K Dilks
tiethoff
Posted: Mon May 04, 2009 2:49 am Post subject: Wing locker questions. |
It's going to open during take-off and has the effect of spoilers. So
take -off speed is going up and stall speed is going up.
Sent: Monday, May 04, 2009 12:33 PM
To: <zenith601-list(at)matronics.com>
Subject: Wing locker questions.
Does any one know how many of the unexplained crashed XLs had wing
lockers?
Any ideas on what would happen if one was to open in flight? Not good for
sure.
Just finished my second locker and was wondering as the dzus fasteners are
not very tight, no real "click" when doing them up.
Just keeping busy building............. :
Austria .............
http://forums.matronics.com/viewtopic.php?p 42598#242598
Thruster87
Posted: Mon May 04, 2009 3:28 am Post subject: Re: Wing locker questions. |
If you are worried about the fasteners opening you can place a small O-ring under it [not under the head but under the lower surface /tail] to put a bit of compression loading and it also stops the fasteners falling out once undone. Cheers
hansriet
Posted: Mon May 04, 2009 5:48 am Post subject: Re: Wing locker questions. |
Or buy the grommets that are made for this function. They are 6 cents a piece at ACS. ( GP5B BLACK THERMOPLASTIC HALF GROM. )
By the way if you don't hear a click, you should check your installation
Hans
jerryvmd
Posted: Mon May 04, 2009 6:48 am Post subject: Wing locker questions. |
List:
I hate to admit this, but about 3 years ago I was in a hurry after doing
some maintenance and did not do a complete pre-flight as I had flown the
plane about an hour prior. Well I had failed to close the right wing
locker on my 601HD. As soon as I took off, the locker came open and the
right wing dropped. I was able to control the flight with opposite
stick almost fully deflected. Went around the pattern and landed
without incident. SO it is controllable if one comes open but avoid
brown underwear stains and check your lockers before EACH flight.
Jerry
K Dilks wrote:
Does any one know how many of the unexplained crashed XLs had wing lockers?
Any ideas on what would happen if one was to open in flight? Not good for sure.
Just finished my second locker and was wondering as the dzus fasteners are not very tight, no real "click" when doing them up.
daveaustin2(at)primus.ca Guest
Posted: Mon May 04, 2009 12:39 pm Post subject: Wing locker questions. |
Wing locker check at pre-flight is absolutely imperative. I know one pilot
who managed to get back down safely and one who was burned very badly when
he crash landed. All the lift goes on that side.
Dave Austin 601HDS - 912
Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Mon May 04, 2009 3:43 pm Post subject: Re: Wing locker questions. |
I have changed my clips from the supplied ones to the quarter turn Cam Locks. These seem to have a better locking position. I have also increased the number that are shown on the plans. I have talked to some pilots that have use the standard number and they have said that the locker still lifts up a bit. He was using the washer under the fastener and it still looked like the locker wanted to lift up a little.
Ianrat
rsteele(at)rjsit.com Guest
Posted: Mon May 04, 2009 6:43 pm Post subject: Wing locker questions. |
A stiffener was added to to the wing locker cover for the 650 vs the
601. (L angle, longitudinally between the fore/aft stiffeners,
roughly centered).
This should help the cover hold its shape, but I think a couple more
fasteners couldn't hurt either.
Ron
On May 4, 2009, at 7:43 PM, Ianrat wrote:
little.
Ianrat
http://forums.matronics.com/viewtopic.php?p 42732#242732
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
z601(at)anemicaardvark.co Guest
Posted: Sat May 09, 2009 6:16 am Post subject: Wing locker questions. |
On Friday 08 May 2009 21:24, Tim Juhl wrote:
In my experience DZUS fasteners hold quite well. The cowlings and panels
on the WWII B25 I used to crew used a bunch of them. I also have them on
my Champ and they've never failed in 34 years
But are these in the same configuration as those on the Zenith? There's no
positive retention mechanism on these as they are intended to be installed. If
you tip the wing locker up, they fall out.
I've used Dzus fasteners before with good success also. But they weren't
configured as these are.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Posted: Sat May 09, 2009 7:06 am Post subject: Wing locker questions. |
Hi Jim,
I'd recommend you make some nylon washers from milk jugs to retain the
Dzus fasteners or purchase
the same from Aircraft Spruce labeled as thermoplastic GP half grommet
types for about .06 each.
These will secure the studs and keep you from loosing any.
Jim Belcher wrote:
Do not archive.
Jim B Belcher
A&P/IA
bryanmmartin
Posted: Sat May 09, 2009 7:07 am Post subject: Wing locker questions. |
You can get plastic half grommets from Aircraft Spruce that snap on to
the dzus fastener and hold it captive in the panel. These are part
number GP3B, GP4B, etc. The number corresponds to the diameter of the
stud in 16ths of an inch. They also carry more expensive metal
grommets that require special tools to install.
On May 9, 2009, at 10:15 AM, Jim Belcher wrote:
There's no
installed. If
weren't
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
bryanmmartin
Posted: Sat May 09, 2009 7:09 am Post subject: Wing locker questions. |
See: http://www.aircraftspruce.com/catalog/hapages/grommets.php
bottom of page, Half Grommets.
| Quote: | But are these in the same configuration as those on the Zenith?
There's no
installed. If
weren't
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
tonyplane(at)bellsouth.ne Guest
Posted: Sat May 09, 2009 7:21 am Post subject: Wing locker questions. |
I used appropriate diameter "O" rings from my Harbor Freight "O" ring kit.
They have worked well to retain the fasteners for about 4 years. Just slip
them over the fasteners "stud" end.
Tony Graziano
XL/Jab N493TG
naumuk(at)windstream.net Guest
Posted: Sat May 09, 2009 7:40 am Post subject: Wing locker questions. |
All-
After many hours I managed to get the DZUS to work properly on my
lockers but I still have no faith in their ability to hold securely. Since I
have locker tanks, the best compromise I could come up with is a
modification of what Klaus' (Sorry, I can't remember his last name)
extensive airflow tests on his HDS indicated.
I intend to secure the main section of the locker with screws and
nutplates, then add a small hatch to access the filler spout. Mind you, I
made this decision after I got the DZUS to work. The small hatch would
create minimal airflow disturbance if it opened, yet you can still get in
for inspection or maintenance purposes. I know of several builders who
simply didn't add the locker option. Just another option.
Bill
Posted: Sat May 09, 2009 8:15 am Post subject: Wing locker questions. |
On Saturday 09 May 2009 09:58, LarryMcFarland wrote:
<larry(at)macsmachine.com>
Hi Jim,
Thanks for the tip! What I wound up doing was to use "O" rings. That held the
fasteners in place, and also pushed against the fasteners when the locker is
closed, making it more secure.
My response was really directed towards the fact that some Dzus fastener
installations really are secure. But, as designed, those in the 601XL aren't.
Mathematics and alcohol do not mix.
Do not drink and derive.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Retired Aerospace Technical Manager
Posted: Sat May 09, 2009 8:16 am Post subject: Wing locker questions. |
On Saturday 09 May 2009 10:21, T. Graziano wrote:
<tonyplane(at)bellsouth.net>
Same place I got mine.
Jim B. Belcher
A&P/IA
Tim Juhl
Posted: Sat May 09, 2009 11:44 am Post subject: Re: Wing locker questions. |
I should have added that I used the thermoplastic grommets that Bryan recommended when I installed the dzus fasteners on my XL wings. When I installed the springs I dimpled the rivet holes and used a flat head on the rivet puller. The hole in the dzus strip is large enough to accommodate dished part of the plastic grommet. The fasteners supplied with my kit hold the cover very snuggly and flush with the wing skin. I did add a third stiffener in the middle of the cover to help it hold it's shape.
On the B25 most of the Dzus fasteners were not held in place by grommets. Our biggest problem was with the springs inasmuch as 40+ years of vibrating next to a 1700 hp radial engine took it's toll. From time to time we would find one missing but we never lost a panel. I would suspect that you could lose most of the fasteners on a wing locker cover without worrying about losing it. The forward hinge won't let it go anywhere while the dzus fasteners will hold it flush.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
