icubob(at)gmail.com Guest
Posted: Tue Apr 07, 2009 4:38 am Post subject: fuel tank venting |
hi all,
what are builders doing to vent their wing tanks so they drain? one builder i know has a small tube sticking up and bent into the wind for a little''ram'' effect. is this necessary? wouldnt a small hole in the cap suffice?
bob noffs
Lynn Matteson
Posted: Tue Apr 07, 2009 5:56 am Post subject: fuel tank venting |
It seems like a small hole would cause a vacuum inside the tank, and
if it didn't lead to siphoning the fuel out through that hole, it
might cause the engine to starve for fuel until the plane's speed was
reduced until the siphoning action eventually stopped. My Kitfox, and
all others that I've seen, have the "small tube sticking up and bent
into the wind."
Lynn Matteson
Jabiru 2200, #2062, 624.3 hrs
Sensenich 62x46
Status: flying
On Apr 7, 2009, at 8:36 AM, bob noffs wrote:
| Quote: | hi all,
bob noffs
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Tue Apr 07, 2009 6:22 am Post subject: fuel tank venting |
The cap is generally right in the low pressure are of the wing when in flight so a hole in the cap will in fact cause a partial vacuum on the top of the fuel... If you forget to put the cap on you will find the tank empty in no time. The little ram effect tube is to overcome the slight vacuum in that area. That little tube should be checked before each flight to make sure it is clear and no insects have built nests there.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of bob noffs
Sent: Tuesday, April 07, 2009 10:06 AM
Subject: fuel tank venting
hi all,
bob noffs
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Fox5flyer Guest
Posted: Tue Apr 07, 2009 6:34 am Post subject: fuel tank venting |
Well stated, Lynn. Those pitot tubes are there not only for venting, but to
also provide a light pressurizing to the fuel system. As I recall, one of
our valued past members (Don Smythe?) recessed his tank caps and vented the
tanks similar to early Cessnas. Seemed to work OK, but he went to a ton of
work to accomplish it. The system as designed works very well.
Crappy weather in NE Michigan while waiting for my airstrip to dry out!
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
matronics(at)bob.brennan. Guest
Posted: Tue Apr 07, 2009 6:40 am Post subject: fuel tank venting |
Those of us that have the main tank under the cowling (me, at least) have a
cap with a small hole which acts only as a vent. I suppose it works well
because the big cooling fan at the front causes an increase in the pressure
in that area.
My "reserve" wing tank has the bug-nest tube facing into the wind, I am
guessing without that it wouldn't drain at all when I open the petcock. In
fact it drains extremely slowly when not in flight, so the tube helps the
bad plumbing. Bad plumbing = Model II drain tube that goes from the wing
tank to the floor and back up to the outlet of the dash tank, not like you
guys with header tanks behind the seats. Without that "vent tube" I would
probably need a pump.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade prop
Wrightsville Pa
Lynn Matteson
Posted: Tue Apr 07, 2009 7:49 am Post subject: fuel tank venting |
If I recall correctly, Don (if it was him) had to run a vent line
clear way out to the tip(s) of the wing(s) so that it/they would be
higher than the top of the tank(s). And didn't this present a problem
if/when the wings were folded?
We got 3-4" of snow down here yesterday, Deke.....just enough to want
to put the skis back on and make tracks in the snow, but the
accompanying winds made me think better of it. Before I built the new
set of skis, I wouldn't have thought of having the ordeal of putting
them back on, but when it's only a 10-minute job, it's definitely a
do-able job.
Lynn Matteson
Sensenich 62x46
Status: flying
On Apr 7, 2009, at 10:30 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
venting, but to also provide a light pressurizing to the fuel
system. As I recall, one of our valued past members (Don Smythe?)
recessed his tank caps and vented the tanks similar to early
Cessnas. Seemed to work OK, but he went to a ton of work to
out!
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
N369LM |
dave
Posted: Tue Apr 07, 2009 11:08 am Post subject: Re: fuel tank venting |
On the talk of airstrip , I have water filled roller. I never been happy with it . I am in the process of making a 8 ' wide 30" roller . Will fill with cement -- should be close to 5000 lbs. I got a few smaller wheel planes come in here and like it nice for them and the amphib float guys - like me .
Kingfox Tires excel at most terrain. Never used much on asphalt so mine look fine. Glad to hear the Kevin might get more in. I shipped most of mine to Europe that I got from him.
| Fox5flyer wrote: | Well stated, Lynn. Those pitot tubes are there not only for venting, but to
Deke Morisse
Mikado Michigan
- Joseph Joubert
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
dave
Posted: Tue Apr 07, 2009 11:10 am Post subject: Re: fuel tank venting |
Bob, I think you should have pitot tubes on each tank including your dash tank. I do and have over 1000 hours in this Kitfox trouble free.
| matronics(at)bob.brennan. wrote: | Those of us that have the main tank under the cowling (me, at least) have a
in that area.
Wrightsville Pa
Posted: Tue Apr 07, 2009 11:32 am Post subject: fuel tank venting |
You have a pitot on your dash tank cap? Is it the kind of cap that is above
the cowling and you can fill without taking the cowling off? Mine is. I've
seen some fillers under the cowling and I agree a pitot might help that. I
know you have lots of pix - does any show a dash tank with pitot?
Attached is a picture of mine - notice the cap is tilted into the wind. I
also have had no problems with it the was it is, though not nearly as many
hours!
dave
Posted: Tue Apr 07, 2009 3:38 pm Post subject: Re: fuel tank venting |
All 3 Pitot tubes for you Bob. btw I never saw an attachment from you. ?
Kitfox IV on floats Pitot tubes www.cfisher.com |
34.83 KB |
11258 Time(s) |
rjdaugh
Posted: Tue Apr 07, 2009 5:25 pm Post subject: fuel tank venting |
That area on top of the cowling ahead of the windshield is a high pressure
area. The pitot vent is not needed there.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
dave
Posted: Wed Apr 08, 2009 3:01 am Post subject: Re: fuel tank venting |
Randy , I am not sure if it is high pressure or not there. I have done tuft testing there and the tufts lift up in front the cap and the rest go around it .
I know once I was transferring fuel from wing tanks to dash tank and I overfilled it , the gas was coming out the pitot tube and spraying on the windshield. Nut sure what that tells you other than I am a dunce.
I don't think I would want to take a chance on siphoning having a open vent on the cap.
| Quote: | Bob,
Randy |
7suds(at)Chartermi.net Guest
Posted: Wed Apr 08, 2009 7:21 am Post subject: fuel tank venting |
All,
I built a Model 4 XL with a Rotax 503 some years back that had a ten gallon
aluminum dash tank that I built and two six gallon wing tanks. Wing tanks
had standard fuel caps with pitots and shutoffs at the wing root ribs. They
each feed into one of two top ports in the dash tank. Dash tank had a filler
cap that protruded up through the cowl and the cap was not vented (No over
flow spillage if I overfilled while transferring from my wing tanks). Dash
tank had a vent port from the top of the tank to the top port on the right
wing tank. Dash tank had a 12 volt float system with a gauge on the dash. I
would fly until I was at half tank on the dash tank and then transfer from
one wing tank or the other, the amber lines feeding the dash tank ran down
each door post so I was able to see the fuel flow. Some times in flight fuel
did not want to flow so I would put the plane into a forward slip with that
wing high to get it started. I discovered later if I was to transfer some
from each tank so the lines were full and then shut off the valves it would
begin flowing better once in flight.
Lloyd Cudnohufsky
Model 5 912ul
IVO IFA Rebuild
Northern Mi.
dave
Posted: Wed Apr 08, 2009 8:10 am Post subject: Re: fuel tank venting |
Lloyd,
My poly tank has no vent built into it but I think you need to have a vent somewhere or you could starve for gas. I have a shut off for each with tank so if they both shut off I have no venting at all on dash tank.
So it seems necessary to have a vent and in my case the pitot serves the purpose.
Dave
