What did you do today?
Goto page 1, 2  Next
pdn8r(at)yahoo.com
PostPosted: Wed May 06, 2009 6:09 am    Post subject: What did you do today? Reply with quote
This is a great and encouraging thread. Lets keep it going.
I rolled her outside to day to see her in the Florida sun.
http://www.geocities.com/pdn8r/Outside.jpg
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
 Filesize:  162.75 KB
 Viewed:  27090 Time(s)
PatrickW
PostPosted: Wed May 06, 2009 6:10 pm    Post subject: Re: What did you do today? Reply with quote
I learned how to weld, and then modified my Corvair valve covers, and made a firewall pass-through for the fuel line.
I'll clean these up tomorrow, and if I'm happy with how they turn out I'll paint them and install them. If I don't like them I know I can fix them.
- Pat
 Filesize:  271.48 KB
 Viewed:  27049 Time(s)
GLJSOJ1
PostPosted: Sat May 09, 2009 5:38 pm    Post subject: Re: What did you do today? Reply with quote
I secured the air hoses inside the cowling and put everything back together and then taxied around the airport. I have an inspection lined up in three weeks
 Filesize:  797.19 KB
 Viewed:  26986 Time(s)
601XL N676L FLYING PHASE I
CHESAPEAKE VA
Larry Webber
PostPosted: Sun May 10, 2009 2:48 pm    Post subject: What did you do today? Reply with quote
Hey ALL
i cut fit shaped and welded the oil filler pipe to the valve cover
in the style WW suggested. yesterday i sliced the forward top skin
and installed a rib splitter and instead of riveting i used riv nuts.
this allows me to remove either side of top panel  without removing
the entire panel (easier to work on inside instrument compartment)
Larry Webber/601xl corvair chugger
Subject: Re: What did you do today?
Date: Sat C 9 May 2009 18:38:14 -0700
--> Zenith-List message posted by: "GLJSOJ1" <gljno10(at)hotmail.com>
601XL N676L reserved
ALMOST DONE
CHESAPEAKE VA
http://forums.matronics.com/viewtopic.php?p=243332#243332
http://forums.matronics.com//files/finished_aircraft_005_172.jpg
&gt=======================
Hotmail® has ever-growing storage! Don’t worry about storage limits. Check it out.
how do you eat an elephant ? one bite at a time
kkinney
PostPosted: Sun May 10, 2009 4:29 pm    Post subject: Re: What did you do today? Reply with quote
I worked on taming the rats nest behind the panel and putting shells on the DB connectors. Oh, and EIS6000 fuel level thing.
Kevin Kinney
craig(at)craigandjean.com
PostPosted: Sun May 10, 2009 5:49 pm    Post subject: What did you do today? Reply with quote
I (re)powder coated one of the sub-panels on my instrument panel last night.
BTW: if you ever need to remove powder coat acetone didn't touch it but
Permatex Gasket Remover (item #80646) made short work of it. And it's "known
by the State of California to cause cancer and birth defects or other
reproductive harm"!
Today I'm mounting switches and instruments.
-- Craig
kmccune
PostPosted: Mon May 11, 2009 2:54 am    Post subject: Re: What did you do today? Reply with quote
Made the flaperon rib form blocks yesterday and then cleaned up my so I could move around and find things.
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
Gig Giacona
PostPosted: Mon May 11, 2009 5:14 am    Post subject: Re: What did you do today? Reply with quote
Installed ELT and worked on cabin heat muff.
W.R. "Gig" Giacona
601XL Under Construction
hansriet
PostPosted: Mon May 11, 2009 6:02 am    Post subject: Re: What did you do today? Reply with quote
I researched torque wrenches, to no avail. If anybody has tips, it will be appreciated.
psm(at)att.net
PostPosted: Mon May 11, 2009 6:22 am    Post subject: What did you do today? Reply with quote
Hi Hans,
Harbor Freight has a nice selection of torque wrenches. I have one
of the smaller ones with 3/8 drive and a larger one too.
Paul
XL grounded
jaybannist(at)cs.com
PostPosted: Mon May 11, 2009 6:27 am    Post subject: What did you do today? Reply with quote
Everyone should have on their computer a copy of John Schwaner's "Mechanic's Toolbox". There you will find everything you need to know about torque wrenches and their use; and lots and lots of other valuable stuff.
Jay Bannister
carlossa52(at)gmail.com
PostPosted: Mon May 11, 2009 8:28 am    Post subject: What did you do today? Reply with quote
Kitplanes June 2009 mentions a digital wrench from Sears
About US$200, if I am not mistaken
Carlos
2009/5/11 hansriet <hansinla(at)mac.com (hansinla(at)mac.com)>
[quote]--> Zenith-List message posted by: "hansriet" <hansinla(at)mac.com (hansinla(at)mac.com)>
PostPosted: Mon May 11, 2009 8:35 am    Post subject: What did you do today? Reply with quote
For foot pounds the standard "torsion bar" or beam ones from Sears are
dandy. It is in the lower ranges (inch pounds) where it gets tough. The
imported "click" style don't keep their accuracy. To get a good "click"
torque wrench you have to spend some dough and get a name brand like
Snap-On.
You can have a good wrench and use it the wrong way and be way off. For
example on the beam wrenches the plastic handle pivots on the steel shaft
through an axle. If you don't hold it such that the handle is floating free
with the force only transmitted through the axle then the reading will be
off.
I went with a strain gauge based Computorq 3 from CDI. The 1/4 inch drive
model has a range of 2 to 20 foot pounds or 24 to 240 inch pounds. You enter
the target on the display and as you approach a yellow light comes on. When
you reach the target a green light comes on. Accompanying sound effects
allow you to torque where you can't see the wrench. Lots of people sell them
and prices vary widely - just google "cdi computorq3"
You can take the whole thing to an extreme. Some would have you calibrate
the wrench before each use. The section on torque in the Sky Ranch
Engineering Manual is a good read.
-- Craig
Jeyoung65(at)aol.com
PostPosted: Mon May 11, 2009 9:10 am    Post subject: What did you do today? Reply with quote
Not sure this is the best wrench for self-locking nuts. You should check
the torque required to run the bolt through on self-locking section of the
nuts and add it to the torque you are using. Most are well below 24 inch
pounds. Jerry of GA DO NOT ARCHIVE
In a message dated 5/11/2009 11:37:22 A.M. Eastern Standard Time,
craig(at)craigandjean.com writes:
PostPosted: Mon May 11, 2009 9:48 am    Post subject: What did you do today? Reply with quote
Yes, I know. I posted the message below last year in March. I avoid the
issue by not reusing small self-locking nuts. What wrench do you use?
-- Craig
The stuff I read said that you measure the drag torque with your torque
wrench before the nut starts touching the surface to be clamped. For the
small nuts I couldn't do this with my CompuTorq3 electronic wrench as it
doesn't start registering until 20 or so inch-pounds. I guessed around 5
inch-pounds. What I finally found that helped was table 7-2 in AC 43.13-1B
(Acceptable Methods.). "Minimum prevailing torque values for re-used
self-locking nuts". This tells you how much drag torque a SL nut needs to
have for it to be safe to reuse it. I reasoned that this must be a pretty
good guide to the minimum drag in a *new* SL nut.
For fine threads the table says:
7/16-20 8 in-lbs
1/2-20 10 in-lbs
9/16-18 13 in-lbs
Larry Webber
PostPosted: Mon May 11, 2009 4:32 pm    Post subject: What did you do today? Reply with quote
Craig  im new to powder coat painting   ? can you paint a powder paint over
an existing standard base paint provided you have sanded first?   i used a powder on my valve covers which i sand blasted C wire wheeled  and for  all purposes were raw metal finish
i  then baked in oven 300  until no more smoke was visible cooled then powder painted and was very pleased with finish. they will be seen at CC#14 in Lowell Ma. on the 22nd of this month
Larry
Subject: RE: Re: What did you do today?
Date: Sun C 10 May 2009 19:45:10 -0600
--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com>
reproductive harm"!
[quote] _=====
Insert movie times and more without leaving Hotmail®. See how.
PostPosted: Mon May 11, 2009 6:12 pm    Post subject: What did you do today? Reply with quote
Are you saying that even after your prep’ed you still had some old conventional paint on the surface? Everything I have read says you have to have bare metal or a first layer of the same powder coat. Since you will cure it at 400-450 degrees F I’d be worried about the effect of the high heat on the old paint. But everything I have done was new aluminum so I don’t have much to go on. The nice thing about aluminum is that no matter how bad your oven is the whole item quickly reaches a uniform temperature.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Lawrence Webber
Sent: Monday, May 11, 2009 6:30 PM
an existing standard base paint provided you have sanded first? i used a powder on my valve covers which i sand blasted, wire wheeled and for all purposes were raw metal finish
Larry
> From: craig(at)craigandjean.com
> To: zenith-list(at)matronics.com
> Date: Sun, 10 May 2009 19:45:10 -0600
> reproductive harm"!
> _=====
JohnDRead(at)aol.com
PostPosted: Mon May 11, 2009 6:51 pm    Post subject: What did you do today? Reply with quote
Sears has a good one, about $70.00 as I recall. It was within 1 in. oz when I check calibration. do not archive.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 5/11/2009 8:07:34 A.M. Mountain Daylight Time, hansinla(at)mac.com writes:
--> Zenith-List message posted by: "hansriet" <hansinla(at)mac.com>
http://forums.matronics.com/viewtopic.php?p=243526#243526===============================================
_-= the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps!
dredmoody(at)cox.net
PostPosted: Tue May 12, 2009 1:44 am    Post subject: What did you do today? Reply with quote
Finished putting on the red detail stripes and added anti-chaffing tape between the upper and lower cowl sections. Then I made one more walk-around to make sure everything will be ready for first flight if the weather cooperates this weekend. Building has been fun but after all... the objective has always been to fly.
Ed Moody II
601XL/Jabiru/Sensenich GA
N4568G "Papa Goose"
Larry Webber
PostPosted: Tue May 12, 2009 9:32 am    Post subject: What did you do today? Reply with quote
the first ones i did were bare metal these came out great
now i would like ti try on old but prepped existing in other words not bare metal
Larry
Date: Mon C 11 May 2009 20:04:12 -0600
.ExternalClass .EC_shape {;} .ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.EC_HTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.EC_EmailStyle20 {font-family:'Calibri' C'sans-serif';color:#1F497D;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
-- Craig
Sent: Monday C May 11 C 2009 6:30 PM
Larry
reproductive harm"!
_=====
0Hotmail® has ever-growing storage! Don’t worry about storage limits. Check it out. [quote][b]
Goto page 1, 2  Next
Page 1 of 2
