longg(at)pjm.com Guest
Posted: Tue Apr 07, 2009 4:22 am Post subject: Affixing an Engine Ground |
On closer inspection of my Lycoming I found there are two pre-determined
grounding locations on the IO-360 engine. Those bearing the Dynafocal
mount setup have a purpose built hole on the ear of lower mounting tabs.
I've attached a few pics.
Glenn
957.88 KB |
5265 Time(s) |
815.97 KB |
5265 Time(s) |
dale.r(at)cox.net Guest
Posted: Tue Apr 07, 2009 6:43 am Post subject: Affixing an Engine Ground |
longg(at)pjm.com wrote:
| Quote: | On closer inspection of my Lycoming I found there are two pre-determined
Glenn,
The folks who still access their mail via a dial-up connection
are probably uttering deprecations right now. 2 Meg is nearly
an hour's download, just for this one message.
For the future, you might want to avail yourself of one of the
many graphic tools (e.g. irfanview is free) to crop and/or
resample to shrink your photos to a manageable < 200KB.
Dale R.
COZY MkIV #0497
Ch. 13
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Tue Apr 07, 2009 7:26 am Post subject: Affixing an Engine Ground |
Glenn,
I would grind the paint off where you have attached the ground in order to
ensure a good connection...
Bret Smith
RV-9A "Finishing"
Blue Ridge, GA
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
mauledriver(at)nc.rr.com Guest
Posted: Tue Apr 07, 2009 1:19 pm Post subject: Affixing an Engine Ground |
Does anyone know equivalent locations on an IO-540?
---- longg(at)pjm.com wrote:
[quote] On closer inspection of my Lycoming I found there are two pre-determined
Glenn
Posted: Wed Apr 08, 2009 5:14 am Post subject: Affixing an Engine Ground |
Ah yes, thought of that. I ground off just under the bolt, so as to keep
up with appearances.
Jim Berry
Posted: Wed Apr 08, 2009 8:58 am Post subject: Re: Affixing an Engine Ground |
Van's method for grounding the IO-540 in the RV10 is to use the accessory case bolts just below the upper Lord mounts.
Jim Berry
40482
N15JB
