jpspencer(at)cableone.net Guest
Posted: Thu Apr 23, 2009 5:48 pm Post subject: Throttle cables/Rotax 912 |
I have had a lot of problems keeping the carbs synched on my 912 ULS equipped 701. I first installed the Zenith issued setup with the torque tube and cables and never was able to keep the carbs synched with that for very long. I found a pushrod setup that a fellow Zenith builder came up with( can't remember his name but he was a prof from Texas). That design used pushrods from the torque tube on the firewall forward to the carbs. I doubted that would work for me cause every time the motor torqued in the mounts I was afraid it would change the synch, but I tried it anyway, and found it as I expected. So I abandoned that rig and tried to find a way to mount the torque tube to the motor and actually did, using the 2 threaded bosses on the top rear of the rear cylinders, and down braces from the rear of the carb cable holder. But I abandoned that cause I was afraid the bosses would crack out; there isn't much meat there; and that vibration would be transmitted to the carbs from the downbrace. So I am back to square one and I guess about to go back to a cable setup; after all that is what most of these things are running, and have since forever ago, so that must be the "best" setup out there, right? My original cables were spring loaded wide open as they came from ZAC; that was aggravating as hell, fighting the throttle springs all the time and having to lock it every time you wanted to take your hand off it.I am thinking about going to the spring loaded idle type...have any of you done that? Seems like that might be a lot more convenient particularly in the pattern. I don't worry about it quitting and going to idle. I figure if it does then it was probably just "my time".If any of you have experience with the spring load idle please pass it along. Also is it essential that the cable housing/wires be exactly the same length as the ones going to the other carb? I haven't seen anything on that, and it doesn't seem necessarily that they should be but maybe so. I was using the vacumn gauge set from Lockwood, which I found near useless because of gauge fluctuation, which on my particular pair couldn't be adjusted out with the valves. I am using a plastic tube loop with oil in it now which I think is reliable but am wondering if it isn't way too sensitive. Your experience appreciated, and sorry to be so long winded here. Thanks
Joe in Mississippi
Posted: Thu Apr 23, 2009 6:34 pm Post subject: Throttle cables/Rotax 912 |
Have you considered using this:
http://www.mcfarlaneaviation.com/Details.aspx?ID=11744352&Article=199
Throttle Control for Dual Carburetor Rotax Engines
Innovative design allows a neat, clean installation without a clunky splitter box
[img]cid:image001.jpg(at)01C9C452.5AD264F0[/img] - Super-smooth friction lock
- All metal construction
- Teflon lined for smooth, consistent control
- Available in 4, 6, and 8 foot lengths
- Measured from panel fitting to end of conduit, wires extend 6 inches beyond conduit
- Easily trimmed to length
- Longer controls available upon request
- Two knob styles available: Standard or Ball
- Manufactured to the same quality standards as McFarlane's FAA-PMA parts
Specifications: - Panel Fitting: 1/2-20 UNF x 0.67 inch thread
- Slip Fit Conduit Terminals: 2 each with 1/4-28 UNF x 1.00 inch thread
- Conduit: 0.188 inch OD Teflon lined wound conduit
- Inner Wire: Heavy duty 0.062 inch diameter, 1x7 stainless steel twisted wire per MIL-DTL-87161
- Travel (stroke): 3.75 inch maximum
- Design Work Loads:
- Push: Not Applicable (designed for pull loads only)
- Pull: 10 lbs maximum
- Typical Locking Force: 1 to 10 lbs (locking force dependent on friction lock engagement)
- Operating Temperature: -65 to 450 F
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Joe Spencer
Sent: Thursday, April 23, 2009 7:48 PM
To: Zenith701801-List(at)matronics.com
Subject: Throttle cables/Rotax 912
Joe in Mississippi
| Quote: | | http://www.matronics.com/Navigator?Zenith701801-List | 0123456789
8.55 KB |
16600 Time(s) |
8.55 KB |
16600 Time(s) |
Posted: Fri Apr 24, 2009 7:16 am Post subject: Throttle cables/Rotax 912 |
Craig
thanks for the link. I called them this morning with questions. Looks like that may be the simplest solution yet. There is still the problem of the springs but I am hoping to be able to go with a lighter one with this cable setup; they thought so, and maybe be able to rig a simple spring load idle control. I ordered one and will give it a try, and then report back here to all the folks. It's a new production item and won't be available for 1-2 weeks, but I will be glad to wait if it solves some problems.
Thanks again. This internet thing is sumpin else
Joe
will report.
arno7452(at)bellsouth.net Guest
Posted: Fri Apr 24, 2009 7:23 am Post subject: Throttle cables/Rotax 912 |
Joe,
You might want to talk with Jon Croke re: lighter throttle springs.
Ken
John Bolding
Posted: Fri Apr 24, 2009 8:09 am Post subject: Throttle cables/Rotax 912 |
Ken thanks. I will. I had tried lighter springs early on and they wouldn't pull the slack out of the cables good enough to keep the sync. Will see how they work with this new gizmo. BTW to use the new cable I will give up the right side throttle control, but the few times I need it from the pax side I can just reach across...
Joe
ronlee
Posted: Fri Apr 24, 2009 9:19 am Post subject: Re: Throttle cables/Rotax 912 |
After a couple of instances of having my throttle wanting to creep up during warm up I switched from a friction system to a Vernier throttle system. It was a safety issue with me. Now it will not move unless I push the button and move it. It's nice in flight too as I just need to turn the knob to get small throttle changes. I only have one throttle now, but it is easy to reach from the passenger side if necessary.
_________________ Ron Lee
Tucson, Arizona |
randy(at)rjhebertassoc.co Guest
Posted: Fri Apr 24, 2009 9:41 am Post subject: Throttle cables/Rotax 912 |
Ron
Where do you have it located can you post a photo?
Randall J Hebert
Randall J Hebert & Associates, Inc
Consulting Engineers
Ph 337-261-1976 Fx 337-261-1977
dougsnash
Posted: Fri Apr 24, 2009 10:16 am Post subject: Throttle cables/Rotax 912 |
Joe, I'll be a little more insistant about the not using lighter throttle springs. Here is the link to Jon's story on the ch701.com website.
http://www.ch601.org/stories/croke_crash.htm
I agree that the throttle system on the 701/912 is a little wierd but it does work and modifications can be dangerous.
Doug MacDonald
CH-701 Scratch Builder
Final assembly.
NW Ontario, Canada
--- On Fri, 4/24/09, Joe Spencer <jpspencer(at)cableone.net> wrote:
| Quote: | From: Joe Spencer <jpspencer(at)cableone.net>
Date: Friday, April 24, 2009, 10:16 AM
Craig
Joe
will report.
bobkat
Joined: 07 Sep 2008 Posts: 143 Location: Bismarck, ND
Posted: Fri Apr 24, 2009 10:51 am Post subject: Throttle cables/Rotax 912 |
I would have put a vernier type of dual cable throttle on had one been
available, so I put the ordinary one on. Doesn't creep, in fact I haven't
adjusted it for months.
I got mine from ?Aircraft Spruce? or maybe it was Skystar themselves and I
think they had them custom made.
On my 701 I used basically the same sytem as suggested by Zenith, but
instead of that T-handle on both sides I put a regular friction throttle
cable on the left, left out that goofy friction block on that common rod
and put on the stock T-handle to the right in case I ever wanted to fly much
from there. The Kitfox has the throttle control in the center so a second
set up isn't an issue.
Rigged up like this you still have those safety springs on the carbs but
never are aware they are there. Anything happen to the throttle control
mechanism and it'll get you down. At altitude it may not be any big deal,
but over water, trees or near the ground it could be a life saver!
bobkat
Don't worry about the springs, Joe! I almost pranged my kitfox because the original builder had removed them and installed a solid cable push/pull system. Worked perfectly until one day I had taken just taken off when one of the solid cables broke and the carb on that side went to idle. I was able to slip it back in to the very short field with trees on the far end, stopping with the spinner inches from a tree!
So the first thing I did was redo it to the original system. Those springs are there for a reason!
If you use that double cable system above pictured (I put that one on the kitfox) you can easily adjust the throttle tension so you are not aware that the springs are there. And the carbs stay balanced!
But those springs could save your life someday. Isn't there a picture somewhere of a 701 in a grove of trees because lack of those springs?
The original system, especially using those two cabled throttles works really well. If it ain't broke, don't fix it. But for safety's sake leave the springs in.
A bit off topic, but I heard that Rotax was working on a single point throttle tttchemnt system. That will make discussions on the annoying double cable throttle problems and keeping the carbs balanced obsolete! Yeah!
Posted: Fri Apr 24, 2009 11:21 am Post subject: Throttle cables/Rotax 912 |
Ron, thanks. I originally had a vernier on mine from ACS and the Zenith/Rotax supplied springs were so strong they somehow overcame the vernier lock,... pulled the throttle forward! If I could get that to work on mine that would be fine. I ran weaker springs(but not a whole lot weaker) on mine for a while and if I remember correctly, the vernier throttle would hold them, and I didn't have any problems with the throttle not advancing, but did have trouble with carb sync..The only thing is it makes a right seat throttle not usable, but I am ok with that, at this point. I still have the vernier here, I might get it back out and try it again...thanks again
Joe
side if necessary.
Ron Lee
Tucson, Arizona
ronlee
Posted: Fri Apr 24, 2009 4:26 pm Post subject: Re: Throttle cables/Rotax 912 |
I suspect something is not right with the Vernier throttle you have. Mine WILL NOT move unless the button is pushed. I have the original springs on my 912uls.
Tucson, Arizona |
Posted: Fri Apr 24, 2009 5:03 pm Post subject: Throttle cables/Rotax 912 |
Ron Lee
Tucson, Arizona
Don't know, could be...it was brand new from ACS when installed...that would be my luck lately, it seems.
I have come up with a new idea that may work reliably w/o springs. Have some more parts on the way from ACS. Will report.
Good weekend all
Joe
ggower_99(at)yahoo.com Guest
Posted: Fri Apr 24, 2009 5:28 pm Post subject: Throttle cables/Rotax 912 |
about 240 hrs in my 701 with the plans throttle, no problem at all.
KIS. Add only lightness and simplicity to any airplane.
Saludos
Gary Gower
What can you fill a bucket with and make it weight less?
Holes.
--- On Fri, 4/24/09, MacDonald Doug <dougsnash(at)yahoo.com> wrote:
| Quote: | From: MacDonald Doug <dougsnash(at)yahoo.com>
Subject: Re: Throttle cables/Rotax 912
To: zenith701801-list(at)matronics.com
Date: Friday, April 24, 2009, 2:14 PM
| Quote: | --> Zenith701801-List message posted by: MacDonald Doug
Doug MacDonald
Final assembly.
NW Ontario, Canada
Craig
Joe
will report.
Posted: Fri Apr 24, 2009 5:32 pm Post subject: Throttle cables/Rotax 912 |
Sincerely I dont understand wht, in the first place they designed the engine with two carbs...
Could be so simple to do as Jabiru, one single carb (same type)
--- On Fri, 4/24/09, BokKat <bobkat(at)btinet.net> wrote:
[quote]From: BokKat <bobkat(at)btinet.net>
Date: Friday, April 24, 2009, 2:30 PM
Posted: Sat Apr 25, 2009 6:53 am Post subject: Throttle cables/Rotax 912 |
>KIS.- Add only lightness and simplicity to any airplane
Amen. In fact KISS is the 2nd reason(spring fight is first) I would like to get away from the ZAC throttle design...if I can make 2 Cessna type push/pull cables from a common throw work then I can get away from the springs and torque tube, and all those bicycle type cables. That may not work either but will give it a try. When mine was rigged without springs it was so much nicer to fly...just like a normal airplane. But the carbs wouldn't stay synched.Some of all this I think depends on your expectations, as some are perfectly happy with the plans rig. Others not.
As to why 2 carbs on the 912...mainly I think it is for high power/weight. But it does add a lot of complexity, as does the water cooling and the external oil tank and all those oil lines and the gearbox. Complicated and fussy...it's kinda like automatic that when you decide to go with a Rotax you are giving up simplicity. I would have much rather had a Continental or Lycoming but they are too heavy and won't perform...that is if you are interested in radical, optimal STOL, anyway. So I reluctantly bought the Rotax cause, for me anyway, radical STOL is about the only reason for this plane's existence. There are better choices if good all around performance and nice flying qualities are what one wants...but man will it ever come out of the hole!!
Joe
the green one on utube
