Corrosion Prevention Kitfox welded tube joints
lcfitt(at)sbcglobal.net
PostPosted: Tue Apr 28, 2009 3:05 pm    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
I did the deed. To illustrate the discontinuity of the tubing in the
Kitfox, I took two sections I cut out of a couple of projects and attached
filled balloons to the ends of the tubes. The yellow tubing came from an
elevator cut to fit a trim tab. The blue tubing came from the hat rack area
where that tubing was cut out to in an attempt to
improve the shoulder harness attachment points.
In the yellow tubing section, the long tube is the trailing edge with the
tube rib the closed end tube. In the blue tubing section, what appears to
be the long section is actually two tubes butted to the short piece which is
continuous.
Lowell
 Filesize:  99.62 KB
 Viewed:  8983 Time(s)
Lynn Matteson
PostPosted: Tue Apr 28, 2009 3:40 pm    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
For what it's worth, when I removed my horizontal stab supports (so I
could weld on the larger 1/4" rod ends) and cut one end off, I could
smell the line oil (tube seal) inside the tubing.
Lynn Matteson
Jabiru 2200, #2062, 635.2 hrs
Sensenich 62x46
Status: flying
the Kitfox, I took two sections I cut out of a couple of projects
and attached filled balloons to the ends of the tubes. The yellow
tubing came from an elevator cut to fit a trim tab. The blue
tubing came from the hat rack area where that tubing was cut out to
in an attempt to
with the tube rib the closed end tube. In the blue tubing section,
what appears to be the long section is actually two tubes butted to
the short piece which is continuous.
Lowell
Lynn
Kitfox IV-Jabiru 2200
N369LM
Float Flyr
PostPosted: Tue Apr 28, 2009 4:18 pm    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
Looking at the big blob of beading on the plue piece it doesn't surprise me
that it is closed off inside the weld. The yellow one is a lot harder to
tell and I'm actually surprised that it is just but welded without first
being cut out and shaped.
Thanks Lowell
Noel
Rhyme not intended
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Tue Apr 28, 2009 4:33 pm    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
Maybe Kitfox LLC inhibits the frames at the factory. John would know for
sure!
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Tue Apr 28, 2009 5:40 pm    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
Usually I give up by now, but here goes. Noel, lets say you are fabricating
a fuselage on a jig. First the longerons on one side, top and bottom, are
clamped into the jig. then the vertical stringers and angle supports are
trimmed, as you discribe, to mate with each other without overlapping
anywhere in a nice tidy cluster. What treatement do you give the longeron
to ensure internal continuity. Do you notch it as you did the stringers or
do you drill a hole at the center of the cluster?
As you all recall, this thread started with advice on introducing a sealant
into the Kitfox tube interiors as a corrosion preventive.
With regard to the first paragraph, Kitfox did notch the tubing to get a
close joint, but they did not drill or otherwise provide for continuity
throughout the tubing interiors. And my opinion is this. I would not fly
in an airplane that would have the number of holes drilled that would be
necessary to protect every tube interior throughout the airplane, especially
if the holes were drilled by an amateur builder.
Lowell
Float Flyr
PostPosted: Tue Apr 28, 2009 7:32 pm    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
I would probably go along with you on that... but aren't the frames made at
a professional company by experts with many years of training and
experience? I watched a certified welder do a cluster joint one time. I
figure it took him several hours to get ready to do the actual welding. I
actually turned down a job e did for our AMO at one time. The joint was
full of pin holes and slag all over the place. Well everyone can have a bad
day. Just haven't yet figured out which one of us was having the hard day.
Him for the poor welding job or me for having to bring it to his attention.
His second try was excellent.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Wed Apr 29, 2009 2:05 am    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
Slag? On a MIG or TIG weld? Surely he did not use a (slag-generating)
stick (arc) welder?
Lynn Matteson
Sensenich 62x46
Status: flying
frames made at
time. I
welding. I
joint was
have a bad
hard day.
attention.
Noel
Lynn
N369LM
akflyer
PostPosted: Wed Apr 29, 2009 5:16 am    Post subject: Re: Corrosion Prevention Kitfox welded tube joints Reply with quote
You can get slag inclusions on both mig and tig. Slag is defined as a non-metallic inclusion in the weldement. If the filler wire is not cleaned properly, you can indeed leave nice little slag inclusions in the form of silicon.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
PostPosted: Wed Apr 29, 2009 5:49 am    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
Hell no it was just an off day for him. He let a job go that he knew he
never should have. I was just unlucky enough to find it and report it ot my
boss who ordered it redone.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Wed Apr 29, 2009 5:51 am    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
Lynn:
I forgot to mention that it was a TIG weld. Stick and MIG are not used in
certified welds here. I think there is some applications for Oxy/Fuel
welding. (a.k.a. oxy acetlyne)
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Wed Apr 29, 2009 7:35 am    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
Hmmmm.....I was thinking only of the thick crap that is left after an
arc job. Maybe my welds are so clean, there is no slag to speak
of....and I'll sell a bottle of snake oil to go along with that
excuse. : )
Lynn Matteson
Sensenich 62x46
Status: flying
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 41893#241893
Lynn
N369LM
Lynn Matteson
PostPosted: Wed Apr 29, 2009 7:37 am    Post subject: Corrosion Prevention Kitfox welded tube joints Reply with quote
I wasn't even thinking of it being a certified weld...I guess I
didn't read the thing thoroughly enough...my bad.
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 29, 2009, at 9:51 AM, Noel Loveys wrote:
Lynn:
used in
Noel
Lynn
N369LM
