rv10rob(at)gmail.com Guest
Posted: Thu Apr 30, 2009 5:11 pm Post subject: "forest of tabs" location on firewall |
I'm trying to do much of the wiring on my -10 now, so I need to put the common ground somewhere. Does anyone have know of a good place to put the B&C "forest of tabs" on the firewall (both sides of the firewall, as described in Bob's book)? I'll be doing the FWF by the plans (except for the grounds, I suppose).
Thanks...
-Rob
ricksked(at)embarqmail.co Guest
Posted: Thu Apr 30, 2009 5:50 pm Post subject: "forest of tabs" location on firewall |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> I put mine up next to the brake reservoir. I didn't need any tabs on the firewall side, dedicated grounds ran into the cabin using bulkhead AMP connectors. The engine is also grounded to the same tab plate through the 3/8 mounting bolt.
Sent via BlackBerry by AT&T
Date: Thu, 30 Apr 2009 18:10:20 -0700
Subject: RV10-List: "forest of tabs" location on firewall
I'm trying to do much of the wiring on my -10 now, so I need to pu= t the common ground somewhere.=A0 Does anyone have know of a good place to = put the B&C "forest of tabs" on the firewall (both sides of t= he firewall, as described in Bob's book)?=A0 I'll be doing the FWF = by the plans (except for the grounds, I suppose).
=A0
Thanks...
=A0
-Rob
| Quote: | | _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - List Contribution Web Site - _-=3D Thank you for your generous support! _-=3D -Matt Dralle, List Admin. _-=3D --> http://www.matronics.com/contribution _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
MauleDriver(at)nc.rr.com Guest
Posted: Thu Apr 30, 2009 6:11 pm Post subject: "forest of tabs" location on firewall |
This has worked well for me so far... at least no regrets so far. You can locate this by reference to the brake fluid resevoir. Access to the cockpit side is primarily thru one of the holes the plans suggest you make in the instrument panel bulkhead. I'm wiring it up now.
Bill "wiring like crazy" Watson
Rob Kochman wrote: | Quote: | I'm trying to do much of the wiring on my -10 now, so I need to put the common ground somewhere. Does anyone have know of a good place to put the B&C "forest of tabs" on the firewall (both sides of the firewall, as described in Bob's book)? I'll be doing the FWF by the plans (except for the grounds, I suppose).
Thanks...
-Rob
768.76 KB |
4762 Time(s) |
roadmaps
Posted: Fri May 01, 2009 11:11 am Post subject: "forest of tabs" location on firewall |
Rob,
I put mine of the inside of the firewall on the far left and ran a #2 ground from the rear battery. On the engine side I ran a braided cable from the mounting bolt to the engine. There was really nothing to ground on the engine side of the firewall. As it ended up most of the grounds came from the avionics and I put 3 10-tab ground ‘buses’ (got from Stein) next to/on the avionics stack.
John Testement
N311RV flying
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver Watson
Sent: Thursday, April 30, 2009 10:11 PM
Subject: Re: RV10-List: "forest of tabs" location on firewall
Thanks...
-Rob
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution |
Checked by AVG - www.avg.com
04/29/09 06:37:00
bcondrey
Posted: Fri May 01, 2009 11:44 am Post subject: "forest of tabs" location on firewall |
There are a number of potential items on the engine side of the firewall are pressure senders, pressure switches, hall effect current sensor, tach generator for RPM pickup, etc. Depending on your installation you might have all, none or any combination. Also, some sensors will ground through the case and others have a ground wire. I think I’ve got 4 items grounded on the engine side of the firewall.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement
Sent: Friday, May 01, 2009 2:11 PM
Subject: RE: RV10-List: "forest of tabs" location on firewall
Rob,
John Testement
N311RV flying
Thanks...
-Rob
04/29/09 06:37:00 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 5
Posted: Sun May 03, 2009 9:04 am Post subject: "forest of tabs" location on firewall |
Thanks, guys for the advice; very helpful. I think I'll go with the same spot Bill shows in his picture. I stumbled across a pic of Van's prototype that seems to show it's a good location, too:
http://www.myrv10.com/N610RV/undercowl/P0003082.html
-Rob
On Fri, May 1, 2009 at 12:43 PM, Condrey, Bob (US SSA) <bob.condrey(at)baesystems.com (bob.condrey(at)baesystems.com)> wrote:
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of John Testement
Subject: RE: "forest of tabs" location on firewall
Rob,
John Testement
N311RV flying
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Bill Mauledriver Watson
Subject: Re: "forest of tabs" location on firewall
Thanks...
-Rob
www.avg.com
04/29/09 06:37:00 0 1 2
3 4567
8
Rob Kochman
RV-10 Wings
Woodinville, WA (near Seattle)
http://kochman.net/N819K
