674
Final Finishing - SB
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p 44232#244232
partner14
PostPosted: Fri May 15, 2009 9:40 pm    Post subject: Upper intersection leg fairing Reply with quote
I didn't like the way the Van's uppers fit, so we built our own.
Make sure you max the tape prior to applying the glass.
Don McDonald
--- On Fri, 5/15/09, orchidman <gary(at)wingscc.com> wrote:
Subject: Upper intersection leg fairing
Date: Friday, May 15, 2009, 6:11 PM
--> RV10-List message posted by: "orchidman" <gary(at)wingscc.com (gary(at)wingscc.com)>
Gary Blankenbiller
RV10 - # 40674
(N2GB registered)
http://forums.matronics.com/viewtopic.php?p=244232#24423om/Navigator?RV10-List" target=_blank>http://www.matronics.com/Navigator? - MATRONICS WEB FORUM; -Matt Dralle, List Admin==========
 Filesize:  245.5 KB
 Viewed:  4415 Time(s)
 Filesize:  370.32 KB
 Filesize:  197.3 KB
Don A. McDonald
40636
Mike Whisky
PostPosted: Fri May 15, 2009 10:39 pm    Post subject: Re: Upper intersection leg fairing Reply with quote
Hi Don,
what is the name of the blue stuff that you used to model the fairing with?
Michael
RV-10 builder (flying)
#511
partner14
PostPosted: Sat May 16, 2009 5:33 am    Post subject: Upper intersection leg fairing Reply with quote
Clay...... wife bought it at Michael's.  Easy to form, not as easy to get it all off.... but that doesn't matter much.... after you get off what you can, use a heat gun.... but don't burn the glass.... it kind of rolls right off.
Don
--- On Fri, 5/15/09, Michael Wellenzohn <rv-10(at)wellenzohn.net> wrote:
Subject: Re: Upper intersection leg fairing
Date: Friday, May 15, 2009, 11:39 PM
--> RV10-List message posted by: "Michael Wellenzohn" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
Hi Don,
Michael
RV-10 builder (engine, prop, finishing)
#511
http://forums.matronics.com/viewtopic.php?pht="http://forums.matronics.com/" target=_blank>http://forums.matronics.c &nbsf="http://www.matronics.com/contribution" =======
Don A. McDonald
40636
orchidman
PostPosted: Sat May 16, 2009 6:02 am    Post subject: Re: Upper intersection leg fairing Reply with quote
Deems
N519PJ 16.5 hrs
Deems,
I saw those to pages but didn't read them slow enough the first time. It
is falling into place. This is the last thing to do construction wise. Now if I
can just get the Feds out. They are scheduled this next week and I hope
to be taking off exactly one week from now. SUBJECT TO CHANGE! Very Happy
Thanks all.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
pitts_pilot(at)bellsouth.
PostPosted: Sat May 16, 2009 8:50 am    Post subject: Upper intersection leg fairing Reply with quote
You can also get blue foam insulation from Lowes or other building
supply places. My Home Depot didn't have it. It's messy, but I think
it'll dissolve with gasoline.
Linn
rolls right off.
Don
<http://us.mc01g.mail.yahoo.com/mc/compose?to=rv-10(at)wellenzohn.net>>
Hi Don,
fairing with?
Michael
#511
<http://forums.matronics.com/viewtopic.php?p 44246#244246>ht="http://forums.matronics.com/"
<http://www.matronics.com/Navigator?RV10-List>
Checked by AVG - www.avg.com
