daveleikam(at)wi.rr.com Guest
Posted: Tue May 05, 2009 7:48 pm Post subject: G900X AHRS & remote compass |
Does anyone have pictures of where they installed the AHRS and remote compass for a G900X system?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
robin1(at)mrmoisture.com Guest
Posted: Tue May 05, 2009 9:15 pm Post subject: G900X AHRS & remote compass |
Does this help?
Robin
583.51 KB |
7313 Time(s) |
vhicy(at)bigpond.com Guest
Posted: Tue May 05, 2009 9:51 pm Post subject: G900X AHRS & remote compass |
Robin my only concern would be the harness atach cables. We installed our unit at the top of the baulkhead to get away from them
Chris
Posted: Tue May 05, 2009 10:49 pm Post subject: G900X AHRS & remote compass |
Stainless Steel hardware.
Every problem has a solution, just add dollars.
If this was not S/S they definitely will interfere with the electronics. You may still have to do the same. These are really sensitive devices.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie
Sent: Tuesday, May 05, 2009 10:49 PM
Subject: Re: G900X AHRS & remote compass
Chris
0123456789
Checked by AVG - www.avg.com
05/05/09 13:07:00
ron.mcgann(at)baesystems. Guest
Posted: Tue May 05, 2009 11:19 pm Post subject: G900X AHRS & remote compass |
You know I reckon that may be the problem with my installation as well – where do you get the stainless steel harness attach cables? (My AHRS/Mag tray is in almost the same position).
Ron
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Wednesday, 6 May 2009 4:18 PM
Subject: RE: G900X AHRS & remote compass
Robin
Chris
| Quote: | | http://forums.matronics.com |
| Quote: | | http://www.matronics.com/contribution |
05/05/09 13:07:00 [quote] "Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
Posted: Wed May 06, 2009 12:20 am Post subject: G900X AHRS & remote compass |
Ron,
I was going to suggest you look at that but I was not following the thread that closely and didn’t want to add my 2 cents when it’s not worth a penny. I knew long before the install that we were going with S/S so we never had the stock units in place to see exactly how the interference presented itself on the display. I suspect if you just jiggle it while your avionics are on it may show you. If I recall you had a slight turn anomaly in only one direction? If so I doubt it’s the harness cables. I assume (bad idea) that the changes would be back & forth vs. only in one direction.
Can someone can suggest a supplier for Ron as I am on the road (again) and don’t have my records handy.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Wednesday, May 06, 2009 12:18 AM
Ron
Robin
Chris
speckter(at)comcast.net Guest
Posted: Wed May 06, 2009 4:20 am Post subject: G900X AHRS & remote compass |
I followed the recommendation from Garmin and put the AHRS on the mount from Van and the Magnitromiter in the tail like they picture in the manual.
It works great
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Thursday, June 04, 2009 10:46 PM
To: RV-10 matronics
Subject: G900X AHRS & remote compass
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Wed May 06, 2009 4:23 am Post subject: G900X AHRS & remote compass |
Nice picture! Thinking more about the electronic slip indicator .....
what's it do sitting still on the ground??? The other post about the
AHRS being out of cal makes sense. If it's accurate on the ground ....
or taxiing straight and out in flight I think points to a true slip.
Linn
Robin Marks wrote:
| Quote: | Does this help?
Robin
stein(at)steinair.com Guest
Posted: Wed May 06, 2009 7:54 am Post subject: G900X AHRS & remote compass |
The harness attach cables haven't really been a big problem in the RV-10's with the G900X Remote Mag in that area, but the attach bolts usually are. If either one of them causes an issue anyway, you can usually just degauss it....at least that's been our experience with lots of these RV10's with G900X's in them. Chris's solution isn't a bad one either, you just need to make sure it's fairly robust as well.
Stein
[quote] --
Tim Olson
Posted: Wed May 06, 2009 8:44 am Post subject: G900X AHRS & remote compass |
Although mine isn't a G900X, the same theory applies and I
haven't seen a problem after the system is calibrated. You
can move the cables all you want and nothing changes. I
did use Brass hardware to mount the units though. But
used standard hardware on the cable ends. A good calibration
helps get rid of the iron effects on some systems.
Tim Olson - RV-10 N104CD
SteinAir, Inc. wrote:
[quote] The harness attach cables haven't really been a big problem in the
Stein
rv10free2fly(at)yahoo.com Guest
Posted: Wed May 06, 2009 3:13 pm Post subject: G900X AHRS & remote compass |
Any pictures of each install please Gary?
Patrick
South Oz
Sent: Wednesday, 6 May, 2009 9:45:44 PM
It works great
Gary Specketer
To: RV-10 matronics
Subject: RV10-List: G900X AHRS & remote compass
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego , WI
| Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com | 012
The new Internet Explorer 8 optimised for Yahoo!7: Faster, Safer, Easier. [url=http://au.rd.yahoo.com/search/ie8/mailtagline/*http://us.lrd.yahoo.com/_ylc=X3oDMTJxbnQwdTJhBF9zAzIxNDIwMjU2NTkEdG1fZG1lY2gDVGV4dCBMaW5rBHRtX2xuawNVMTEwMzQ0OAR0bV9uZXQDWWFob28hBHRtX3BvcwN0YWdsaW5lBHRtX3BwdHkDYXVueg--/SIG=11k6t9t1c/**http://downloads.yahoo.com/au/internetexplorer/]Get it now.[/url]. [quote][b]
Could try Hooker Harness?
Pat
Sent: Wednesday, 6 May, 2009 5:46:47 PM
Ron,
Robin
Subject: RE: RV10-List: G900X AHRS & remote compass
Ron
Robin
Chris
Posted: Wed May 06, 2009 3:49 pm Post subject: G900X AHRS & remote compass |
No, but there are pix in the Garmin install manual. I could make copies and send them snail mail or Stein probably could send you electronic copies.
Sorry
Gary Specketer
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis
Sent: Wednesday, May 06, 2009 6:13 PM
Patrick
South Oz
It works great
Gary Specketer
To: RV-10 matronics
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego , WI
| Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution htt="http://forums.matronics.com/" target=_blank rel=nofollow>http://for - List Contribution://www.matronics.com/contribution" target=_blank rel=nofollow>http://ww====================== |
The new Internet Explorer 8 optimised for Yahoo!7: Faster, Safer, Easier. [url=http://au.rd.yahoo.com/search/ie8/mailtagline/*http:/us.lrd.yahoo.com/_ylc=X3oDMTJxbnQwdTJhBF9zAzIxNDIwMjU2NTkEdG1fZG1lY2gDVGV4dCBMaW5rBHRtX2xuawNVMTEwMzQ0OAR0bV9uZXQDWWFob28hBHRtX3BvcwN0YWdsaW5lBHRtX3BwdHkDYXVueg--/SIG=11k6t9t1c/**http:/downloads.yahoo.com/au/internetexplorer/]Get it now.[/url]. 0123456789 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 5 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 6 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 7 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 8
