Fuel lines routing through firewall - monowheel
jpg12305
PostPosted: Sun Apr 12, 2009 12:05 am    Post subject: Fuel lines routing through firewall - monowheel Reply with quote
Hello there,
My fuel lines currently route inside the cockpit, which is obviously not "by the book" and involves bends plus quite awful firewall crossing.
I would like to revert to the standard way, but the manual is not very clear to me, with no detailed drawing.
Any indications, pictures, tips and tricks... will be welcome.
Jean-Paul
Europa Mono 337
France
ptag.dev(at)tiscali.co.uk
PostPosted: Sun Apr 12, 2009 3:21 am    Post subject: Fuel lines routing through firewall - monowheel Reply with quote
Hi! Jean
I took my lines up the tunnel straight into the engine bay through the
stainless firewall. My system does not have the standard filters in the
seat pan neither the standard sight gauge. I have Andair Mini
Gascolators but Mine is now dedicated to be a trike so if you are Mono
construction you may not be able to do it this way? All my fuel module
is on a tray in the unused wheel well.
Bob Harrison G-PTAG
grahamsingleton(at)btinte
PostPosted: Sun Apr 12, 2009 6:34 am    Post subject: Fuel lines routing through firewall - monowheel Reply with quote
jpg12305 wrote:
Hello there,
Jean-Paul
Europa Mono 337
Jean-Paul
the neatest installation I have seen is Bryan Fogg's. Going throuhg the
stainless firewall is messy and stainless steel tends to cut things, not
good imho.
Graham
 Filesize:  321.65 KB
 Viewed:  4799 Time(s)
rparigor(at)suffolk.lib.n
PostPosted: Sun Apr 12, 2009 7:06 am    Post subject: Fuel lines routing through firewall - monowheel Reply with quote
Hi Jean-Paul I did a similar routing to the pix Graham sent of Bryan Fogg's install.I am using Aeroquip 666 hose.http://www.europaowners.org/modules.php?set_albumName=album227&op=modload&name=gallery&file=index&include=view_album.phpIt is in a XS with 914 with both long and short.914 pumps and gasculators aft.http://www.europaowners.org/modules.php?set_albumName=album231&op=modload&name=gallery&file=index&include=view_album.phpRon Parigoris [quote][b]
frans(at)paardnatuurlijk.
PostPosted: Sun Apr 12, 2009 8:19 am    Post subject: Fuel lines routing through firewall - monowheel Reply with quote
good imho.
But if there develops a leak for whatever reason, whether in flight or
after a crash landing, you are sitting with your feets in a bath tub.
Not good imho too.
Frans Veldman
