dlm46007(at)cox.net Guest
Posted: Sat Apr 04, 2009 2:32 pm Post subject: Extra battery |
Anyone mount an extra Odyssey 680 on the firewall? I am planning on using the Piper battery box and mounting it diagonally to pick up two holes on the diagonal stiffener.and creating a couple of aluminum doublers for the other four holes. The holes in the battery box are .29 which means they will have to be bushed for an AN3 or enlarged and bushed for an AN4.
bkbrown(at)minetfiber.com Guest
Posted: Sat Apr 04, 2009 8:52 pm Post subject: Extra battery |
If you’re using a PC-680 battery, why not just buy the install kit for the RV7 or 7A?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Saturday, April 04, 2009 3:31 PM
Subject: Extra battery
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
gengrumpy(at)aol.com Guest
Posted: Sun Apr 05, 2009 6:26 pm Post subject: Extra battery |
I'm using 2 of the 680s, both mounted aft of the bulkhead in 2 of Van's battery boxes (2 batt busses).
Works like a champ.
grumpy
N184JM
On Apr 4, 2009, at 11:51 PM, Bob and Karen Brown wrote:
= [quote][b]
ricksked(at)embarqmail.co Guest
Posted: Sun Apr 05, 2009 6:54 pm Post subject: Extra battery |
John,I'm in the middle of spraying. Mike Loehle's paint on my -10', how's it holding up on yours? Also what gap are those flying using between the wing gap faring and the fuselage I need to final fit the edge prior to painting them Rick Sked40185Can taste the flying..or maybe its polyurethane!
Sent via BlackBerry by AT&T
Date: Sun, 5 Apr 2009 21:23:23 -0500
Subject: Re: RV10-List: Extra battery
I'm using 2 of the 680s, both mounted aft= of the bulkhead in 2 of Van's battery boxes (2 batt busses).
=Works like a champ.
grumpy
N184JM
| Quote: | I= f you=92re using a PC-680 battery, why not just buy the install kit for the=20= RV7 or 7A?
</= div>From: mailto:owner= -rv10-list-server(at)matronics.com ([email]owner-rv10-list-server(at)mat= ronics.com[/email])]&n= bsp;On Behalf Of David McNeill
Sent:&nbs= p;Saturday, April 04, 2009 3:31 PM
To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)=
Subject: RV10-L= ist: Extra battery
=Anyone= mount an extra Odyssey 680 on the firewall? I am planning on using the Pipe= r battery box and mounting it diagonally to pick up two holes on the diagona= l stiffener.and creating a couple of aluminum doublers for the other four ho= les. The holes in the battery box are .29 which means they will have to be b= ushed for an AN3 or enlarged and bushed for an AN4.
<= /div>=[/b]<= /span>http://www.matronics.com/Navigator?RV10-List012345 | 6
=3D 7
Posted: Sun Apr 05, 2009 7:13 pm Post subject: Extra battery |
so am I but I think the third on the firewall will provide more flexibility to load the baggage area. Since the fuel burn moves the CG aft , the pitch controls get lighter than I like. Also my main batteries don't seem to get recharged completely given the fixed output from the alternator and the long run to the batteries. Two batteries to start works fine but sometimes a single battery start is slow
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Miller John
Sent: Sunday, April 05, 2009 7:23 PM
Subject: Re: Extra battery
Works like a champ.
grumpy
N184JM
= 1 [quote][b]
Posted: Sun Apr 05, 2009 7:15 pm Post subject: Extra battery |
I think that is what I have but it came from Aircraft Spruce. A black aluminum box made for the PC 680.
Works like a champ.
grumpy
N184JM
= 1 [quote][b]
rv10free2fly(at)yahoo.com Guest
Posted: Sun Apr 05, 2009 7:38 pm Post subject: Extra battery |
Any pictures of the set-up please guys.
Pat
South Oz
Sent: Monday, 6 April, 2009 11:53:23 AM
Works like a champ.
grumpy
N184JM
= 0
Enjoy a safer web experience. Upgrade to the new Internet Explorer 8 optimised for Yahoo!7. [url=http://au.rd.yahoo.com/search/ie8/mailtagline/*http://us.lrd.yahoo.com/_ylc=X3oDMTJxbnQwdTJhBF9zAzIxNDIwMjU2NTkEdG1fZG1lY2gDVGV4dCBMaW5rBHRtX2xuawNVMTEwMzQ0OAR0bV9uZXQDWWFob28hBHRtX3BvcwN0YWdsaW5lBHRtX3BwdHkDYXVueg--/SIG=11k6t9t1c/**http://downloads.yahoo.com/au/internetexplorer/]Get it now.[/url]. [quote][b]
rene(at)felker.com Guest
Posted: Sun Apr 05, 2009 9:29 pm Post subject: Extra battery |
David, I have thought about going to a single 680 on the firewall. My CG is aft and 4 adults is tough with the CG that way. You say cranking on one 680 can be slow…….how often to you crank with 1 batt. Would it be worth me testing the single battery config?
Rene'
801-721-6080
partner14
Posted: Sun Apr 05, 2009 10:07 pm Post subject: Extra battery |
I think it will depend on the following factors: 1. Weather - if it's cold, it will be tougher to turn over. 2. Compression - if your engine has any increase in compression from stock it'll be tougher to turn over. 3. Dependability - Does it fire right away,,, every time? Another consideration is hot starts, sometimes they can be a problem.
What I can tell you is that mine will start with one battery, but if I have a problem of any sorts, it's really nice to flip that second switch.... spins it right up.
That's my 2 cents.
Don McDonald
#40636
Plane has it's airworthiness cert, pilot has cross training...... but still no license!
--- On Sun, 4/5/09, Rene <rene(at)felker.com> wrote:
Subject: RE: Extra battery
Date: Sunday, April 5, 2009, 10:24 PM
Rene'
801-721-6080
40636 |
Kelly McMullen
Posted: Mon Apr 06, 2009 2:13 am Post subject: Extra battery |
What does Van's have in 410RV? It probably does more starts, especially hot starts than any other -10 is likely to see. IIRC the plans call for RG25 battery?
On Mon, Apr 6, 2009 at 1:24 AM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
Rene'
801-721-6080
A&P/IA, EAA Tech Counselor
KCHD |
gengrumpy(at)AOL.COM Guest
Posted: Mon Apr 06, 2009 5:28 pm Post subject: Extra battery |
I use both batteries for start, which seems to work fine so far.
At the suggestion of both Aviation Consumer and Light Plane Maintenance, I bought 2 battery tenders and keep them hooked to my batteries if I'm not going to fly for a week or so. Remember that it takes at least an hour of flying to recharge the voltage lost during start.....
On Apr 5, 2009, at 10:10 PM, David McNeill wrote:
| Quote: | so am I but I think the third on the firewall will provide more flexibility to load the baggage area. Since the fuel burn moves the CG aft , the pitch controls get lighter than I like. Also my main batteries don't seem to get recharged completely given the fixed output from the alternator and the long run to the batteries. Two batteries to start works fine but sometimes a single battery start is slow
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Miller John
Works like a champ.
grumpy
N184JM
| Quote: | If you’re using a PC-680 battery, why not just buy the install kit for the RV7 or 7A?
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David McNeill
0123456789
= 1 2
= [quote][b]
