dale1rv6(at)comcast.net Guest
Posted: Mon Mar 30, 2009 7:14 pm Post subject: timing advance |
I have to protest the allegation that conditions in the combustion chamber would cause early failure of a magneto. BTW, Before installing my 2nd (dual) electronic ignition I put 900 hours on a slick mag (while running the Electroair), working perfect at the time of removal. Proper use of the Electroair or Lightspeed systems reduces CHTs and increases horsepower. There are many well educated pilots on this forum. Your system may be good, but please stick to the facts.
Dale
RV6a
0-360 Electroair / Lightspeed, dual electric sys
2.67 KB |
2672 Time(s) |
G3i Ignition
Joined: 26 Mar 2009 Posts: 11 Location: Englewood, CO.
Posted: Tue Mar 31, 2009 4:07 am Post subject: timing advance |
Hello Dale,
Thank for the reply, this is a great topic and has been going around the lunchroom many times and at my chapter meetings as well as others.
Definitely do not want to step on any toes or slam other ignition systems. This is just experience and information that I and others have gathered over the years. The mags that I have inspected that were 1/2 and 1/2 that had failed, the failure was in the distributor block with severe carbon tracking, resulting in miss-fire. However, I've have seen that in the typical normal 2 mag set-up as well. The cylinder pressure does increase when there is a earlier firing event before the mag firing. However, this is NOT going to guarantee of an early magneto failure though. The mag just has to work harder to ionize the spark that’s all. Now if there was already an existing problem. It would definitely increase the chance of earlier failure of that mag/component.
Sincerely,
Thomas S.
----- Original Message -----
[quote] Sent: Monday, March 30, 2009 9:11 PM
Subject: ***SPAM***Re: Re: timing advance
Dale
RV6a
2.67 KB |
2671 Time(s) |
_________________ Thomas S.
www.G3ignition.com
Follow G3i on Facebook.
www.facebook.com/pages/G3i-Ignition/243104229291 |
Posted: Tue Mar 31, 2009 2:41 pm Post subject: timing advance |
Hi Thomas,
And thank you for further info. Compliments to you for taking my opinion in a positive way. Will be watching to learn more.
Best of luck,
Dale
