3edcft6(at)cox.net Guest
Posted: Thu Mar 23, 2006 12:44 pm Post subject: RV-12 question |
The RV-12 is shooting for the light sport licensed pilots. My question
is suppose you build one to spec and find after flight testing that it
goes faster than the max speed for that category? What do you do?
Chris W
KE5GIX
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
flyboy.bob(at)gmail.com Guest
Posted: Thu Mar 23, 2006 1:06 pm Post subject: RV-12 question |
Don't let it do that . . . or at least don't admit to it!
Last year at OSH Van said "they were going to play by the book" so if you
follow their instructions I'm pretty sure you'll be ok?
Good Luck,
Bob
On 3/23/06, Chris W <3edcft6(at)cox.net> wrote:
Chris W
KE5GIX
jjessen(at)rcn.com Guest
7ecapilot(at)comcast.net Guest
Posted: Thu Mar 23, 2006 1:31 pm Post subject: RV-12 question |
Certify that it's maximum speed in level flight under standard
conditions at sea level is 120 kts at a maximum permissible
continuous RPM setting. Then, provide operating limitations in your
handbook and placards in your airplane. You are the manufacturer. You
set the operating limitations. I have no idea if this will get past
an FAA inspection, but I am pretty sure that is legal. Sonex, Ltd.
declares that their 120hp version is LSA compliant. The maximum
continuous RPM for the Jabiru 3300 (120hp) is 2750 rpm. When you
extrapolate that to max continuous power('bout 108), their airplane
tops out at 135 mph (roughly 117kts). But, Jabiru says you can run
the engine to 3300 rpm for 10 minutes. So, for 10 minutes you can go
faster than 135 mph. They say their airplanes will go 170mph at
8000'. Builders of the Sonex 120hp have indicated that their
airplanes easily fly 160 mph ('bout 139kts) at cruise altitudes. But,
the reg stipulates maximum speed in level flight at sea level under
standard conditions with maximum continuous power.
http://www.sportpilot.org/rule/sp_rule.pdf
ymmv,
tw
On Mar 23, 2006, at 12:40 PM, Chris W wrote:
question
Chris W
KE5GIX
PFolbrecht(at)starkinvest Guest
A ramp-check is never going to involve a flight test (on a standard day yet!) to ensure the IAS falls with the legal range. They will go by the specs and you can be sure that the RV-12, with Van's recommended engine/prop combo, will meet them. Nothing to worry about.
From: owner-rv-list-server(at)matronics.com on behalf of Bob C.
Sent: Thu 3/23/2006 3:05 PM
To: rv-list(at)matronics.com
Subject: Re: RV-12 question
Good Luck,
Bob
Chris W
KE5GIX
jhstarn(at)verizon.net Guest
Posted: Thu Mar 23, 2006 3:04 pm Post subject: RV-12 question |
Easy. Put a self imposed RPM limit on you engine and note same in the "owner
operating limitations". KABONG
flynlow(at)usaviator.net Guest
Posted: Thu Mar 23, 2006 4:06 pm Post subject: RV-12 question |
"What do you do?"
Well......
If yer Catholic:
Perhaps 4 "Hail Mary's" 2 "Our Fathers" and 1 "Act of Contrition" would be
sufficient, then go fly.
If yer anything else
Perhaps say: "OOPS" then go fly.
All's well that ends well they say....
Bud Silvers
RV8 Fastback - Finishing
rv8(at)lazy8.net Guest
Posted: Thu Mar 23, 2006 5:07 pm Post subject: RV-12 question |
Take it back apart, give the kit back to Van and demand your money back!
Chris W wrote:
Robin Marks
Joined: 10 Jan 2006 Posts: 24 Location: San Luis Obispo, CA
Posted: Thu Mar 23, 2006 6:01 pm Post subject: RV-12 question |
If your RV-12 flies too fast after it is first assembled follow these
instructions in order:
Step 1: Fly for 500 hours to see if performance decreases due to lower
engine / prop efficiencies.
Step 2: If you notice no reduction in performance repeat step 1.
Step 3: Continue to TBO.
Please, please, please do not archive....
_________________ RV-4 Sold
RV-6A 0-360 - C/S Flying |
BPA(at)bpaengines.com Guest
mrobert569(at)hotmail.com Guest
Posted: Mon Mar 27, 2006 1:51 pm Post subject: RV-12 question |
Actually, you are a bit off on this reply. If you build a light-sport
certified kit you can not do what you want, but must build it exactly as the
manufacturer calls out in their assembly manual. any deviations must be
approved by the manufacturer. Other than that you are OK.
Mike Robertson
Das Fed
| Quote: | From: Terry Williams <7ecapilot(at)comcast.net>
Reply-To: rv-list(at)matronics.com
Date: Thu, 23 Mar 2006 13:30:10 -0800
ymmv,
tw
> question
> do not archive
> Chris W
> KE5GIX
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Mon Mar 27, 2006 5:54 pm Post subject: RV-12 question |
That's for the "certified" LSA kit. Isn't there still an Experimental LSA category that has the same latitude its big brother Amateur-Built Experimental enjoys?
Greg Young
<mrobert569(at)hotmail.com>
light-sport certified kit you can not do what you want, but
must build it exactly as the manufacturer calls out in their
assembly manual. any deviations must be approved by the
Mike Robertson
Das Fed
steveadams
Posted: Tue Mar 28, 2006 4:53 am Post subject: Re: RV-12 question |
| gyoung wrote: | That's for the "certified" LSA kit. Isn't there still an Experimental LSA category that has the same latitude its big brother Amateur-Built Experimental enjoys?
Greg Young
Mike Robertson
Das Fed
You are correct. If the kit still meets the 51% rule, then it is still experimental. I don't know how Van's intends to market the RV-12, but I assumed it would be as a E-LSA.
Posted: Tue Mar 28, 2006 3:50 pm Post subject: RV-12 question |
Through January 2008 there is latitude because we can get it in under the
"existing aircraft" category. But all these existing aircraft are supposed
to be certificated prior to January 2008. After that there is a serious
question. I think there will be some way to handle it but in what form I do
not know at this time.
Mike Robertson
das Fed
| Quote: | From: "Greg Young" <gyoung(at)cs-sol.com>
To: <rv-list(at)matronics.com>
Subject: RE: RV-12 question
Date: Mon, 27 Mar 2006 19:47:10 -0600
Greg Young
> Mike Robertson
> Das Fed
steveadams
Posted: Thu Mar 30, 2006 10:39 am Post subject: Re: RV-12 question |
| mrobert569(at)hotmail.com wrote: | Through January 2008 there is latitude because we can get it in under the
Mike Robertson
Are you saying that after 2008 there will be no E-LSA?
Posted: Fri Mar 31, 2006 8:08 pm Post subject: RV-12 question |
ELSA isn't going to go away but the sub-qualifications under ELA that covers
existing aircraft may change. We will just have to wait and see how it goes
and how to manage/manipulate it.
Mike Robertson
| Quote: | From: "steveadams" <dr_steve_adams(at)yahoo.com>
Date: Thu, 30 Mar 2006 10:39:40 -0800
the
supposed
I do
> Mike Robertson
http://forums.matronics.com/viewtopic.php?p=25349#25349
steveadams
Posted: Fri Apr 07, 2006 8:29 am Post subject: Re: RV-12 question |
| mrobert569(at)hotmail.com wrote: | ELSA isn't going to go away but the sub-qualifications under ELA that covers
Mike Robertson
Actually, I think the "existing aircraft" qualification applies to ultralights that have not been previously certified, so they can get the E-LSA certification before 2008. It absolutely does not effect the rules that apply to other aircraft. If someone buys an RV-12, they will have a choice to certify it either as E-LSA or experimental, amateur built. In either case, it can be flown by a sport pilot because it meets the definition of a LSA. The definition of an LSA is based upon certain performance parameters, weight, and number of seats etc. It is not in any way defined by the certification it receives, ie - standard, E-LSA, S-LSA, or experimental, amateur built.
