Dual static line runs?
tomhanaway
PostPosted: Sun Apr 26, 2009 3:36 am    Post subject: Dual static line runs? Reply with quote
Trutrak suggests that a large # of demands on static line may cause lag in auto pilot. Their suggestion is to run two static lines forward to panel IF this occurs.
My current panel is two AFS 4500's, one AFS 3400, 2&1/4" backup altimeter and airspeed, trutrak adi and vsvg2 autopilot , and 430w garmin stack for demands on static line.
Has anyone actually found a need for a second static line (still using just the original two static ports) or is one sufficient?
I'd like to avoid second line but if I'm going to run one, now's the time.
Tom H.
Tim Olson
PostPosted: Sun Apr 26, 2009 5:02 am    Post subject: Dual static line runs? Reply with quote
I used that Tygon tubing for static and I've not seen any problems
even with at least 7 items tapped off of it. I'm not sure if tubing
size for other types of tubing would have an effect or not, but
I can only say that what I'm using seems to be fine. I'd give
it a try I guess before you worry about pulling more lines, because
unless you add 2 more static ports, I don't know that adding the
additional volume of another line would be a good thing.
tomhanaway wrote:
<tomhanaway(at)comcast.net>
time.
Thanks, Tom H.
http://forums.matronics.com/viewtopic.php?p 41293#241293
jesse(at)saintaviation.co
PostPosted: Sun Apr 26, 2009 5:06 am    Post subject: Dual static line runs? Reply with quote
I have not seen the need for 2 static lines. If you are worried about
it, you can put your Auto Pilot closest to the static port in your
routing, then your EFIS, then your backup instruments.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
the time.
Tom H.
Tim Olson
PostPosted: Sun Apr 26, 2009 5:29 am    Post subject: Dual static line runs? Reply with quote
I'd keep the altimeter and air data instruments closest in all cases
if you find any issues. Knowing the correct altitude on an IMC
approach is more important than how quickly the autopilot reacts.
But, I doubt you'd have a problem.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
> time.
> Thanks,
> Tom H.
rene(at)felker.com
PostPosted: Sun Apr 26, 2009 5:55 am    Post subject: Dual static line runs? Reply with quote
I agree with Tim and Jesse and have not seen a need for it. I also agree
with Tim that I wonder if it even would do any good without another set of
ports.....the tubing ID is so much bigger than the static port opening. I
am not a fluid dynamics expert....but I did stay in a Condo in Park City
Last night. I have the following off of may static system....
Backup altimeter
Backup ADI
Backup AS indicator
Autopilot
Grand Rapids EFIS
Blue mountain EFIS
AOA
My autopilot works great....
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Dick Sipp
PostPosted: Sun Apr 26, 2009 5:58 am    Post subject: Dual static line runs? Reply with quote
I would have to agree wtih Tim and Jesse, I also have multiple taps and all
static related indications are
very close.
Dick Sipp
N110DV 130 hours
jim(at)CombsFive.Com
PostPosted: Sun Apr 26, 2009 12:14 pm    Post subject: Dual static line runs? Reply with quote
That is weird. Is this specified in the manuals? There is no flow in either the static or the pitot system, only pressure. Very low pressures to boot. Is that something someone told you on the phone?really curious.Jim C--> RV10-List message posted by: "tomhanaway" <tomhanaway(at)comcast.net>Trutrak suggests that a large # of demands on static line may cause lag inauto pilot. Their suggestion is to run two static lines forward to panelIF this occurs.My current panel is two AFS 4500's, one AFS 3400, 2&1/4" backup altimeterand airspeed, trutrak adi and vsvg2 autopilot , and 430w garmin stack fordemands on static line.Has anyone actually found a need for a second static line (still usingjust the original two static ports) or is one sufficient?I'd like to avoid second line but if I'm going to run one, now's thetime.Thanks,Tom H.Read this topic online here:http://forums.matronics.com/viewtopic.php?p 41293#241293 [quote][b]
tomhanaway
PostPosted: Sun Apr 26, 2009 1:29 pm    Post subject: Re: Dual static line runs? Reply with quote
Jim, actually in writing. Page 2 of the vsvg2 install manual (see below). Based on everyone's comments, it sounds like the single line has sufficient volume. I'm using the safeair 1 system.
Thanks to all. One more "mental demon" put to rest.
Tom
Pitot and Static Connections
All multi-servo TruTrak autopilots require connections to the pitot and static lines. The preferred method of this connection
would be tee fittings near the aircraft’s altimeter. The static line for the autopilot requires due care in its construction, as
excessive lag or insufficient static orifices can cause the autopilot to oscillate (hunt) in pitch. Although there is compensation
within the autopilot sufficient to handle moderate amounts of lag, the importance of a good static port and line cannot be
overstated. In some cases problems can be caused by having a large number of devices (including the autopilot) connected to a
single, insufficient, static port. In other cases, the static line itself is adequate but there are one or more devices connected to the
same line, one of which has a large static reservoir. A simple remedy for this problem if it occurs is a tee-fitting near the static
port, and a dedicated line to the autopilot only.
Obviously, an insufficiently-large orifice coupled with large static reservoirs
can aggravate the problems associated with lag.
PostPosted: Sun Apr 26, 2009 5:32 pm    Post subject: Dual static line runs? Reply with quote
I am currently installing an VSGV DII and missed that statement. I could see where a older mechanical instrument might have a set of "Bellows" and that by itself could set up some pressure fluctuations. The newer electronic EFIS units depend on mems based pressure sensors and would not have any such devices. I have been focusing on the servo installation this weekend. The connections to the control unit will happen this week.Comment for anyone currently running wiring. Run ALL the wires you ever think you might need. Going back and adding them is NOT a fun process.Thanks Tom for the post.Jim CombsN312F Flying (Soon with autopilot!)--> RV10-List message posted by: "tomhanaway" <tomhanaway(at)comcast.net>Jim, actually in writing. Page 2 of the vsvg2 install manual (see below). Based on everyone's comments, it sounds like the single line hassufficient volume. I'm using the safeair 1 system.Thanks to all. One more "mental demon" put to rest.TomPitot and Static ConnectionsAll multi-servo TruTrak autopilots require connections to the pitot andstatic lines. The preferred method of this connectionwould be tee fittings near the aircraftâ&euro;&trade;s altimeter. The static line forthe autopilot requires due care in its construction, asexcessive lag or insufficient static orifices can cause the autopilot tooscillate (hunt) in pitch. Although there is compensationwithin the autopilot sufficient to handle moderate amounts of lag, theimportance of a good static port and line cannot beoverstated. In some cases problems can be caused by having a large numberof devices (including the autopilot) connected to asingle, insufficient, static port. In other cases, the static line itselfis adequate but there are one or more devices connected to thesame line, one of which has a large static reservoir. A simple remedy forthis problem if it occurs is a tee-fitting near the staticport, and a dedicated line to the autopilot only. Obviously, aninsufficiently-large orifice coupled with large static reservoirscan aggravate the problems associated with lag.Read this topic online here:http://forums.matronics.com/viewtopic.php?p 41355#241355 [quote][b]
wayne.e(at)grandecom.net
PostPosted: Mon Apr 27, 2009 3:31 am    Post subject: Dual static line runs? Reply with quote
Tom,
I used the Safeair system also and I have the TruTrak Sorcerer auto pilot and a bunch of other static required instruments and I've had no problems at all. I've also had my instruments IFR certified and they found no problems.
Wayne Edgerton
N602WT flying
