Tri-gear wheel fairing
frans(at)paardnatuurlijk.
PostPosted: Thu May 14, 2009 11:30 am    Post subject: Tri-gear wheel fairing Reply with quote
Hi all,
While working today on the nose wheel fairing, I noticed that the top of
the front halve is highly asymmetrical.
Now, having gone through all sorts of puzzles with it, it looks like it
is not my fault.
The starboard side next to the hole of the wheel shaft is noticably
lower than the port side. If I wouldn ignore the scribings on the top,
and redrill the hole on the top centered around the highest point, the
hole would be no longer in the middle, offset to the port side. If I
flex the front halve so that it appears to be right, the bottom is
slanted and doesn't align with the wheel hole on the rear halve anymore.
It drives me nuts.
As these fairings are coming from a mold, I suspect that all the nose
wheel fairings are asymmetrical. if this is true, other builders should
have experienced the same.
Has anyone found an easy fix for this?
Or, do I just have a bad individual fairing? In that case I would be
better off to swap it.
Can anyone show me a picture of their nose wheel fairing, taken right
from the centerline?
Frans Veldman
s(at)vestuti.orangehome.c
PostPosted: Thu May 14, 2009 12:08 pm    Post subject: Tri-gear wheel fairing Reply with quote
Hi Frans,
Mine was exactly as you describe, i just did my best with it.
its difficult to notice when its all together and painted,
i'll see if i can get a picture uploaded,
Steve.
Visit - www.EuropaOwners.org
budyerly(at)msn.com
PostPosted: Thu May 14, 2009 12:42 pm    Post subject: Tri-gear wheel fairing Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Frans,
Yes it is wonky, and it is not your fault. I've done probably 5 sets and helped three or four customer and they are all the same. Bad plug made from someone elses' bad mould? (It appears subcontractors copy parts from other manufacturers and pass them off. My assumption is based on the fact that one time I purchased a similar nose pant from another manufacturer that was exactly the same as the original moulder who used to make them for Europa. Somebody copied somebody.)
I have made a plug and mould for my custom fairings because I felt filling was too cumbersome. Really it is more expensive, and time consuming for me to make the mould from my plug. But that is my problem. Getting a plug perfect is a pain isn't it.
What I normally do is put the two halves together and heat to get the shape close. I then cut the pant just above the curve on the left side bottom if the bottom looks too stupidly sloped. Cut about two to four inches back on the bottom side. You need to reinforce that area anyway. Spring it to where you want it. Usually lean it to the side about 1/4 inch. I use heat to shape and then super glue and a couple of sticks to hold the shape I want, then add back three layers on the inside. Fill the outside gap and cover with a single layer. Put the two haves together, sand and fill.
I promise to send my squared up pant to Roger to fix the factory subcontractors mould. That is when I get it straight. I'm on version two.
Bud Yerly
PostPosted: Fri May 15, 2009 9:02 am    Post subject: Tri-gear wheel fairing Reply with quote
ALAN YERLY wrote:
Frans, Yes it is wonky, and it is not your fault. I've done probably
Thanks very much for your confirmation. Now that I know that the
fairings are not going to be right if I follow the manual, I started to
experiment a little.
By coincidence, I found the secret!
Actually, it is very simple to get these things straight. The ONLY thing
you need to do, is to leave a gap on the bottom of the port flange. This
will make the fairing straight, viewed from all angles! No heating
necessary, no cutting needed at the bottom, no filling at the top, nothing.
The only thing you will have to do is to extend the port flange a little
bit to attach the bottom anchor nut, and use some expancel to fill the gap.
It seems that the only error the factory made was to cut the port side
of the front half at the wrong angle.
About the pictures:
Keep in mind that this is preliminary fitting. Even the anchor nuts are
not attached, the bolts are just inserted through the holes to keep
everything temporary in place. (Should have used cleco's for this, but I
already drilled the holes before I discovered that these fairings are
wonky).
The white shaft you see is my 2 inch nose wheel shaft extension, to
allow for a larger prop. The metal ring you see just above the wheel
spat is the fork, and is very usefull to provide a straight reference.
Then, for the folks curious about my nose wheel shaft extension, cowling
mod, and prop, a picture of the entire nose section. Again, this is far
from finished, but gives an idea how it will look like when all is finished.
Frans Veldman
 Filesize:  60.07 KB
 Viewed:  5978 Time(s)
 Filesize:  64.16 KB
 Filesize:  55.21 KB
fklein(at)orcasonline.com
PostPosted: Fri May 15, 2009 10:43 am    Post subject: Tri-gear wheel fairing Reply with quote
About the pictures:
are
but I
wonky).
Frans,
Nice crisp and clear explanation of a simple solution to the nose gear
fairing.
And your prop looks great...[at first glance, I thought I saw some de-
icing boots on its leading edge...Smile ].
May I ask what your prop diameter is?
Fred
believed to be clean.
budyerly(at)msn.com
PostPosted: Fri May 15, 2009 12:05 pm    Post subject: Tri-gear wheel fairing Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Looks great, I never thought of that Frans, looks fast and easy.
Good job,
Bud
PostPosted: Fri May 15, 2009 12:44 pm    Post subject: Tri-gear wheel fairing Reply with quote
1720mm (that is 67.5").
I have choosen this prop for optimum cruise performance. Large diameter
= high efficiency. 2 blades versus 3 blades = slightly smaller take off
performance, but above 70 knots much more efficient.
And, last but not least, the inner section has very much twist. Again,
during the early stage of the take off this inner section probably
stalls, but at higher speeds it produces lots of thrust. The inboard
section of conventional props most likely produces no thrust a cruise
speeds, or even negative thrust.
Of course, all of this is so far still theoretical. Once I'm finally
flying, I will collect some performance data.
Frans Veldman
PostPosted: Fri May 15, 2009 12:54 pm    Post subject: Tri-gear wheel fairing Reply with quote
I didn't think of that as well. I was just wondering whether I could
force the front half somewhat in the correct direction. To do this, I
attached the starboard side of the front half fairing to the rear half
of the fairing, to be able to bend the port side, and then discovered
that I could get the correct shape, without any bending, but at the cost
of creating a gap at the port seal. If you try to close this gap, the
fairing twists and takes its odd shape again. Leave it alone, and all is
right.
I love to think out solutions, but this one is really a coincidence, not
the result of thinking.
Next time you prepare a speed kit, try it, and let me know if it works
out the same for you.
I think it is a shame that it isn't covered in the manual. These parts
are not really a bargain, I somehow expected that the manual is adjusted
to the experiences of builders (and preferably, not only the manual but
the parts as well).
Frans Veldman
craigb(at)onthenet.com.au
PostPosted: Fri May 15, 2009 3:54 pm    Post subject: Tri-gear wheel fairing Reply with quote
Fred and Frans, may I humbly refer you to the following link with regard to
prop choice etc
After going through this article I am opting for a smaller 4 blade prop,
probably around 60 inches.
http://www.eaa.org/experimenter/articles/2009-02_elippse.asp
PostPosted: Fri May 15, 2009 4:55 pm    Post subject: Tri-gear wheel fairing Reply with quote
regard to
prop choice etc
prop,
Hi Craig...humility helps when one suggests something other than a CS
prop for our beloved Europas...I too have been intrigued by the
Ellipse props and talked them up a bit a couple of years ago after
learning of Paul Lupps' interest in designing something for the
Europa. Glenn Crowder may chime in here as he's said he's ordered a
Lipps prop for his monowheel. Since Paul's interest is in prop design
(rather than marketing ir making props), an RV guy named Jim Smith has
volunteered to handle purchasing paperwork. Jim's email is: elippsefppropsales(at)gmail.com
PostPosted: Sat May 16, 2009 12:23 am    Post subject: Tri-gear wheel fairing Reply with quote
prop choice etc
I know the article. I would love to have such a prop, but as clearly
explained, it only works well if it is carefully designed for a specific
engine-airplane combination. I will certainly keep an eye on it, and
maybe even volunteer to experiment with it once I'm flying.
I don't see the logic of going to a smaller 4 blade prop though. It is
true that with the eliptical design you can have more blades without
drag penalty, but again, this only applies to this eliptical design.
According to the article, most props have considerable drag at the tips,
and with each additional blade, you are increasing this drag. You are
effectively increasing the tip area, the place where the bigges losses
occur due to the spill over from high-pressure to low-pressure area.
Consider this: What would happen if you would cut the wings of your
Europa in half, and put another halved wing on top of your plane? (I
believed it is alled a bi-plane?). You would have the same wing area,
that's right. But you would get more losses, because you doubled the
rather lossy tip area. It is better to have two longer wings than to
have four shorter ones.
Look at Paul's props: He can afford to have multiple blades, because his
tips are so narrow. Four of these would still create less drag than two
of the conventional blade tips. For his props only, having more blades
is beneficial.
With conventional props, it is better to focus on overal blade efficiency.
According to the article, a very important gain comes from the high
twist near the root, converting this area into something usefull.
And that is precisely what my Woodcomp prop does: it has a very large
twist near the root, to allow the root portion of the prop to contribute
to the overall thrust. By minimizing the amount of blades, you minimize
the losses near the tips of the blades. Remember, the losses are highest
at the tips because of the higher speed in that area.
Also, compare this particular Woodcomp prop to the Ellipse prop. The
only thing missing here is the tip, which is way to wide. The root
portion has great similarities. The Woodcomp prop may be quite an
affordable compromise.
If you can somehow lay your hands on a (affordable) 4 blade, elliptical
prop, well, I would beg you to order one for me too.
Frans Veldman
budyerly(at)msn.com
PostPosted: Sat May 16, 2009 6:23 am    Post subject: Tri-gear wheel fairing Reply with quote
Most of the time in a situation like yours, I add glass to the front cover gap, tape it in place on the rear pant where it looks good and fits without flexing (with release tape of course) and allow to cure to fill the gaps. Then sand and fill.
Having made my own entire speed kit, I disagree with your point on being a bargain. Although the nose gear pant is wonky, the gear leg covers are finiky, try making them from scratch or even buying from a third party. It takes me a half day per 5 day week to mold my pants, and wing covers. Gear legs and covers take another two days. Yes they are very nice, but then I have to make the metal parts, get the fasteners and hardware together etc. It still takes 40 hours to do a nice job of alignment, fillets and transitions that allow full gear leg movement without cracking. I have about 60 hours into my set and I will not make another. I'll buy them. The mods to make them fit nicely is far easier. Try doing an RV speed kit sometime....Talk about frustrating.
It is always about life being too short and time is money isn't it.
Bud
PostPosted: Sat May 16, 2009 11:23 am    Post subject: Tri-gear wheel fairing Reply with quote
I think you missed my point. Let me clarify it with a sketch:
Customer: I'm not happy with the TV-set I bought last week.
Seller: Why is that?
C: It doesn't show the color red. It is bad to view movies like this. I
want to swap it for another set.
S: That won't help you.
C: Why not?
S: All these TV-sets have the same problem.
C: But I paid good money for it!
S: Well, actually it is a bargain!
C: A bargain?
S: Yes. I once constructed my own TV-set. Do you know how much work that
is? First of all, you have to make a Printed Circuit Board. You have to
mess with nasty chemicals to etch the traces. It will take quite some
samples and time before you got that right. Then you have to....
C: I don't want to know. I guess you just found out about the problem?
S: No, we have had this problem from the beginning. A couple of years
now actually.
C: A couple of years! Why didn't you fix it?
S: Well, people keep buying these flawed units anyway. Besides, all
electronic devices, like TV-sets, need to be tested for spurious
emissions. We got our FCC certificate, and if we change the TV-set, we
have to go through the testing procedure again.
C: Changing it? It is just fixing it! And besides, what does the color
red have to do with spurious emissions?
S: Well, you know it, I know it, but so are the rules. And we just hate
to have to go through the testing phase again.
C: But what should I do?
S: Well, you can try tapping it on the left side of the panel. That
usually helps.
C: So you know a fix for it?
S: Yes, we use this fix ourselves. We can't show it to potential
customers the way it is.
C: If you know a fix, why don't you put it in the manual? Just a slight
hint that it could be possible that the color red doesn't show, and that
tapping the panel will cure it?
S: Well, it takes time to revise the manual. We don't type that fast.
Furthermore, it would reveal potential customers that our product is
flawed. And besides, it would be cheating. This is part of the challenge
of using our TV-set. We consider that as a plus. And, last but not
least, we love to see on the internet forums how peope struggle with it,
and come up with solutions.
C: So, actually I should be happy?
S: Yes, you should be very happy. It is a bargain, and it is a challenge
for you, to keep you busy. Just watching TV isn't fun if you haven't
gone through all this.
Frans Veldman
budyerly(at)msn.com
PostPosted: Sat May 16, 2009 1:14 pm    Post subject: Tri-gear wheel fairing Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Well put friend.
Bud
paul.the.aviator(at)gmail
PostPosted: Sat May 16, 2009 3:44 pm    Post subject: Tri-gear wheel fairing Reply with quote
Frans,
This is hilarious, (especially since it isn't happening to me).... Please don't ever change my friend and keep up the postings.
Cheers,  Paul
On Sat, May 16, 2009 at 2:19 PM, Frans Veldman <frans(at)paardnatuurlijk.nl (frans(at)paardnatuurlijk.nl)> wrote:
C: Why not?
..........[b]
