n8vim(at)arrl.net Guest
Posted: Mon Apr 06, 2009 11:52 am Post subject: Ethernet Hub - Crossover Cable |
10/100 Base T CrossOver Cable
Plug Code Plug Code
1 T2--------\ /------1 T2
2 R2-\ X /-2 R2
3 T3--\-----/ \---/--3 T3
4 nc \ /-------/ 4 NC
5 nc x 5 NC
6 R3---/ \-----------6 R3
7 nc 7 NC
8 nc 8 NC
10/100 Base T Cable
COLOR CODES FOR STANDARD WIRING
Plug Color
1 Orange-White
2 Orange
3 Green-White
4 Blue
5 Blue-White
6 Green
7 Brown-WHite
8 Brown
-Jim 40384
John Cumins wrote:
If your just linking 2 ea afs units then you can just use a Ethernet Cross
over cable and will not need a hub. If you want to connect more then 2
devices then you will need a Ethernet switch/hib.
If you want more info on a cross over cable shhot me a e-mail off list and I
will assist you.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
jeff(at)westcottpress.com Guest
Posted: Mon Apr 06, 2009 12:21 pm Post subject: Ethernet Hub - Crossover Cable |
Hi All,
The cross over cable works if you're just connecting two AFS units
together. When you add the WX Receiver in to the mix, then you need
the hub. I won't have that initially (unless business gets a whole
lot better fast), but I don want to make provisions for the space it
needs as well as the power.
Jeff Carpenter
Plug Code Plug Code
2 R2-\ X /-2 R2
3 T3--\-----/ \---/--3 T3 4 nc \ /-------/ 4 NC
5 nc x 5 NC
7 nc 7 NC
8 nc 8 NC
10/100 Base T Cable
Plug Color
1 Orange-White
2 Orange
3 Green-White
4 Blue
5 Blue-White
6 Green
7 Brown-WHite
8 Brown
-Jim 40384
> Ethernet Cross
> then 2
> list and I
> will assist you.
> John G. Cumins
> President
> 2499 B1 Martin Rd
> Fairfield Ca 94533
> 707-425-7100
> 707-425-7576 Fax
Posted: Mon Apr 06, 2009 12:39 pm Post subject: Ethernet Hub - Crossover Cable |
Hmm... Looks like I missed a <CR>
Also, if you do find a way to connect three devices with a cable having
only two ends, you'll provide endless hours of laughter to anyone in IT !
Take two:
Plug Code Plug Code
2 R2-\ X /-2 R2
5 nc x 5 NC
7 nc 7 NC
8 nc 8 NC
10/100 Base T Cable
Plug Color
1 Orange-White
2 Orange
3 Green-White
4 Blue
5 Blue-White
6 Green
7 Brown-WHite
8 Brown
-Jim 40384 (Also now a RedHat Enterprise Linux Certified Engineer!)
