Windscreen Support Brace
planecrazzzy
PostPosted: Sat Mar 25, 2006 3:06 pm    Post subject: Windscreen Support Brace Reply with quote
Hey Guys,
You might have read about the trouble I had with my Windscreen on my second flight....
Someday I'll make a "Full enclosure" , but for now I put a brace in the windscreen.... I cut the Aluminum Tubing at 4' 10" and bent it around something 15" Dia.
I put some tape on the Lexan to make my marks....
I used 1/8" SS rivets , and I drilled the Lexan bigger ( 5/32 )
Afterwards I pulled off the tape , some of the adhesive stayed on...
I cleaned it off with Mineral Spirits....Then I cleaned the whole windscreen with some of my disposable CD cleaner cloths....( Rubbing Alcohol ) It cleaned it VERY GOOD and didn't scratch it....
Here's some Pictures....
 Filesize:  60.45 KB
 Viewed:  375 Time(s)
 Filesize:  59.72 KB
 Viewed:  395 Time(s)
 Filesize:  61.17 KB
 Viewed:  409 Time(s)
 Filesize:  61.47 KB
 Viewed:  392 Time(s)
 Filesize:  62.08 KB
 Viewed:  391 Time(s)
 Filesize:  59.67 KB
 Viewed:  381 Time(s)
Eugene Zimmerman
PostPosted: Sat Mar 25, 2006 5:19 pm    Post subject: Windscreen Support Brace Reply with quote
Congratulations on a good job!
Very nice plane!
I like your beautifully upholstered seats.
planecrazzzy
PostPosted: Sat Mar 25, 2006 6:37 pm    Post subject: Re: Windscreen Support Brace Reply with quote
Thanks...
http://www.matronics.com/photoshare/planecrazzzy(at)lycos.com.06.06.2004/
http://www.matronics.com/photoshare/planecrazzzy(at)lycos.com.07.09.2004/
Gotta Fly...
Mike in MN / N381PM
This address won't put the " (at) " in the post.....???? ( it can be changed after it's "copied and Pasted" )
HEY Matt,
Why can't the "A" with the circle around it, ( at ) be posted???
