kiwimick
Posted: Wed Mar 22, 2006 3:27 pm Post subject: Jabiru |
Jet Pilot,
Take it you have not been in this game long then,
You say the Jab has more probs than a 912, Maybe in the USA you don't get
the Rotax SB's so I will apologize now, but as a Rotax and Jabiru service
centre and operator of both on our school A/C I can say with first hand
experience that there is bugger all between them in reliability, and the
Rotax has a SB almost every other month, they are both very good, serivce
intervals on the jab are now as good as the 912 as well as no G-Box maint.
Also with first hand exp I can confirm that Our Jab powered Xtra gets off
the ground quicker than a 912 powered Classic (tested on same day) for CAA.
I would be confident to stake my aircraft on that, the 912 will climb a bit
better from about 200 feet onwards though and Jab not quite as fast at full
power but I cruise at 80 mph at 2550rpm, 90mph at 2800, and 95 at 2950.
Maybe you forgot all the problems the 912 had in the first 5-8 yrs, theJab
is well sorted now.
Mike
Xtra/Jab
_________________ Mike the kiwi Kolber in England....... |
kiwimick
Posted: Wed Mar 22, 2006 3:38 pm Post subject: Jabiru |
John, Yep that is no prob now, I can vouch for that.
Mike
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Wed Mar 22, 2006 4:16 pm Post subject: Re: Jabiru |
Mike,
Since you have experience with the Jabiru's on a Kolbs, could you answer a question or two?
How high above the bottom of the engine mount is the prop shaft?
How much is the installed weight on a Kolb?
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
Posted: Wed Mar 22, 2006 4:19 pm Post subject: Jabiru |
| Mike
What did Jabiru do to eliminate the moisture problem?
Do they still use the twin distributors? or did they go to a sealed
system similar to Rotax and other manufacturers? My Suzuki dirt bike
ign is sealed, solid state.
MKIII
_________________ John Hauck
Titus, Alabama |
usmc_diver(at)yahoo.com Guest
Posted: Wed Mar 22, 2006 4:48 pm Post subject: Jabiru |
Link to the jabiru site
http://www.arionaircraft.com/
you can also check out the yahoo esqual group for the
full details on the 80hp speedster.
Lamont Taylor
--- Don G <donghe(at)one-eleven.net> wrote:
browse
Subscriptions page,
FAQ,
Admin.
Posted: Wed Mar 22, 2006 5:14 pm Post subject: Jabiru |
serivce
maint.
Rather have that little bit of gear box maintenance, what is it? check
every 600 or 800 hours?? than no gear box.
gets off
for CAA.
Musta been piss poor pilot technique on the part of the Classic
driver. My old Classic used to eat up John W's Jab powered Kolbra on
acceleration, take off distance, and climb. Course all that changed
dramatically when John W upgraded to a 912S.
climb a bit
at full
2950.
Bring the Xtra on over. Would be happy to do a little one on one
competition with you.
theJab
| is well sorted now.
I was flying my 912 back then. Mine was manufactured later part of
1993. I started flying it April 1994. I remember a few updates
during that time frame, but don't remember a lot of problems. I know
I was doing a lot of flying back then and the old 912 was still
humming when I swapped it for the 912ULS at 1,135.0 hours.
I remember having some mandatory updates to do on the 912ULS, and she
is still humping like a new one at 1,100.0 hours.
Both the Jabiru and Rotax 912 series engines are great engines. I
believe there is a place for them on Kolbs, but they are not going to
perform as well as a gear box engine.
MKIII
Titus, Alabama |
Posted: Wed Mar 22, 2006 6:02 pm Post subject: Jabiru |
John Hauck wrote:
|| Also as Rick stated, the Jabiru guys machine a gearbox for that
| engine,
|| Rotax will have there hands full...
|| Jeremy
Forgot to comment on the above.
Why hasn't Jabiru taken advantage of a gearbox to allow slower turning
larger diameter props?
Must be some reason they have not come up with a good workable
solution. Seems there would be a large market for that type
equipment.
MKIII
I've never flown one; only seen them occasionally. But I can hazard a
guess on why they don't have a gearbox. Their chosen market seems to be
the light end of the experimental non-ultralite market; typically faster
planes being flown by pilots more accustomed to flying traditional a/c
engines. Note the overall original configuration: direct drive,
carburetors & dual mags, even though electronic injection/ignition would
probably have been cheaper & simpler to build.
Believe me, it's very difficult to find a licensed pilot (even one who
flies experimentals) who will trust a gearbox on an aircraft engine.
Most won't trust *any* alternative engine. Just mention the idea of
gearing & you'll get a 3rd hand account of how those Continentals on
Cessna 175's always failed & how much it costs to repair Twin Bonanza
engines.
FWIW...
neilsenrmf(at)comcast.net Guest
Posted: Wed Mar 22, 2006 8:59 pm Post subject: Jabiru |
Charlie
Making a gear reduction drive for a aircraft engine takes some work to make
it work well but Rotax does and the performance gains (power and thrust) are
well worth it. The redrive for my VW has plenty of room for improvement but
it is still worth it. Rotax makes the 912 series for the same light aircraft
you are referring to. I would venture a guess that in a apples to apples fly
off a 80HP rotax would blow the doors off a 85HP Jabiru in most any airplane
even the fast ones.
I'm a licensed pilot and my MKIIIc is a experimental...... Seems like there
are a few gear boxes in turbo prop airplanes...... Also there are gear boxes
in P51 Mustangs, Spitfires and allot of the big radial engines used in WWII
aircraft. These gearbox airplanes only seemed to fall out of the sky when
they got shot down. Just because Continental didn't make it work well
doesn't mean that it isn't ever going to work well and not be reliable. You
also might note that the airplanes I just referred to are a bit faster than
that 180MPH Jabiru someone was talking about. If gear box driven props
didn't work better at higher speeds the designers wouldn't have used them.
Again I think the Jabiru is a great engine it just needs a reduction drive
to compete with the rotax 912 series of engines.
As always my $.02 worth
Rick Neilsen
Redrive VW powered MKIIIc
Steve Boetto
Posted: Thu Mar 23, 2006 4:12 am Post subject: Jabiru |
In a message dated 3/22/2006 9:03:07 P.M. Eastern Standard Time,
ceengland(at)bellsouth.net writes:
| Quote: | Forgot to comment on the above.
equipment.
MKIII
To John/All
Don't forget the issue of Prop size vs Ground clearance. Many of these tiny
little speedsters could not use a larger prop even if the engine could turn
them. Maybe the Jab is really good in that niche. My old Long Ez turned a 64x79
Sensch prop due to ground clearance. The 160 hp Lyc turned about 2500 on
takeoff and 2950 at 10,000ft. She would climb in excess of 3,000 fpm at low
altitudes and true out 205 mph at 10,000ft. I think that clean airframes can
tolerate shorter props that are pitched heavy BUT, just imagine what that plane
could have done with a longer prop at lower rpms.
Hope to see everyone at SnF 2006
Steve B
Firefly #007
Kirk Smith
Posted: Thu Mar 23, 2006 6:32 am Post subject: Jabiru |
The majority of successful applications of the Jabiru are in tractor
configurations in aircraft with higher speeds than Kolbs. The slower
aircraft in pusher configuration that do well with the larger props may
run into cooling problems for the Jabiru even if it had a reduction unit.
My penny.........
Do not
archive
Posted: Thu Mar 23, 2006 11:41 am Post subject: Jabiru |
Hi Rick,
Sorry; I didn't mean to imply that gearboxes are bad, just that
superstitious pilots who've listened to too many old wives' tales
(hangar flying) don't understand them & therefore, don't trust them.
Most don't trust electronics on an engine, either, even though they've
had to comply with several carb AD's & a couple of mag overhauls while
never touching anything under the hood of their cars. The problem with
the old C175 motors was that no one was willing to run them at design
rpm; they tried to operate them at rpms of the direct drive engines they
were accustomed to.
My (attempted) point was: Jabiru knows their market & the market drove
the design.
I think that for anything cruising under 200mph, a fixed pitch large
diameter prop & small displacement geared engine can make a lot of
sense. For under 100 mph & STOL operation with very light planes, it
makes just about the *only* sense.
Charlie
Richard & Martha Neilsen wrote:
Charlie
even the fast ones.
Rick Neilsen
Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Thu Mar 23, 2006 1:02 pm Post subject: Re: Jabiru |
L.T.
Thanks for the link. I have just spent the last half hour or better studying that Lighting site....WOW. A real good example of the sum of a process where you take any particular engine and design an aircraft for it, instead of building an airframe, and adapting engines to them. These folks obviously have a mind for their market, and are developing just what it will take to compete in that market.
Unlike so many of the import LSA and EXP competitors, it is available in a Kit. I predict it will be a huge sucess. I still havent figgered out why so many other LSA entries are ignoreing the production numbers of the likes of Vans and Zenith and Sonex kits. The american market for aircraft already exists for kit built aircraft and they are all trying to convince that market (or themselves maybe) that a ready built airplane will gain market share when the buyers show a preference for building themselves.
Reminds me of a boss I used to have.
(I'm still here, he isn't!!)
Thanks for the link...cant wait to see one a there babies in the flesh.
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
kiwimick
Posted: Thu Mar 23, 2006 2:52 pm Post subject: Jabiru |
John, I will measure that for you within the next few days.
The installed weight is 64kg.
Mike
kiwimick
Posted: Thu Mar 23, 2006 3:09 pm Post subject: Jabiru |
Yep John, I am that that crap Classic pilot, I flew them both that day. I am
quite new to flying only done just under 10,000 hrs in microlights, mainly
as an instructor and qualified test pilot, still I have only got approx 150
hrs in a Classic and 500 or so on Jab and 582 Xtra's
You keep referring to the old days of John W and Jab, those days the jab was
only approx 75 real hp and if I remember right John and all the other USA
Jab runners only turn a tiny 58" prop, Much more power now and I turn a
62.5" prop. My Xtra also has VG's, The Classic did not. Come see it ,
believe it.
Mike
kiwimick
Posted: Thu Mar 23, 2006 3:17 pm Post subject: Jabiru |
All,
You very lucky Americans have a wonderful thing called EXPERIMENTAL, the
rest of the world is not quite so lucky. Without the lighter simpler Jab
many microlights around the world would not exist with 4 stroke engines,
others just choose not to have a 4 stroke engine cruising at 4500-5500 rpm.
Mike
Posted: Thu Mar 23, 2006 4:43 pm Post subject: Jabiru |
| believe it.
| Mike
Man...........I would love to if I could find the time and money.
Even if I got beat.
Thanks for the invite.
DO NOT ARCHIVE
Titus, Alabama |
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Sat Mar 25, 2006 3:39 am Post subject: Re: Jabiru |
There's a new engine being developed in Belgium that, I think, will challenge the Jabiru, Rotax's etc, for market share once in production.
Ground runing is virtually finished and test flying is in progess now. (Wish it had a PSRU though)
Info is here if interested:
http://www.ulpower.com/index.html
David.
