Eddie's Moose
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
dstroud(at)xplornet.com
PostPosted: Tue Mar 31, 2009 1:39 pm    Post subject: Eddie's Moose Reply with quote
Giday, Eddie. Did you install a fuel debubbler device on your Moose ? If so,
could you please say what type and the source of it ? Thanks....
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
[quote] [b]
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
eddiemoranii(at)yahoo.com
PostPosted: Wed Apr 01, 2009 2:07 am    Post subject: Eddie's Moose Reply with quote
David, no I did not.
Eddie
--- On Tue, 3/31/09, DAVID STROUD <dstroud(at)xplornet.com> wrote:
Subject: Eddie's Moose
To: m14pengines-list(at)matronics.com
Date: Tuesday, March 31, 2009, 5:39 PM
Christavia C-FDWS
st" target=_blank rel=nofollow>http://www.matronics.com/Navigator?M14PEngines-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
Ted French
PostPosted: Wed Apr 01, 2009 5:04 pm    Post subject: Eddie's Moose Reply with quote
I'm helping to build a Moose with the M14. I just have to ask..... what is a fuel debubbler and what is it used for.
Ted
Christavia C-FDWS
French_Edwin_L_(Ted).vcf
 Filename:  French_Edwin_L_(Ted).vcf
 Filesize:  502 Bytes
 Downloaded:  777 Time(s)
Ted French
RV-10 fuselage
PostPosted: Thu Apr 02, 2009 11:10 am    Post subject: Eddie's Moose Reply with quote
Giday, Ted. The Yak has a de-bubbler on the firewall. It is a small sphereical item which takes any air out of the fuel system
before it heads off to the filter and carb. I am building a Fairchild 51 replica using the Huosai engine from a Nanchang and
look to the Yak list for any info I can get along the way. The Moose builders are usually ahead of me so I was wondering
if any were using one. It may not be necessary on a plane that will not fly inverted and that's a position I will not get into
on purpose anyway. More knowledgable members could confirm it's benefits on a non stock application like ours.
Christavia C-FDWS
Ted French
PostPosted: Thu Apr 02, 2009 5:43 pm    Post subject: Eddie's Moose Reply with quote
Thanks guys.
Ted
 Filesize:  502 Bytes
 Downloaded:  798 Time(s)
Ted French
RV-10 fuselage
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
