jhankin(at)planters.net Guest
Posted: Fri May 01, 2009 7:07 am Post subject: Torque setting |
Help!!
I know someone can help—I need to know the torque value of the bolts used to hold the 447 “B” gearbox together.
There are six bolts: Hex Screws # (2) 8X125, (2) 8x110, (2) 8x65.
I have a oil drip and I want to re-torque these bolts first. If this doesn’t fix the problem I will replace the gasket.
Also need the torque value for the prop bolts, Tennessee wooden prop.
Where can these torque values be found.
Jimmy Hankinson
FF035, N6007L
325 Hours
Pegasus Field
Rocky Ford, Ga.
912 863 7384
aslsa.rng(at)gmail.com Guest
Posted: Fri May 01, 2009 7:14 am Post subject: Torque setting |
Jimmy, Go to the Illustrated Parts Catalogue. It has torque requirements for every screw or bolt used by Rotax.
Rick
On Fri, May 1, 2009 at 10:06 AM, Jmmy Hankinson <jhankin(at)planters.net (jhankin(at)planters.net)> wrote:
Help!!
Jimmy Hankinson
FF035, N6007L
325 Hours
Pegasus Field
Rocky Ford, Ga.
912 863 7384
==== get="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution [/b] |
herbgh(at)nctc.com Guest
Posted: Fri May 01, 2009 7:33 am Post subject: Torque setting |
well....I went to the Tenn Prop site , thinking I would find their recommendation...no luck...Memory tells me that it is 10 to 12 ft lbs... Herb
At 10:06 AM 5/1/2009, you wrote:
[quote]Help!!
I know someone can helpI need to know the torque value of the bolts used to hold the 447 “B” gearbox together.
Jimmy Hankinson
FF035, N6007L
325 Hours
Pegasus Field
Rocky Ford, Ga.
912 863 7384
Thom Riddle
Posted: Fri May 01, 2009 8:56 am Post subject: Re: Torque setting |
LEAF's most recent parts catalog (2007-2008 Resource Guide) has table of torques for the various engines on page 91. It lists the torques for bolts based on diameter with an exception list by part number below that. I've attached an image of the top of that page.
| Rotax 2-stroke torque specs (LEAF catalog). |
 Download |
| Filename: |
Rotax 2-stroke torque specs.pdf |
2.52 MB |
| Downloaded: |
509 Time(s) |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Sat May 02, 2009 6:29 pm Post subject: Re: Torque setting |
| jhankin(at)planters.net wrote: | Help!!
Jimmy Hankinson
Jimmy,
I took the Rotax 2 stroke class last month. They provided a repair manual. In the manual when it talks about reassembling the B gearbox it says:
"Attach cover with 6 hex hd screws M8 and spring washer and tighten crosswise to 24 Nm (210 in. lb.)"
Where exactly is it leaking?
I'm sure you know this, but the oil is to be filled only to the lower drain plug. When I first checked my plane after buying it they had filled it up too much.
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
