ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Sun Apr 19, 2009 1:18 pm Post subject: Re: New M3X Flies ! |
Ok ! The prop I am running on my Jabiru is a Sensenich,wood,W58djl44---ae9623...hope this helps...we are going to have some crappy weather here in Mi so it will be a bit before I get a chance to post anymore numbers.
chris ambrose
m3x-jab
924.95 KB |
8473 Time(s) |
pj.ladd(at)btinternet.com Guest
Posted: Mon Apr 20, 2009 5:52 am Post subject: New M3X Flies ! |
Sensenich,wood,W58djl44---ae9623..>>
Hi Chris,
what does that mean in feet and inches or even centimetres?
My reprt of 10knot climb at 50mph should have been 1000ft per min.
Pat
herbgh(at)nctc.com Guest
Posted: Mon Apr 20, 2009 6:03 am Post subject: New M3X Flies ! |
Pat
Not Chris...but in front of the puter now...
58 inches in dia... 44 inch pitch... Sensenich makes super
props... been doing it for a long time...not sure about the ae9623... Herb
At 08:52 AM 4/20/2009, you wrote:
Hi Chris,
Pat
Checked by AVG - www.avg.com
04/19/09 20:04:00
What are you swinging Pat? Herb
Hi Chris,
Pat
04/19/09 20:04:00
Posted: Mon Apr 20, 2009 6:09 am Post subject: New M3X Flies ! |
Thought you all might do it different over there.
_________________ John Hauck
Titus, Alabama |
Posted: Mon Apr 20, 2009 10:19 am Post subject: New M3X Flies ! |
Thought you all might do it different over there.>>
Heh! Heh!
Just that my last planes instruments were calibrated in knots. ASI and vario
and I forgot.
Pat
Posted: Mon Apr 20, 2009 11:02 am Post subject: New M3X Flies ! |
Hi,
Wooden GT-2/157/NO 2BLADE HR tips. 157 cms dia. 98cms pitch. Max ground
Static 2750 rpm.
Thats what it says in the book.
Pat
Posted: Mon Apr 20, 2009 11:05 am Post subject: New M3X Flies ! |
props... been doing it for a long time...not sure about the ae9623... Herb.
Hi,
thought I might do the conversion.
61.8 inches dia. 38.5 inch pitch
Pat
Posted: Mon Apr 20, 2009 11:35 am Post subject: New M3X Flies ! |
Hello Mike,
here is a picture of the inside...
Pretty nice,
Is the throttle and trim in the middle a repeat of one at your left hand?
Mine has throttle and trim just under the left hand so I can fly right
handed with a repeater for a lefthanded co pilot.
The trim is forward as far as I can reach. The flaps are operated by a damn
great handle which projects from the rear of the cockpit between the pilot
and crew. You get used to it but it is a lousy bit of design. Putting up the
flaps as you clean up climbing through5/600 feet produces porpoising like a
new Spitfire pilot changing hands to operate the u/c.
Incidentally a Spitfire was auctioned today at an airfield near me. She went
for £1.5 million . I remember when we were collecting to buy a Spitfire at a
Wings Week during the war that a Spit. was £5000 and a Lancaster was £25000.
I wish I had bought half a dozen at the time.
Cheers
Pat
Pat.
Possums
Posted: Mon Apr 20, 2009 6:21 pm Post subject: New M3X Flies ! |
At 02:16 PM 4/20/2009, you wrote:
Heh! Heh!
and vario and I forgot.
Pat
I thought it was furlongs per fortnight.
_________________ Possum |
Posted: Tue Apr 21, 2009 1:10 am Post subject: New M3X Flies ! |
I thought it was furlongs per fortnight.>>
Great!. I never met an American who knew what a fortnight was.
How about `rod, pole, perch or lug per sennight`
Pat (Still laughing)
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Tue Apr 21, 2009 6:20 am Post subject: New M3X Flies ! |
Well, isn't lug to be pulled by the hair or ears, and sennight is celtic for 7 nights?
Soooo is it being pulled by your ears for 7 nights????
Shhhhhhh don't tell anyone it's not kolb related....
Mk III C
Oak Grove Missouri
Sent: Tuesday, April 21, 2009 4:00:29 AM
Subject: Re: Re: New M3X Flies !
--> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
How about `rod, pole========================
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
Posted: Tue Apr 21, 2009 7:21 am Post subject: New M3X Flies ! |
sennight is celtic for 7 nights? >>
Hi Mike,
Not Celtic as far as I know. `Sennight` is a shortened form of `seven nights` in the same way that `fortnight` is a shortened form of `fourteen nights`.
Now that really is off topic so back in your dorm quickly before the monitor comes round. Its nearly `lights out`
Pat
