Any ideas how to aid instrument panel hardware alignment?
rparigor(at)suffolk.lib.n
PostPosted: Thu May 14, 2009 11:13 pm    Post subject: Any ideas how to aid instrument panel hardware alignment? Reply with quote
At moment in process of mounting instrument panel.
Any ideas on how to make a ramp/guide/shelf near lower mounting to aid installiation would be appreciated.
Thx.
Ron Parigoris
Visit - www.EuropaOwners.org
craigb(at)onthenet.com.au
PostPosted: Fri May 15, 2009 12:18 am    Post subject: Any ideas how to aid instrument panel hardware alignment? Reply with quote
One way I saw, and copied was to put a narrow lip around the inside of the
panel and then fix bolts into the lip
so they protrude through the firewall from the inside, that way the bolts
are concealed and it is easy to put nuts
on the firewall side. you can then just slide the panel in and spin a nut on
with the other hand. One thing i would
suggest is you make a cardboard template to drill the holes in both the
firewall and the panel lip or you may have
problems lining up the holes for the bolts
craig
g-iani(at)ntlworld.com
PostPosted: Fri May 15, 2009 2:43 am    Post subject: Any ideas how to aid instrument panel hardware alignment? Reply with quote
Ron
What Craig has described is set out as LAA Standard Mod 10402. This is
available on the Club site.
I have "guide rails" on which the panel slides as you install it. This was
achieved by having the lower area over the tunnel attached to the tunnel
(not the panel). The benefit of this is that my mag switch, choke and all
the leads to my EIS stay in place when you remove the panel. Have a look at
the picture. It was a lot of work to create this but it works well. If you
are interested e-mail me of the forum and I can send you more details.
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.comththe
 Filesize:  86.25 KB
 Viewed:  3224 Time(s)
rampil
PostPosted: Fri May 15, 2009 5:15 am    Post subject: Re: Any ideas how to aid instrument panel hardware alignment Reply with quote
An extra shelf or mounting bracket is unnecessary. The panel does
quite well hanging on the top bolts and resting on the tunnel. I would
not close the gap between the bottom panel and the firewall because
it aids ventilation. My panel does not move or vibrate even during 3-4g
akro.
Ira N224XS
fklein(at)orcasonline.com
PostPosted: Fri May 15, 2009 10:47 am    Post subject: Any ideas how to aid instrument panel hardware alignment? Reply with quote
Ron,
If your question concerns facilitating alignment of bolt holes when
positioning the instrument panel module, you might consider (after
bolting the panel in place) making some splash molds along the port
and starboard underside between module and fuselage sides. The module
would rest on these as you install the module and push it forward into
place...simple, out of the way, light weight.
Though I've beefed up the forward flange and installed about 10
vibration/isolation bolts, you raise an issue I've yet to
address...not sure how big of a concern it will be...
Good luck,
Fred
believed to be clean.
