A bit of corrosion...
jochs(at)froody.org
PostPosted: Thu May 07, 2009 12:44 pm    Post subject: A bit of corrosion... Reply with quote
Hi all,
I got some aluminum cleaner on one of my elevator skins accidently
(see attached) and didn't notice it was there until it left some
corrosion on the skin. I'm just getting to the tailcone, so it is
going to be a while before I was going to paint (I'm planning to paint
after the fly-off period so it will be a couple of years) Is this
something I need to worry about? Should I clean it off, and if so,
what should I use and how to ensure I don't make it worse?
One other thing I thought of is to use the corrosion protection that I
am using and put that on the outside of the skins. I am using
Sanchem 6100 and they say you don't have to put the sealer on top of
it if you are going to paint, and that you don't have to paint or
prime immediately. If any of you are using the Sanchem stuff what are
your recommendations?
James
#40400
RV-10 finishing up elevators/trim tabs
http://www.froody.org/heartofgold/
 Filesize:  149.1 KB
 Viewed:  1824 Time(s)
chaskuss(at)yahoo.com
PostPosted: Thu May 07, 2009 2:25 pm    Post subject: A bit of corrosion... Reply with quote
James,
Polish the corrosion off of the affected areas, using your 2" Roloc ScotchBrite discs. Use the fine (blue) discs to do this. Once you have cleaned the area, reapply the Sanchem to the area you cleaned.
Charlie Kuss
--- On Thu, 5/7/09, James Ochs <jochs(at)froody.org> wrote:
Subject: A bit of corrosion...
To: rv-list(at)matronics.com
Date: Thursday, May 7, 2009, 4:36 PM
Hi all,
accidently (see attached) and didn't notice it was there
until it left some corrosion on the skin. I'm just
getting to the tailcone, so it is going to be a while before
I was going to paint (I'm planning to paint after the
if so, what should I use and how to ensure I don't make
it worse?
protection that I am using and put that on the outside of
the skins. I am using Sanchem 6100 and they say you
don't have to put the sealer on top of it if you are
stuff what are your recommendations?
James
-- #40400
